JSF
Incidente a un JSF in fase di rifornimento in volo, il pilota si eiettato
- richelieu
Re: Incidente a un JSF in fase di rifornimento in volo, il pilota si eiettato
Se ne parla anche nella discussione "USN & USMC e le loro aviazioni" ...Valerio Ricciardi ha scritto: 1 ottobre 2020, 13:56 Un altro esemplare perso
https://video.lastampa.it/esteri/disast ... 954/122077
- richelieu
Re: JSF
Il rapporto è stato appena pubblicato ...richelieu ha scritto: 21 maggio 2020, 23:53 Intanto ... un F-35A dell' USAF è precipitato al termine di un volo di addestramento notturno ...
... airforcemag.com ... "Eglin F-35A Crashes Upon Landing, Pilot Ejects" ...
Anche qui ... theaviationist.com ... "USAF F-35A Lightning II from 58th Fighter Squadron Crashes at Eglin AFB, Florida" ...
... airforcemag.com ... https://www.airforcemag.com/eglin-f-35- ... o-faulted/ ...
- richelieu
Re: JSF
E' arrivato ODIN
... bye bye ALIS ...
Anche qui … hitechaerospace.com … First Lockheed Martin F-35s Loaded With ODIN Hardware …
… dvidshub.net … ODIN Hardware Operating at MCAS Yuma …The F-35 Lightning II Joint Program Office (F-35 JPO), in partnership with Lockheed Martin, fulfilled the next major milestone in the development of the Operational Data Integrated Network (ODIN).
On Sept. 29, 2020, Marines at U.S. Marine Corps Air Station (MCAS) Yuma, Ariz., completed the loading of a single squadron of F-35Bs on new modernized ODIN hardware.
Later that day, the USMC flew the first flight supported by the new hardware and flew four more flights the following day.
The new modern hardware is running the most current version of the Autonomic Logistics Information System (ALIS) and is designed to host future ODIN applications.
Successful operation at MCAS Yuma validates the next-generation servers as a viable successor to the aging ALIS system and provides a significant performance upgrade to F-35 units.
As was announced earlier this year, ODIN is the planned replacement for ALIS.
- richelieu
Re: JSF
Una ipotesi che emerge periodicamente ...
… psk.blog.24heures.ch … Les F-35 exports sont moins performants ! …
Re: JSF
Pratt & Whitney si aggiudica contratto per studiare gli upgrade del motore F135:
https://www.md80.it/2020/10/21/pratt-wh ... ion-study/
- richelieu
Re: JSF
Il "pacco di sopravvivenza" ...
(*) … eielson.af.mil … First arctic survival kits installed in Eielson F-35As …
… airforcemag.com … Eielson F-35s Get Arctic Survival Kits …Arctic survival kits are the newest feature on the Air Force’s F-35A Joint Strike Fighters at Eielson Air Force Base, Alaska.
The F-35 was not designed to carry sleeping bags and other equipment to protect pilots if they need to eject into the brutal Arctic temperatures, which regularly dip to -40 degrees Fahrenheit or colder.
Alaska-based Airmen had to figure out how to fit roughly 10 pounds of survival gear into a 5-pound sack attached to the F-35’s ejection seat.
After months of research and testing, the 354th Operations Group commander approved the final kit, which includes survival tools such as a knife for gathering food, a poncho to stay dry, and flares to alert rescue crews to a downed pilot’s location.
“Due to the smaller size of the seat, we are limited on how many items we can pack in here,” Staff Sgt. Ross Dugger, a 354th Operations Support Squadron aircrew flight equipment craftsman, said in a release (*).
Re: JSF
Nel nostro c'erano una Beretta .22 con silenziatore, profilattici, monete d'oro e le solite cose per sopravvivere...
Il calibro della pistola era stato scelto in quanto non essendo il proiettile supersonico lo sparo, silenziato, era come quello
di una pistola ad aria compressa ed usandola per cacciare o per agguati non ci si faceva individuare.
Le monete d'oro per comprarsi l'aiuto ed i profilattici potevano servire come laccio emostatico, contenitore sterile per l'acqua,
copertura di mani ustionate, elastici per trappole o per fare un arma da lancio per la caccia... e per il loro uso naturale.
Secondo le convenzioni in caso di cattura in possesso del silenziatore si poteva essere fucilati per spionaggio.
- richelieu
Re: JSF
In teoria si ... nella realtà storica non sempre ...Lampo 13 ha scritto: 23 ottobre 2020, 12:36 Nel nostro c'erano una Beretta .22 con silenziatore ...
