British Airways rejected takeoff due to engine fire
dave91
Messaggio da dave91 »
sidew
Re: British Airways rejected takeoff due to engine fire
Messaggio da sidew »
Fonte: avherald.com
Aldo
Proseguendo anche qui la discussione (ve ne è una già attiva in generiche, come al solito, questa rimane in area tecnica e quindi rispondente al regolamento d'area), riporto l'aggiornamento apparso oggi su avherald:
"On Sep 10th 2015 the NTSB reported first preliminary findings. The NTSB reported that there were multiple breaches of the engine case in the area of the high pressure compressor, several pieces of the high pressure compressor spool were found on the runway. The engine, engine pylon, fuselage structure and the inboard left wing were substantially damaged by fire. A number of occupants received minor injuries, mainly abrasions, in the evacuation. Cockpit Voice, Flight Data and Quick Access recorders have been taken to the NTSB Laboratory and are being downloaded." (http://www.avherald.com)
Oggi NTSB ha emesso un aggiornamento sull'evento in questione:
http://www.ntsb.gov/news/press-releases ... 51006.aspx
"Engine examination revealed that a portion of the stage 8-10 spool in the high-pressure compressor (HPC) section had failed, liberating fragments that breached the engine case and cowling. Additional pieces of the HPC spool were recovered from inside the engine and retained for metallurgical examination.
The NTSB Materials Laboratory examined engine parts gathered from the scene.
HPC parts recovered during the disassembly of the engine were examined at the GE facility.
All pieces of the damaged stage 8 disk rim have been collected.
The fracture initiated in the HPC stage 8 disk web, a part of the stage 8-10 spool. The NTSB will continue metallurgical evaluations of the disk and the fracture features.
GE is performing high-priority, focused inspections of HPC hardware from other GE90 engines. The inspection data is being gathered to support the investigation and to determine further investigative actions".
RIlasciati da NTSB alcuni documenti relativi a questo evento, consultabili qui:
https://dms.ntsb.gov/pubdms/search/hitl ... 98A1503249
Riassunti anche su Avherald (http://avherald.com/h?article=48c10434)
"On Apr 12th 2017 the NTSB opened their public docket. The documents available suggest that the crew reacted within one second after the left hand engine's N2 dropped from stable 113% to 98% with increasing fuel flow. The #1 engine fuel cut off lever was moved to off within one second, the right hand engine's thrust lever was brought to idle at the same time. 6 seconds after the N2 dropped the engine fire warning became active followed by a engine #1 overheat warning. The aircraft came to stop, the crew radioed their were stopping and initiated the engine fire checklist. The crew announced to the passengers to remain seated. 26 seconds after the captain called "STOP" the crew radioed Mayday and requested fire services. Smoke was observed on board of the aircraft, however, it was believed for some time the fire had gone out. 150 seconds after N2 dropped the captain instructed the cabin to evacuate right hand side, 4 seconds later the crew informed ATC about the evacuation. 192 seconds after N2 dropped a forward cargo smoke warning became active. The crew discussed engine shut down checklists and evacuation checklists and read the evacuation checklist (until end of CVR recording).
The powerplant group reported in their chairman's report:
The pieces of the high pressure compressor recovered on site were first sent to the NTSB material laboratory for initial metallurgical examination. The received pieces accounted for less than 50% of the stage 8 outer rim. One of the recovered pieces with the dovetail slot and forward seal teeth still attached exhibited a hemi-elliptical shaped flat-fracture region that initiated in fatigue on the aft face of the web and transitioned circumferentially in both directions. A field emission scanning electron microscope was used to examine the surface in greater detail and the fracture region revealed an intergranular appearance near the initiation site and striations in the transgranular region of the fracture where striation density measurements could be taken to estimate the number of flight cycles from initiation/detection to failure. The NTSB materials laboratory estimated the number of flight cycles from detection to separation to be approximately 5,400 cycles. The last inspection of the event high pressure compressor spool was conducted by GE Wales 3,943 cycles prior to the failure.
