Mike Pence ..... va fuori pista .....
richelieu
Messaggio da richelieu »
Mike Pence ..... candidato Vice Presidente di Donald Trump ..... esce di pista .....
A Boeing 737-700 carrying the running mate of Republican presidential candidate Donald Trump skidded off a wet runway after landing at LaGuardia Airport in New York late on 27 October.
The Eastern Airlines-operated charter flight came to a stop on the grass beyond the runway, according to local reports.
Fonte ..... "​Aircraft for Trump's running mate skids off LaGuardia runway" .....
CNN ..... "Plane carrying Pence skids off runway" .....
NYT ..... "Plane With Mike Pence Aboard Skids Off La Guardia Runway" .....
ASN ..... "ASN Wikibase Occurrence # 190959" .....
Re: Mike Pence ..... va fuori pista .....
Messaggio da tartan »
Preferisco non commentare questa notizia, ancora mi ritengo una persona rispettabile e perciò mi tengo dentro tutto quello che cerca di uscire fuori. :mrgreen:
"On Nov 22nd 2016 the NTSB reported that the aircraft had accumulated 48,179 flight hours in 17,098 flight cycles. The cockpit voice and flight data recorder were recovered by the NTSB, both recorders were downloaded and contained data in good quality. The flight crew reported they acquired visual contact with the runway at 700 feet AGL, the landing followed a stable approach, however, the aircraft was floating during the landing flare and touched down about 3000 feet down the runway, the speed brakes were manually deployed about 4 seconds after touch down, thrust reversers were activated 7 seconds after touch down. There was no anomaly with the aircraft and no abnormal braking action, the NTSB commented this was corroborated by the flight data recorder. The NTSB interviewed the flight crews of 4 flights landing prior to the occurrence aircraft, none of the crews reported any problems with the braking action on the wet runway."
(http://avherald.com/h?article=49ff6bcc&opt=0)
