I understand Italian very well but I prefer to write in English.pippo682 ha scritto:Do you need an english answer?
Understanding Italian very well is quite different from writing in Italian very well and with all the respect that I have towards italian language, I do consider it's correct to use an international language, instead of writing in incorrect italian.Kitano ha scritto:This is an italian Forum, so you have to use italian language.
If you understand italian "very well" please write in italian. Thanks.
Well, there is no difficult to land a plane, even if with no power. You have to keep in mind you have not a second try, you are flying with a glider, like the Shuttle. The only difficult could be to be able to arrive to an airport. The more your quote, the more your possibility. For each feet of quote, you get about 15/20 feet on the ground.SimplePassenger ha scritto:let's imagine that it'll fly like a glider or like a plane with 2 broken engines, and how is it going to land???
Alianteatene77 ha scritto:Well done Luke
what does Glider mean? i don't want to go to read my dictonary, thanks
Grazie per la precisazioneGalaxy ha scritto:Glider means, in Italian, "ALIANTE"
Galaxy ha scritto:Poca confidenza Dega90!!!![]()
Ho postato insieme a te...
I think you don't need to be informed if both the engine are gone.... there is a strange quite....SimplePassenger ha scritto:ok guys, your answers convinced me and do you think in case there is an emergency in the plane during the flight, are passengers being informed and in which way? Or they stay relaxed, sleeping or reading while the plane is losing pieces on the way![]()
looking forward your creative answers!
Liuke ha scritto:لمجلس أمناء الوكالة الذرية ومجلس الأمنفي القاهرة حسين عبد الغني بكفالة بعد اعتقاله ?![]()
الطيران المدني سليمان عبيدات أن الطائرة
