B777 della Malaysia Airlines scompare dai radar
Re: B777 della Malaysia Airlines scompare dai radar
riporto da: http://avherald.com/h?article=4710c69b&opt=0
Malaysia's Prime Minister stated on Mar 15th that based on new satellite data there is evidence that the data communication systems and transponder had been turned off by deliberate action by someone on board and the aircraft deviated off course, the last confirmed communication between aircraft and satellites occurred at 00:11Z
On Mar 24th 2014 Malaysia's Prime Minister announced that according to new computations by Inmarsat and the British AAIB there is no reasonable doubt that flight MH-370 ended in the South Indian Ocean west of Perth (Australia).
in base a queste dichiarazioni appare evidente che entrambi gli ATC transponder e il Datalink siano stati resi inoperativi ma il Satcom ha continuato ad essere alimentato.
- richelieu
Dopo un falso allarme .....
http://www.jacc.gov.au/media/releases/2 ... mr016.aspx
http://www.jacc.gov.au/media/releases/2 ... mr018.aspx
..... le ricerche continuano ..... http://www.jacc.gov.au/media/releases/2 ... mr017.aspx
- richelieu
Come si svilupperanno oggi le ricerche .....
Fonte ..... http://www.jacc.gov.au/media/releases/2 ... mr019.aspxToday, Australian Defence Vessel Ocean Shield continues more focused sweeps with the Towed Pinger Locator to try and locate further signals related to the aircraft's black boxes.
The AP-3C Orions continue their acoustic search, working in conjunction with Ocean Shield.
The oceanographic ship HMS Echo is also working in the area with Ocean Shield.
This work continues in an effort to narrow the underwater search area for when the Autonomous Underwater Vehicle is deployed.
Mi chiedo:
se, come dichiara la Honeywell http://aerospace.honeywell.com/blog/abo ... lack-boxes e comunque ampiamente documentato, la black box emette un segnale rilevabile a poche miglia di distanza, che diavolo stanno rilevando i mezzi impegnati in tal senso, da non poter restringere drasticamente l'area delle ricerche
- bigshot
Perchè ricevere il segnale vuol dire essere vicini ma non per forza esserci passati sopra. Restringi il campo senza dubbio (come hanno fatto) ma non è così immediato ritrovarle.
Sarà ma, dando uno sguardo su http://www.marinetraffic.com/it/ais/home/, le navi impegnate nella ricerca, battono un'area troppo vasta, per essere correlata ad un segnale che può essere rilevato solo a qualche miglio di distanzabigshot ha scritto:Perchè ricevere il segnale vuol dire essere vicini ma non per forza esserci passati sopra. Restringi il campo senza dubbio (come hanno fatto) ma non è così immediato ritrovarle.
- MasterW
Quei "rettangoli" color magenta a cosa si riferiscono?
Li ho notati anche io quest'oggi. Credo abbiano voluto evidenziare le aree maggiormente interessate alle ricerche infatti su quello più a est vi è l' Ocean Shield. Non ne ho mai visti simili altrove.MasterW ha scritto:Quei "rettangoli" color magenta a cosa si riferiscono?
- MR
RAI News: "Rinvenuto strato di carburante nella zona delle ricerche"
http://www.rainews.it/dl/rainews/artico ... e488a.html
Per seguire le ricerche "live": http://www.marinetraffic.com
Non si pensava fosse precipitato per aver consumato tutto il carburante? Se c'è in mare tanto carburante da formare uno strato rintracciabile significa che l'aereo ne aveva ancora ed è precipitato per altre cause?
- maxago
Se ho capito bene, l'area piccola vicino alla Ocean Shield e alla Echo è quella di ricerca sottomarina. Le due aree magenta a ovest sono quelle di ricerca degli eventuali resti galleggianti. Le aree di ricerca a ovest sono necessariamente più vaste e tengono conto della deriva delle correnti marine a oltre un mese dall'evento.ettore65 ha scritto:Li ho notati anche io quest'oggi. Credo abbiano voluto evidenziare le aree maggiormente interessate alle ricerche infatti su quello più a est vi è l' Ocean Shield. Non ne ho mai visti simili altrove.MasterW ha scritto:Quei "rettangoli" color magenta a cosa si riferiscono?
Max
potrebbe essere il carburante non utilizzabile,unusable fuel,nell'ordine di qualche centinaia di kg ciascun serbatoio.Ryanjet ha scritto:Non si pensava fosse precipitato per aver consumato tutto il carburante? Se c'è in mare tanto carburante da formare uno strato rintracciabile significa che l'aereo ne aveva ancora ed è precipitato per altre cause?
ma potrebbe anche essere olio motore oppure olio idraulico e finche' non faranno le analisi di un campione prelevato non si avrebbe la certezza che si tratti di jetA/skydroll/mobil...
Chiaro, grazie per la spiegazione.
Mi chiedo (girando la domanda a chi ha avuto premura di leggersi qualche cartina): è possibile che dopo più di un mese, posto che sia caduto da quelle parti, non sia stato trovato non dico un corpo ma, che so, un imbottitura di sedile, un pezzo di fusoliera...?
E che la corrente non abbia portato nulla, ma proprio nulla, a depositarsi sulle coste australiane?
Le coste australiane non sono come le nostre: sono per lo più deserte, e parchi nazionali, quindi potrebbe essere stato depositato, ma nessuno l'ha visto...effegi88 ha scritto:Mi chiedo (girando la domanda a chi ha avuto premura di leggersi qualche cartina): è possibile che dopo più di un mese, posto che sia caduto da quelle parti, non sia stato trovato non dico un corpo ma, che so, un imbottitura di sedile, un pezzo di fusoliera...?