… sputnikimages.com … Material evidence in Francis Gary Powers case …
… taskandpurpose.com … The History Of The CIA’s Silent Pistol Of Choice …
- richelieu
Re: JSF
F-35B ... continuano le tensioni fra AMI e MMI sulla gestione dei velivoli ...
… defensenews.com … Italy’s Navy-Air Force tussle over the F-35 comes to a head …A long-running tussle between Italy’s Air Force and Navy over the F35-B jet is coming to a head as deadlines approach for deciding who gets the next aircraft to roll off the production line and where it will be based.
Italy’s planned order for 30 of the short-takeoff-and-vertical-landing aircraft is to be split by the services, with each receiving 15, in addition to the 60 F35-As ordered for the Air Force.
After the first two of Italy’s F35-Bs went to the Navy and the third to the Air Force, a decision is due, possibly within weeks, on who gets the fourth one next year as the two military branches jostle for primacy on the program.
- richelieu
Re: JSF
Un consiglio spassionato agli alleati ... "Imparate la lezione e non commettete i nostri errori" ...
… airforcemag.com … Wilsbach to Allies: Learn from USAF’s Mistakes, Fly Your F-35 Like an F-35 …Pacific Air Forces commander Gen. Kenneth S. Wilsbach has some advice for users of the F-35 in his region: Don’t use it like the aircraft you’re used to, but take advantage of its full potential.
Speaking at an AFA Mitchell Institute virtual event Oct. 27, Wilsbach said the U.S. Air Force operated the F-22 like the F-15C for “about five years,” failing to fully exploit its fifth-generation stealth and sensor fusion capabilities.
“It took us a while to learn” what the jet could really do, he said, and now, “the tactics are completely different.”
He advises the F-35 partners to use the aircraft “like an F-35,” and not like some of the high-performance fourth-generation aircraft they have been operating.
“Take advantage of the lessons learned that we’ve had,” he said.
“Skip right to that … and cycle through those lessons learned that much faster. Take full advantage of the platform.”
- richelieu
Re: JSF
A proposito degli F-35B della Marina Militare ...
… RID … F-35 e CAVOUR: IOC nel 2024 …
In precedenza …
... RID … CAVOUR, slitta la crociera negli USA …
In precedenza …
- richelieu
Re: JSF
Gli F-35 di Amendola tornano al poligono elettronico “Polygone”, in Germania, nell'àmbito dell'esercitazione “Lightning 2020”
… aeronautica.difesa.it … F-35: IL 2° STORMO ED IL XIII GRUPPO DEL 32° STORMO SI ADDESTRANO CONGIUNTAMENTE DURANTE L’ESERCITAZIONE “LIGHTNING 2020” …Lunedì 19 ottobre 2020 presso l’aeroporto militare di Rivolto (UD), sede del 2° Stormo, con l’atterraggio di quattro velivoli F-35, provenienti dal 32° Stormo di Amendola (FG), ha avuto inizio l’esercitazione “Lightning 2020”.
Per due settimane, i velivoli del XIII Gruppo hanno operato dall’aeroporto di Rivolto effettuando diverse sortite giornaliere per raggiungere il poligono elettronico “Polygone”, in Germania, e per operare con i sistemi di difesa aerea disponibili presso il 2° Stormo.
L’intero evento esercitativo ha rappresentato un’importante occasione di addestramento per tutte le articolazioni del 2° Stormo impegnate a garantire il pieno supporto tecnico-logistico e operativo al personale della cellula del 32° Stormo rischierata.
- richelieu
Re: JSF
Polemiche ...
Tricarico replica a Binelli Mantelli ...
… formiche.net … Spirito interforze ed F-35. La replica del gen. Leonardo Tricarico …Finché ho potuto, ho evitato di commentare pubblicamente le scelte di altre Forze armate nella convinzione che il dibattito susseguente sarebbe stato rubricato come una lite da pollaio, dove ognuno tira l’acqua al proprio mulino. Ma quando è troppo e troppo. Proprio su questa testata infatti, solo per aver auspicato una migliore integrazione tra Marina ed Aeronautica nell’impiego dell’F-35 B (qui il precedente articolo), sono stato oggetto di una inusitata reazione da parte di un ammiraglio che ha definito falsità le mie affermazioni, ed il cui pensiero mi auguro non rifletta quello della Marina militare.
- richelieu
Re: JSF
F-35A per l'Aeronautica Militare ... e fanno 13 ...
