http://avherald.com/h?article=4a1c2ee4&opt=0
"A PIA Pakistan International Airlines Avions de Transport Regional ATR-42-500, registration AP-BHO performing flight PK-661 from Chitral to Islamabad (Pakistan) with 42 passengers and 5 crew, declared emergency reporting problems with the left engine, shortly afterwards radio and radar contact was lost with the aircraft at about 16:30L (11:30Z). Residents in Havelian near Abbottabad (Pakistan) heard sounds consistent with an impact. The crash site was located at that position about 25nm north of Islamabad. Emergency serivces are on their way to the crash site.
Local government sources report, seven bodies have been recovered, chances to find survivors are "bleak".
The airline reported contact with flight PK-661 has been lost, all resources have been mobilized to locate the aircraft.
Pakistan's Civil Aviation Authority confirmed the aircraft declared emergency shortly before it disappeared from radar screens. A search for the missing aircraft is underway."
PIA ATR42 Crash near Abbottabad (Thread Tecnico)
effegi88
Re: PIA ATR42 Crash near Abbottabad (Thread Tecnico)
Ultimi aggiornamenti:
"A PIA Pakistan International Airlines Avions de Transport Regional ATR-42-500, registration AP-BHO performing flight PK-661 from Chitral to Islamabad (Pakistan) with 42 passengers and 6 crew, reported the failure of the left hand engine (PW127E). The crew shut the engine down and continued towards Islamabad descending, some time later declared Mayday, shortly afterwards radio and radar contact was lost with the aircraft at about 16:30L (11:30Z). Residents in Havelian near Abbottabad (Pakistan) heard sounds consistent with an impact. The crash site was located at that position about 25nm north of Islamabad, the wreckage was ablaze with a plume of smoke over the crash site. All occupants of the aircraft perished in the crash.
The airline reported contact with flight PK-661 has been lost, all resources have been mobilized to locate the aircraft. The airline reported there were 42 passengers (including 2 infants, 2 Austrian and 1 Chinese Citizen), 3 flight crew, 2 cabin crew and a mechanics on board of the aircraft.
In the evening the airline confirmed that AP-BHO had crashed near Havelian.
Pakistan's Civil Aviation Authority (CAA) confirmed the aircraft declared emergency reporting engine trouble shortly before it disappeared from radar screens. Later the day the CAA reported that there had been no survivors, 36 bodies were recovered so far.
The Aviation Herald received information - contradicting a number of media reports in Pakistan - that the aircraft departed Chitral without any mechanical defect, no minimum equipment list requirements were in effect.
The blackboxes have been recovered and have been handed to Pakistan's Civil Aviation Authority.
(http://avherald.com/h?article=4a1c2ee4&opt=0)
"On Jan 11th 2019 Pakistani TV Station DunyaNews showed what they claim is a safety recommendation released by Pakistan's SIB (Editorial note: the document as shown does not reveal an official letter head nor does it reveal a date, see below, there is no reference to this document on the CAA Pakistan's website) which appears to provide a first clue as to what caused the mechanical failure of the engine (but does not explain why the aircraft impacted terrain). The document reads in the factual part:
On 07 Dec 2016, a PIAC aircraft ATR (AP-BHO) flying from Chitral to Islamabad crashed near Havelian by killing all 47 souls on-board. Safety Investigation Board (SIB) of Pakistan was mandated by the Federal Govt to carry out detailed investigation into this unfortunate air crash.
The investigation is towards a concluding stage, however, some important findings of technical nature require immediate attention/intervention.
These are as follows:
(a) Sequence of events was initiated with dislodging of one blade of Power Turbine Stage-1 (PT-1), inside Engine No 1 (left-side engine) due to fatigue.
(b) This dislodging of one blade resulted in in-flight engine shut down, and it contributed towards erratic/abnormal behavior of No 1 Propeller.
(c) According to a "Service Bulletin" these turbine blades were to be changed after completion of 10,000 hrs. on immediate next maintenance opportunity. The said engine was under maintenance on 11 Nov 2016, at that time these blades had completed 10004.1 hrs (due for a change). This activity should have been undertaken at that time, but it was missed out by the concerned.
(d) Aircraft flew approximately 93 hrs after the said maintenance activity, before it crashed on 07 Dec 2016.
(e) Missing out of such an activity highlights a lapse on the part of PIAC (Maintenance and Quality Assurance) as well as a possible in-adequacy/lack of oversight by PCAA".
Ma senza un motore su due l'aereo precipita?
E' stato rilasciato il final report relativo a questo incidente:
http://avherald.com/h?article=4a1c2ee4/0000&opt=0
Se l'elica non va in bandiera si.
Esatto, l'elica non era in bandiera. Tra l'altro, rilevanti gli aspetti manutentivi precedenti all'incidente.