Pilotastro della domenica
Facile che i corpi siano stati preda di squali, non credo "durino" molto in mezzo all'oceano.
- richelieu
Le ricerche, intanto, proseguono senza esito .....
I comunicati del JACC degli ultimi giorni .....
14/04 - http://www.jacc.gov.au/media/releases/2 ... mr021.aspx
15/04 - http://www.jacc.gov.au/media/releases/2 ... mr022.aspx
16/04 - http://www.jacc.gov.au/media/releases/2 ... mr023.aspx
16/04 Update - http://www.jacc.gov.au/media/releases/2 ... mr024.aspx
17/04 - http://www.jacc.gov.au/media/releases/2 ... mr025.aspx
3 giorni..14 aprile 2014
Angus Houston ha dichiarato che un campione del materiale scoperto è stato inviato in Australia per essere analizzato. Il carburante non sembrerebbe appartenere a nessuna delle navi in transito nell'area.
17 April 2014—am
The oil sample collected by Ocean Shield has now arrived in Perth and will be subject to detailed testing and analysis. We will provide details of the results when they become available.
- richelieu
Non è carburante .....
Fonte ..... JACC 17/04 Update - http://www.jacc.gov.au/media/releases/2 ... mr026.aspxAt the recent media conference conducted by the Chief Coordinator of the Joint Agency Coordination Centre, Air Chief Marshal Angus Houston (Ret'd), said that the Australian Defence Vessel Ocean Shield had detected an oil slick on Sunday evening in her current search area.
Preliminary analysis of the sample collected by ADV Ocean Shield has confirmed that it is not aircraft engine oil or hydraulic fluid.
Non avevamo dubbi...richelieu ha scritto:Non è carburante .....
- richelieu
Bluefin-21 prosegue il suo lavoro .....
http://www.jacc.gov.au/media/releases/2 ... mr028.aspx
Fonte ..... JACC Media Release - 19 April 2014—am .....Overnight Bluefin-21 AUV completed mission six in the underwater search area. Bluefin-21 has searched approximately 133 square kilometres to date.
Data from the sixth mission is currently under analysis.
No contacts of interest have been found to date.
- richelieu
"Unidentified material washed ashore" ..... http://www.jacc.gov.au/media/releases/2 ... mr035.aspx
- richelieu
Aggiornamento .....
Inoltre ..... "Australian beach debris unrelated to MH370: ATSB" .....
http://www.flightglobal.com/news/articl ... sb-398516/
Fonte ..... JACC ..... http://www.jacc.gov.au/media/releases/2 ... mr036.aspxThe Australian Transport Safety Bureau (ATSB) has advised that after examining detailed photographs of material washed ashore 10 kilometres east of Augusta, it is satisfied it is not a lead in relation to the search for missing flight MH370.
Any further information will be made available if, and when, it becomes available.
- richelieu
Ricerche ..... si cambia ..... meno in aria ..... di più sotto la superficie del mare .....
"Australian PM announces major shift in MH370 search" .....
http://www.flightglobal.com/news/articl ... ch-398628/
"Fruitless search for MH370 to enter 'new phase': Tony Abbott" .....
http://www.smh.com.au/federal-politics/ ... zr0sb.html
- danko156
A questo punto è bene proseguire le ricerche via mare. Non vedo a cosa possa servire ormai cercare anche per via aerea.
DR
Per me stanno ancora cercando dalla parte sbagliata...
Che buffoni...sigmet ha scritto:Per me stanno ancora cercando dalla parte sbagliata...
- richelieu
Fonte ..... http://www.jacc.gov.au/media/releases/2 ... mr041.aspxThe search for missing Malaysia Airlines flight MH370 is commencing a new phase and will transition over the coming weeks to an intensified undersea search.
- richelieu
Intanto ..... la Marina USA .....
"Navy Pulls P-8s and Cargo Ship From Search for Missing Malaysian Airliner" .....
http://news.usni.org/2014/04/30/navy-pu ... n-airliner
Anche se .....
Anche se .....
The Navy will continue to aid the Australians with use of the service contracted Bluefin-21 — an autonomous underwater vehicle (AUV) to look for the plane that went missing on March 8 .....
Il ministero dei trasporti della Malesia ha rilasciato il primo Preliminary Report sull'evento, che viene riportato oggi da AvHerald:
http://avherald.com/h?article=4710c69b/028&opt=0
Comprende anche le pagine del Cargo Manifest
Da notare:JT8D ha scritto:Il ministero dei trasporti della Malesia ha rilasciato il primo Preliminary Report sull'evento, che viene riportato oggi da AvHerald:
Lithium Ion Batteries, 133 pkgs+67 pkgs loose
Un preliminary report deve essere inoltrato entro 30 giorni dall'incidente. Qui invece tra ping, squitters,squawk,e PRI sono passate 7 settimane per non sapere ancora se lo stanno cercando nell'emisfero giusto oppure no...
Quoto e aggiungo: "Allucinante !"sigmet ha scritto:Un preliminary report deve essere inoltrato entro 30 giorni dall'incidente. Qui invece tra ping, squitters,squawk,e PRI sono passate 7 settimane per non sapere ancora se lo stanno cercando nell'emisfero giusto oppure no...
Siccome anche su flightradar24 si puo' vedere la posizione di un aereo...come e' possibile che non riescano a trovarlo??
- danko156
Se spegni il trasponder dubito che tu sia visibile su fr24.
DR