… aviation-report.com … Maiden Flight del tredicesimo velivolo F-35A (AL-13) dell’Aeronautica Militare …Da Cameri è finalmente uscito di fabbrica il 13° F-35A destinato al 32° Stormo dell’Aeronautica Militare, a distanza di pochi giorni dalla consegna ufficiale degli ultimi 2 velivoli olandesi prodotti dallo stabilimento novarese co-gestito da Lockheed Martin e Leonardo per conto del Ministero della Difesa italiano.
Il maiden flight è avvenuto nel tardo pomeriggio di ieri 18 novembre, accompagnato da un Eurofighter Typhoon F-2000A (4-8) dell’Aeronautica Militare nel ruolo di chase plane.
Da poco si sono conclusi altri due voli di collaudo in una giornata decisamente migliore rispetto a quella di ieri.
- richelieu
Re: JSF
Polemiche ...
La bega infinita (per interposta persona) fra AM e MM non si ferma ...
… it.insideover.com … Una guerra interna alla Difesa: cosa succede con gli F-35B …
- richelieu
Re: JSF
Polemiche ...
L' Amm. Luigi Binelli Mantelli risponde ad un articolo del Direttore di RID (link interno) ed esprime, fra l'altro, il suo punto di vista sui caccia STOVL e su chi li deve utilizzare ...
Da RID ... Difesa, ma davvero è necessaria una nuova Riforma? …
- richelieu
Re: JSF
Il Direttore di RID ha scritto ...
Mettere tutti gli F-35B in una sola base (Amendola) potrà anche essere una soluzione meno costosa ... ma, al tempo stesso, fino a che punto è conveniente, sotto l'aspetto della sicurezza, mettere tutte le uova nello stesso paniere?Secondo lo Scrivente, tale riforma dovrebbe ricomprendere, partendo dall'alto, i seguenti punti:
- 7. Sinergie a livello interforze su alcune capacità, in particolare per ciò che concerne la componente F-35B.
Più specificamente, tale componente dovrebbe essere basata su una sola base (Amendola), in modo tale da mettere a fattor comune supporto logistico, training virtuale e dottrine operative, e disporre di 30 velivoli (15 della MM e 15 dell’AM) con comando a rotazione tra AM ed MM.
Allo stesso tempo i 15 velivoli dell’AM dovrebbero poter operare sulle 2 portaereomobili della Marina, con piloti addestrati e qualificati di conseguenza, mentre i 15 velivoli della MM dovrebbero “andare” a terra qualora le circostanze lo richiedano.
In casi di contingenza ad alta intensità, dunque, potremo avere una ventina di F-35B capaci di operare tanto da “piste corte” ed eliporti, quanto dalle 2 portaeromobili
- richelieu
Re: JSF
Mentre il Direttore di RID pubblica una "breve replica" all'Ammiraglio Binelli Mantelli ...
https://www.portaledifesa.it/index~phpp ... ,3894.html
... Silvio Lora Lamia pubblica a sua volta, su Analisi Difesa, un commento sulla vicenda ...
https://www.analisidifesa.it/2020/11/la ... -italiani/
- richelieu
Re: JSF
Tutto sommato ... è meglio non rivelare troppo ...
… airforcemag.com … F-35 Crash Corrective Measures Must Remain Secret, JPO Says …Action to correct hardware problems that contributed to the crash of an F-35 on May 19 at Eglin Air Force Base, Fla., must remain secret, the F-35 Joint Program Office said Nov. 23.
“Explicit details related to corrective actions have the potential to compromise operational security,” a JPO spokeswoman said, without elaborating.
Broadly, she said, the JPO participates in accident investigations and identifies “corrective actions and evaluates, prioritizes, and incorporates those actions into aircraft maintenance and production procedures.”
She added that “safety of flight remains the highest priority in the adjudication of corrective actions” and said the 585 F-35s in service worldwide have accumulated more than 335,000 safe flying hours.
- richelieu
Re: JSF
Un'arma che, a tempo debito, dovrebbe arrivare anche in Italia ...
… share-ng.sandia.gov … Flight tests to show B61-12 will work on Air Force’s newest fighter jet …A mock B61-12’s strike in the dusty Nevada desert successfully completed the first in a series of flight tests with the U.S. Air Force’s newest fighter jet, demonstrating the bomb’s first release from an internal bomb bay at greater than the speed of sound.
The flight test of the B61-12 with the F-35A Lightning II this summer was the first ever at Sandia National Laboratories’ Tonopah Test Range featuring the fighter jet.
It was also the first of a testing series that will conclude with full-weapon systems demonstrations designed to increase confidence the bomb will always work when needed and never under any other circumstances.
- richelieu
Re: JSF
Primo volo da solo ... dopo settimane al simulatore ...
