Questi i requisiti di Virgin Blue per un direct entry FO
We do have some minimum criteria that you must meet if you wish to join our Flight Crew team.
Australian ATPL or CPL with ATPL Theory Subjects
Australian Command Instrument Rating
Australian Class 1 Medical Certificate
Total Flying Time - 1000 hours (must include at least 500 hours in Command of a Multi Engine Aircraft)
apply via http://www.bfound.net/detail.aspx?jobId ... Id=43&rq=2
e ora la Jet Star...
The minimum requirements for selection as a pilot with Jetstar Airways are:
Hold, or be eligible to hold an Australian ATPL;
Have passes in all Australian ATPL subjects;
Hold, or be eligible to hold, an Australian Class 1 Multi-Engine Command Instrument Rating;
Current Class 1 Medical Certificate;
Hold relevant Australian permanent residency status;
Strong and effective team working competencies;
Committed to service excellence;
Have an educational degree level;
Eihter
Minimum 2000 hours total flying time of which 500 may be helicopter; and
500 hours Pilot in Command (excluding ICUS) of Multi-Engine aircraft.
or
Minimum 4000 hours total time of which 500 hours may be helicopter time;
Minimum 2000 hours Co-Pilot or Command time on jet transport with a MTOW greater than 40,000kg; and
Minimum 500 hours Pilot in Command (up to 250 hours may be ICUS).
la qantas elenca i requisiti qui: http://www.qantas.com.au/info/about/emp ... ctCriteria
Sunshine Express
- Hold an Australian CPL
- Hold a command instrument rating
- Have at least 500 hr PIC fly experience with an education degree level or have at least 1000 hr PIC experience without an education degree level
- Turbo prop experience and Type Rating an advantage
NESSUNO RICHIEDE IL TYPE RATING..
ALLORA EUROFILI FATEVI AVANTI COI COMMENTI!!!
Perchè l'Australia....
Aces High
Re: Perchè l'Australia....
Non lo indicanoAussie_Pilot ha scritto:Questi i requisiti di Virgin Blue per un direct entry FO
ma non dicono se te lo pagheranno loro o se dovrai pagartelo tu.
Inoltre 4000 ore sul jet propelled multiengine non significano TR fatto, a meno di non aver fatto tanto aerotaxi su aerei per miliardari ?
Just step a foot in the door first, mate!
