La Soyuz MS-14 fallisce l'aggancio alla ISS ...
richelieu
Messaggio da richelieu »
A rare uncrewed flight of a Soyuz spacecraft took another twist Aug. 24 when the spacecraft failed to make an automated docking with the International Space Station.
The Soyuz MS-14 spacecraft was scheduled to dock with the station’s Poisk module at about 1:30 a.m. Eastern.
While the spacecraft’s initial approach to the station took place normally, the spacecraft failed to make a final approach for docking, remaining about 90 meters from the station.
NASA said in a later statement (*) that the station’s two Russian cosmonauts, overseeing the docking, issued a command to abort the docking at 1:36 a.m. Eastern, directing the Soyuz to move away from the station.
The ISS, NASA added, was never in danger during the aborted docking attempt.
... spacenews.com ... "Uncrewed Soyuz aborts ISS docking" ...
(*) ... "Russian Spacecraft Docking Attempt No Earlier Than Monday" ...
Un nuovo tentativo di aggancio verrà dunque tentato Martedì 27 dopo un' operazione di riposizionamento della Soyuz MS-13 che avrà luogo Lunedì 26 ...
Instead, Skvortsov will board the Soyuz MS-13 spacecraft currently docked to the station’s Zvezda module Aug. 26 and manually dock it to the Poisk module.
That will free up the Zvezda module’s port for a new docking attempt by Soyuz MS-14.
The situation is complicated, however [it] is under control,” Roscosmos stated (*).
(*) ... http://en.roscosmos.ru/20890/ ...
(*) ... http://en.roscosmos.ru/20891/ ...
richelieu
Re: La Soyuz MS-14 fallisce l'aggancio alla ISS ...
Problema risolto ... aggancio felicemente avvenuto ...
... spacenews.com ... https://spacenews.com/soyuz-docks-with- ... d-attempt/ ...
... air-cosmos.com ... https://www.air-cosmos.com/article/le-s ... port-21607 ...
... roscosmos.ru ... http://en.roscosmos.ru/20892/