After the initial examination of the high pressure compressor stage 8 pieces by the NTSB materials laboratory, they were sent to the GE Aviation Material Laboratory for further evaluation along with the stage 8 disk that was removed during the engine disassembly. Over several weeks, persons from the NTSB and FAA participated and oversaw much of the additional examination and testing. With all the recovered parts of the high pressure compressor stage 8 disk put together, it appeared that the entire disk rim and web was accounted for. GE’s analysis of the stage 8 disk concluded: 1) the crack initiation propagated with intergranular features with local variations consistent with hold-time, high-alternating stress, low cycle fatigue (hold-time low cycle/sustained-peak, low cycle) consistent with the NTSB finding, 2) no microstructural anomalies or detrimental species in the grain boundaries were found near the fracture origin, 3) the material composition, hardness, and grain structure were as specified, 4) multiple secondary cracks were found, but only within 0.016 inches radially of the fatigue region, 5) just like the primary fracture, no microstructural anomalies were found at the secondary crack locations, and 6) the shot peening appearance on the forward web face had more pronounced peening dimples than the web aft face. GE also performed their own striation density calculation and they estimated the number of flight cycles from detection to separation to be between approximately 5,000 – 5,700 cycles, consistent with the NTSB finding.
In order to better understand how the crack could have initiated in the web of the stage 8 disk, GE performed a series of additional hardware testing (for example residual stress and strain distortion), computational analysis (reevaluated the LCF lifing based on the actual event hardware, including all the material review board accepted allowable deviations and under the worst material property conditions) and operation mission profile review (verify stresses during taxing time, takeoff thrust rating, shutdown, core speeds and temperatures, ambient takeoff temperature, etc.). All the predictive calculations that GE performed could not close on the event crack location at the number of cycles it was thought to have initiated the crack; however, the striation density curves that were developed for the event spool match well with the analytical predictive crack propagation rate.
Based on this event, GE developed and incorporated into the engine maintenance manual a set of unique non-destructive inspections for the HPC stage 8-10 spool focusing on the event crack location. These inspections can be performed at the piece part, rotor and module levels, as well as on-wing. Along with the addition of the engine manual non-destructive inspections, GE released three separate service bulletins (SB 72-1145, SB 72-1146, and SB 72-1151) to inspect all the GE90 HPC stage 8-10 spools with part number 1694M80G04 (failure event spool part number) and a selected number of spools part numbers 1844M90G01 & G02. The Federal Aviation Administration mandated those inspections by issuing airworthiness directives AD 2015-27-01 and AD 2016-13-05".
Rilasciato il Final Report da parte di NTSB:
https://www.ntsb.gov/news/press-release ... 80620.aspx
In fondo alla news release di NTSB sopra linkata, c'è il link per accedere al Final Report completo.
"Probable Cause and Findings
The failure of the left engine high-pressure compressor (HPC) stage 8-10 spool, which caused the main fuel supply line to become detached from the engine main fuel pump and release fuel, resulting in a fire on the left side of the airplane. The HPC stage 8-10 spool failed due to a sustained-peak low-cycle fatigue crack that initiated in the web of the stage 8 disk; the cause of the crack initiation could not be identified by physical inspection and stress and lifing analysis. Contributing to this accident was the lack of inspection procedures for the stage 8 disk web
Riguardo l'evacuazione, vi sono state delle problematiche:
"The captain commanded the evacuation (step three in the evacuation checklist) before calling for the evacuation checklist and performing the first two steps in the checklist. Step two of the evacuation checklist instructs the captain to shut down both engines. The left engine was shut down as part of the engine fire checklist, but the right engine continued operating for about 43 seconds after the captain's evacuation command. The unusual attitude of two slides (the 3R and 4R slides) resulted from the jet blast coming from the right engine while it was operating.
The captain did not use the QRH to read and do his evacuation checklist items. The right engine was shut down after the relief pilot noticed EICAS indications showing that the engine was still running. Also, the captain's call for the evacuation checklist occurred after the relief pilot stated that the checklist needed to be performed. (The first officer had stated, just before the relief pilot, "we haven't done the engine checklist," but he most likely meant the evacuation checklist.) Because the captain did not follow standard procedures, his call for the evacuation checklist and the shutdown of the right engine were delayed
Riassunto anche su AvHerald:
http://avherald.com/h?article=48c10434&opt=0
