La 'vasca da bagno' va al museo .....
richelieu
Messaggio da richelieu »
Più che una 'vasca da bagno' ..... a me sembra piuttosto un ferro da stiro rovesciato ..... :wink:
Welcome Flying Bathtub .....
(2/5/2015)
NASA's M2-F1 Lifting Body, tested at Edwards AFB, Calif., in the 1960s went on display at Edward's Air Force Flight Test Museum late last month.
"This is a hand built, one of a kind aircraft, designed to test the concept of wingless flight," explained museum specialist Tony Moore in a base release .....
"AFFT Museum acquires 'up-lifting' aircraft" ..... http://www.edwards.af.mil/news/story.asp?id=123437719
"This aircraft, made of steel tubes, wood, and fabric is a handmade work of art ... whose contributions are still being utilized today," he added.
M2-F1 was an unpowered glider prototype for follow-on lifting bodies, culminating in the rocket-propelled X-24 aimed at validating concepts for aerodynamically efficiency and reusable spacecraft.
The M2-F1, loaned from NASA's Armstrong Flight Research Center on-base, was initially towed aloft by a modified Pontiac convertible, and flew 77 flights towed by a C-47 to altitudes as high as 12,000 feet before releasing.
The AFFT cleared dedicated space to display NASA's history on base, and hopes to grow the exhibit in future.
Lifting Body factsheet ..... http://www.nasa.gov/centers/dryden/news ... MhC6EhpF3Q
Fonte ..... il 'Daily Report' dell' AFA .....
"NASA - The M2-F1: 'Look Ma! No Wings!'" ..... http://www.nasa.gov/topics/history/M2_F1.html
Erano veramente ..... tempi eroici ..... :mrgreen:
giragyro
Re: La 'vasca da bagno' va al museo .....
Messaggio da giragyro »
è grazie a questi " lifting boby " se abbiamo avuto lo space shuttle . massimo rispetto per coloro che li cavalcarono
richelieu
giragyro ha scritto:è grazie a questi " lifting boby " se abbiamo avuto lo space shuttle . massimo rispetto per coloro che li cavalcarono
E' vero .... e lo M2-F1 ne fu, nella tarda estate del 1963, il precursore .....
http://www.flightglobal.com/FlightPDFAr ... 201668.PDF
http://www.flightglobal.com/FlightPDFAr ... 201669.PDF
Per saperne di più ..... "Wingless Flight" .....
http://ntrs.nasa.gov/archive/nasa/casi. ... 169231.pdf
Oppure ..... "Flying Without Wings" .....
giragyro
steve austin , astronauta , un uomo vivo per miracolo .......
nei primi 30 secondi della sigla si vedeva uno dei lifting bodies in volo ....penso fosse L'X24 A
