Annuncio tratto da un  noto sito inglese di ricerca personale:-
VoliAmo
MANTENANCE TECHNICIANS
BRESCIA-MILAN
We are looking for a full / part time aircrfat mantenance technicians to work at an aircraft transit maintenance station located in Brescia Airport/Italy.
Ratings and Certificates:
Aircraft Maintenance Licence / EASA Part-66 B1 (Airframe/Powerplant)
Boeing 737-200 / JT8D-15 engine Type rating
Aircraft Maintenance Licence / EASA Part-66 B2 (Avionics)
Experience:
TRANSIT MAINTENANCE AND TECHNICAL HANDLING oF B737-200 AIRCRAFT Including:
trouble shooting/ perform arrival WAC, Prefligt & Transit check, refueiling, oilservicing, removal and installation aircraft components, correction of technical discrepancies, keep aircraft records i.e. Aircraft Technical Logbook, MEL/HIL items.
Potential candidates must have the ability to work well in team, but are also able to make independent decisions, frequently under pressure. They must have the ability to follow instructions provided in written or blueprint form, and to interpret regulations. They should enjoy analysing information and troubleshooting problems, being methodical in their approach to the work, and in subsequent report writing. Written and spoken English is required.
Per chi fosse interessato.
Steve
						VoliAmo- Tecnici 737
				Snap-on
Sinceramente la risposta non dovrei darla in questo link, ma siccome non vorrei fare pasticci nello spostare il tuo intervento in una nuova discussione in area "maintenance", provvedo subito a risponderti.
I "bluprint form" sono da intendersi le "job card" di manutenzione relative ad item programmati.
Su di esse sono riportati i dati relativi all'operazione da eseguire [ marche aeroplano, ore, cicli, ATA di riferimento, riferimenti procedurali, P/N e S/N delle parti rimosse/installate, firma degli operatori,d ei tecnici e dei supervisor,etc]
La prima copia è su carta copiativa (blueprint) in maniera che la seconda copia rimane impressa e spedita al planning per le opportune registrazioni.
Per chi fosse interesato alla posizione ricercata dall'annuncio, riporto qui di seguito il link:-
http://www.aviationjobsearch.com/employ ... acID=66094
Steve
Steve
 Cosa vuol dire "blueprint form"