… f35.com … Five Ways F-35 Training is Improving Mission Readiness for Pilots and Maintainers …It’s the morning of your first solo flight in the most advanced fighter jet ever created – the F-35.
You’re excited and anxious because today culminates weeks of training and preparation.
Once onsite, you get assigned your tail number.
After hours of meticulous preparation and briefing, you head to the airplane knowing your maintenance crew chief has checked everything tip to tail getting it ready for flight.
It will be flawless.
- richelieu
Re: JSF
L'Italia e gli F-35B ... 30 velivoli sono, probabilmente, troppo pochi ...
… it.insideover.com … La diatriba degli F-35B per l’Aeronautica e la Marina …Insomma serve una capacità congiunta – definita jointness – dei comandi e una integrazione delle competenze, anche con parziali sovrapposizioni che garantirebbero una certa ridondanza in caso di necessità, quindi sostanzialmente la scelta di avere gli F-35B per due Forze Armate è giusta, ma non è giusta la decisione di acquistarne così pochi.
- richelieu
Re: JSF
L'Italia e gli F-35B ... il punto di vista dell'Ammiraglio (a riposo) Michele Cosentino ...
… ocean4future.org … Lo show di Pantelleria …
- richelieu
Re: JSF
A proposito del possibile acquisto degli F-35 da parte della Grecia ...
… gr.usembassy.gov … Statement by U.S. Ambassador to Greece Geoffrey R. Pyatt on F-35 Acquisition …
- richelieu
Re: JSF
Da un articolo (destinato ai soli abbonati) del quotidiano torinese "La Stampa" ...
… lastampa.it … Manutenzione e aggiornamento degli F-35: a Cameri ci sarà lavoro per quarant’anni …
Alle pagine 15, 16 e 17 del documento ...
… amcham.it … La centralità della relazione transatlantica tra Italia e Stati Uniti …
- richelieu
Re: JSF
L'Italia e il canto delle sirene di Lockheed Martin ...
... formiche.net ... Il ruolo di Lockheed Martin per la Difesa italiana. Parla Luigi Piantadosi …IL PROGRAMMA F-35
Al momento, il programma F-35 è “un esempio di sostenibilità internazionale, per cui sussistono contemporaneamente accordi governativi; collaborazione industriale ed economie di scala”.
Un programma che coinvolge 14 Paesi e che vede l’Italia nel ruolo di partner di secondo livello, con diversi primati: “Primo paese ad aver costruito un F-35 fuori dagli Stati Uniti sia nella versione A che B; primo paese ad aver sorvolato l’Atlantico con un F-35; primo paese ad aver dichiarato la capacità operativa iniziale dopo gli Stati Uniti; primo paese ad aver svolto una missione Nato con l’F-35”.
Il programma è ancora in crescita, e ciò alimenta le opportunità per il sito novarese di Cameri, unico centro di assemblaggio e verifica finale (Faco) in Europa per il velivolo di quinta generazione.
LE OPPORTUNITÀ PER L’ITALIA
L’obiettivo italiano, spiegato di recente dal ministro Lorenzo Guerini, è avere più lavoro.
Dal quadro illustrato da Piantadosi le opportunità ci sono.
“Si prevede che nel corso del programma, gli F-35 di stanza in Europa potranno essere dai 500 ai 700”, includendo anche i velivoli statunitensi operanti nel Vecchio continente, ma senza contare Belgio e Polonia, entrati da poco.
In più, “molti altri Paesi europei hanno manifestato interesse verso l’F-35”, comprese Finlandia e Svizzera, in cui sono in corso le gare, Emirati Arabi, Repubblica ceca e Romania.
Si punta dunque ad aumentare il ritorno per l’industria italiana, pari a 4 miliardi di euro fino al 2019, come notato dalla Difesa italiana nel recente documento programmatico.
Ritorno, ha detto Piantadosi, “di cui non beneficia soltanto Leonardo, ma un largo numero di piccole e medie imprese che agiscono come fornitori o sub-fornitori del programma”.
Per aumentarlo, serve l’impegno congiunto di istituzioni, difesa e industria, per proporre “un centro di eccellenza come quello di Cameri per i futuri acquirenti”, ha ricordato Piantadosi.
- richelieu
Re: JSF
Concentrazione ...
… airforcemag.com … 355th Fighter Squadron Activated to Fly F-35s at Eielson …Eielson Air Force Base, Alaska, now has its second F-35A squadron.
The 355th Fighter Squadron officially stood up during a Dec. 18 ceremony at the base, joining the 356th Fighter Squadron that activated earlier this year.
