Eurocontrol ETFMS failure
Yavapai
Messaggio da Yavapai »
Ciao, Eurocontrol sta cercando di risolvere una grana accaduta oggi all'ETFMS (Enhanced Tactical Flow Management System), ossia il sistema che gestisce le assegnazioni degli slot; questo ha causato una riduzione della capacità di flusso del 10%: pare che il problema software sia risolto ma la piena efficienza del sistema rientrerà nella norma solo domani:
Qui dettagli ufficiali di Eurocontrol:
https://www.eurocontrol.int/press-relea ... edures-are
M.C.
FAA Aircraft Dispatcher
Yavapai
Re: Eurocontrol ETFMS failure
Aggiornamento ..........
MESSAGE FROM DIRECTOR NETWORK MANAGER
EUROCONTROL very much regrets the disruption that has been caused to passengers and airlines due to today’s outage of the Enhanced Tactical Flow Management System (ETFMS).
The contingency procedures put in place ensured that safety was not compromised at any time.
As of 18.00 UTC, following the resumption of the ETFMS, the EUROCONTROL Network Manager has restarted normal flow management operations. This has been done after extensive internal testing and in coordination with airports, airlines and air traffic control across Europe and beyond.
In over 20 years of operation, the ETFMS has only had one other outage which occurred in 2001. The system currently manages up to 36,000 flights a day.
NMOC Brussels
M.C.
