Riporto la notizia, fortunatamente non risultano vittime.
https://aviation-safety.net/database/re ... 20221023-0
Grave incidente A330 a CEB
- cabronte
Re: Grave incidente A330 a CEB
Riporto anche da AvHerald:
https://avherald.com/h?article=50004095&opt=0
E' andata bene, sembra non vi stati nemmeno feriti di rilievo. I danni alla macchina invece sono decisamente rilevanti.
Aggiornamento
AvHerald riporta: "On Oct 24th 2022 Philippines Authorities as well as Korean Ministry of Land, Infrastructure and Transport report, according to first preliminary investigation results a hydraulic failure had caused a brakes failure".
(https://avherald.com/h?article=50004095&opt=0)
Aggiornamento
- b747-8
Praticamente si è sventrato!!! Ok il problema idraulico...ma come ha fatto a ridursi così??? Ok il fuori pista ma è impressionante davvero!!!cabronte ha scritto: 24 ottobre 2022, 9:33 Riporto la notizia, fortunatamente non risultano vittime.
BIRRA POINT
Ministro rapporti CULturali
BIRRA POINT
Oggi AvHerald riporta: "On Oct 25th 2022 it became known that the captain of the flight provided testimony that they suffered a hard touchdown on their second approach due to wind shear forcing them down, during the following go around a warning light regarding brakes came on. The crew therefore declared emergency, prepared for the emergency landing and performed a third approach in gusting winds and turbulence, a warning light regarding brakes pressure came on at the time of touch down and they could not slow down the aircraft".
E' stato rilasciato il final report relativo a questo incidente:
https://araib.molit.go.kr/LCMS/DWN.jsp? ... t+2022.pdf