The base will eventually be the home to 54 of the aircraft, and with F-22s at Joint Base Elmendorf-Richardson, Alaska will be the home to the highest concentration of fifth-generation fighters in the Defense Department.
“The 354th FW has been tasked with standing up two combat-coded F-35A squadrons for a total of 54 F-35As at Eielson AFB,” squadron commander Lt. Col. Samuel Chipman said ...
“The 355th FS is the final addition to this tasking.”
- richelieu
Re: JSF
Initial Operational Capability per gli F-35A australiani ...
... minister.defence.gov.au ... https://www.minister.defence.gov.au/min ... perational ...
Anche qui ... abc.net.au ... https://www.abc.net.au/news/2020-12-28/ ... l/13017700 ...
- richelieu
Re: JSF
RAF Lakenheath ... in arrivo, dal 2021, 54 F-35A dell'USAF ...
… military.com … As Marines Plans Historic Joint F-35 Ops with UK, Air Force Looks for Ways to Follow Suit …
Tre mesi fa … airforcemag.com … USAFE Still Targeting F-35s at Lakenheath by 2021, Despite Construction Delays …
- richelieu
Re: JSF
E' stato consegnato all'Italia il 123° F-35 prodotto nel 2020 ...
… aviation-report.com … Lockheed Martin chiude il 2020 con 123 caccia di quinta generazione F-35 consegnati nonostante le difficoltà legate al Covid-19 …Lockheed Martin ha consegnato il 123mo velivolo F-35 dell’anno 2020 la settimana scorsa, un F-35A, variante a decollo e atterraggio convenzionale (CTOL), costruito presso la FACO (Final Assembly and Checkout) di Cameri, in Italia, e consegnato all’Aeronautica Militare italiana.
Nel 2020, 74 F-35 sono stati consegnati alle Forze Armate degli Stati Uniti, 31 alle nazioni partner internazionali e 18 ai clienti del programma statunitense per la vendita di equipaggiamenti militari all’estero (Foreign Military Sales).
In conseguenza dei ritardi nella catena di fornitura causati dal COVID-19, a maggio gli obiettivi di consegna annuali sono stati rivisti da 141 a 117-123 velivoli, con l’obiettivo di evitare fluttuazioni, che avrebbero determinato un aumento dei costi di produzione e creato ulteriori ritardi e difficoltà.
- richelieu
Re: JSF
Prossima partenza di Nave Cavour per gli Stati Uniti ...
… analisidifesa.it … Imminente la partenza della portaerei Cavour per gli Stati Uniti …La portaerei STOVL Cavour (C 550) è in procinto di lasciare la base navale di Taranto per raggiungere gli Stati Uniti ed iniziare l’attività che la porterà a qualificarne il ponte di volo, strutture, equipaggiamenti e personale, per l’impiego del velivolo stealth di quinta generazione Lockheed Martin F-35 Lightining II nella versione B a decollo corto ed atterraggio verticale.
- richelieu
Re: JSF
Una "Tempesta Perfetta 3.0" per l'Aeronautica Militare ...
… aeronautica.difesa.it … F-35: continua l’iter d’integrazione tra i velivoli di 4ª e 5ª generazione …Nei giorni 11 e 12 gennaio presso il 32° Stormo di Amendola, si è svolta la terza edizione dell’attività addestrativa denominata “Tempesta Perfetta” alla quale hanno partecipato F-35A, F-35B, MQ-9 Predator, diversi velivoli Eurofighter F-2000 provenienti dal 4°, 36° e 37° Stormo ed un G-550 CAEW del 14° Stormo, oltre a personale navigante del Reparto Sperimentale Volo.
L’evento, inserito nel contesto del continuo percorso di integrazione fra sistemi d’arma di 4ª e 5ª generazione, ha consentito un notevole ritorno addestrativo ed ottimizzato le diverse metodologie di impiego dei vari enti coinvolti.
- richelieu
Re: JSF
Trattative in corso ...
… airforcemag.com … Next F-35 Contracts Under Negotiation, Deal Expected by Late September …The F-35 Joint Program Office, Lockheed Martin, and Pratt & Whitney are negotiating prices for the 15th through 17th lots of Lightning II fighters and engines, aiming for a deal by the end of September.
The contracting strategy is to negotiate a “base year” contract for Lot 15, with “two single-year options (Lots 16 and 17),” a JPO spokeswoman said.
While the air vehicles are under negotiation, the “propulsion Lot 15-17 proposal is currently in technical evaluation,” the spokeswoman said.
Although Lockheed quotes prices publicly for F-35s with engines included, the government negotiates with the engine maker separately.
The Lightning II is powered by Pratt’s F135 turbofan.
