Verso un nuovo U-2 .....
richelieu
Messaggio da richelieu »
Gli 'Skunk Works' sono di nuovo all' opera .....
..... stanno progettando un successore stealth del leggendario U-2 .....
Lockheed Martin Skunk Works is designing a next-generation high-altitude, long-endurance (HALE) surveillance airplane, known internally as RQ-X or UQ-2, as an optionally-manned successor to the U-2 and Northrop Grumman RQ-4 Global Hawk.
U-2 programme officials told reporters at the Skunk Works headquarters in Palmdale, California, that its engineers have been mulling designs for stealthy HALE platform that would combine the best of the U-2 and its unmanned rival, the Global Hawk.
The advanced research and development arm of Lockheed is essentially pursuing an improved version of the U-2, which is powered by the same General Electric F118 engine and optimised to fly at 70,000ft or higher.
It would carry many of the same sensors, since those are already calibrated for use at that altitude.
The biggest difference will be the aircraft’s low-observable characteristics.
Fonte ..... "Lockheed Skunk Works designing next-gen U-2 spy plane" .....
http://www.flightglobal.com/news/articl ... ne-415842/
Guren
Re: Verso un nuovo U-2 .....
Messaggio da Guren »
come cambiano i tempi... non troppi anni fa l'avrebbero pubblicizzato almeno un decennio dopo il primo volo
Ciao, Marco
_____________________________
In tutta la sua vita,
giragyro
Messaggio da giragyro »
stesso motore , sebbene aggiornato , stessa tangenza massima ...mah .
richelieu
giragyro ha scritto:stesso motore, sebbene aggiornato, stessa tangenza massima ... mah .
Però ..... a quanto dicono ..... sarà ..... stealth ..... 8)
Riguardo al motore ed alla tangenza massima .....
To reduce development costs the design also utilizes the same General Electric F118 turbofan which was used to re-engine the U-2/TR-1 fleet in the mid-1990s.
“It’s a very good engine and it’s relatively new. We would look at using the same engine because of the cost but, on the other hand, if they say [the altitude requirement was] 90,000 ft. then that means a new engine. We would then go back and see what is out there and that may mean redesigning something,” says Winstead.
Fonte ..... "Skunk Works Studies Stealthy U-2 Replacement" .....
http://aviationweek.com/defense/skunk-w ... eplacement
richelieu
Guren ha scritto:come cambiano i tempi ... non troppi anni fa l'avrebbero pubblicizzato almeno un decennio dopo il primo volo
Dal 1°Agosto 1955 (data del primo volo) al 1°Maggio 1960 (data della forzata pubblicizzazione a livello internazionale dell' aereo) trascorsero, in effetti, meno di dieci anni ..... ma, già dal 1956, circolavano informazioni sul suo conto .....
http://www.flightglobal.com/FlightPDFAr ... 200602.PDF
http://www.flightglobal.com/FlightPDFAr ... 200661.PDF
http://www.flightglobal.com/FlightPDFAr ... 200859.PDF
http://www.flightglobal.com/FlightPDFAr ... 201647.PDF
Ultima modifica di richelieu il 19 agosto 2015, 14:28, modificato 1 volta in totale.
giragyro
non comprendo molto l'utilizzo " dual " sia manned che in modalità drone . in fin dei conti hanno già il global hawk , potrebbero utilizzarlo per farne una base di partenza per un ulteriore ampliamento delle specifiche senza tirarsi in ballo la complicazione di metterci dentro un pilota .
Vultur
Messaggio da Vultur »
Un pilota a bordo potrebbe anche impedire che un hacker prenda il comando del drone.
giragyro
bah , mi sembra deboluccia come tesi , sopratutto in un mondo occidentale dove da 20 anni ed oltre sono stati abbandonati gli studi sulla protezione dei circuiti elettronici . nello specifico sugli effetti di un impulso em , cosa che invece nell'ex blocco continuano a perfezionare ( non solo em ma anche " durezza " ad intrusioni non volute )
richelieu
E già che si parla di U-2 .....
..... un articolo di AW&ST (uno degli ormai pochi che vengono pubblicati non criptati) rivela alcune particolarità sui voli di lunga durata ad alta quota e su quale sia il pasto che i piloti consumano nel corso di tali interminabili missioni .....
"What Do Spy Plane Pilots Eat?" ..... http://aviationweek.com/blog/what-do-sp ... pilots-eat
Polenta with Cheese and Bacon’ ..... :eeeeek:
richelieu
In forma dubitativa .....
I got the impression from Winstead that, while Skunk Works definitely has done substantial design work for this aircraft — RQ-X? — this is in the we-could-do-it-if-they-ask-us-to box.
He told me there is no requirement for it nor has there been great interest expressed by the Air Force.
Should the Air Force decide it does need this new plane, Skunk Works could deliver it quickly IF the requirement is clear and does not change, Austin told us.
Fonte ..... "Will Lockheed Build A Stealthy U-2 Successor?" .....
http://breakingdefense.com/2015/08/will ... successor/
richelieu
Il nuovo U-2 ..... evoluzione di un progetto .....
Lockheed Martin Skunk Works’ proposal for a next-generation, optionally-manned U-2 surveillance aircraft has morphed into more of a tactical reconnaissance aircraft dubbed “TR-X”.
The designation is both a throwback to the U-2’s TR-1 designation in the 1980s but also symbolises a change in thinking that could drive the design to be more of an affordable peace and wartime intelligence, surveillance and reconnaissance (ISR) workhorse than a strategic, penetrating platform – like the supersonic Lockheed SR-71 Blackbird.
Fonte ..... " Lockheed Skunk Works' next-generation U-2 morphs into 'TR-X' " .....
https://www.flightglobal.com/news/artic ... nt-416709/
Inoltre ..... dal 'Daily Report' dell' AFA .....
Lockheed Promotes TR-X U-2 Replacement .....
John A. Tirpak (09/15/2015)
​Lockheed Martin is preparing an unsolicited offer to the Air Force for a “TR-X” replacement for the U-2, and could have something flying by 2025 if given the go-ahead.
Scott Winstead, company U-2 strategic business manager, said at a press briefing during ASC​15 that the aircraft would be a cost-effective way to continue the “complementary” role of the U-2 with the RQ-4 Global Hawk because it could re-use the U-2S General Electric F414 engines, which have a lot of life left in them, as well as many of the U-2’s unique sensors and reconnaissance systems.
What would be new, he said, is an airframe that would be stealthy enough to survive in heavily defended airspace.
As it stands, the U-2S has enough structural life to serve until 2045, he said, but conditions will change long before then, requiring more survivability.
The notional TR-X could also perform electronic warfare, communications node, and even laser attack missions.
Winstead said a fleet of 25-30 airplanes would be sufficient to take over the duties now performed by 18 U-2s and 25 Global Hawks.
The design would change, however, if the Air Force wants an aircraft able to fly at 90,000 feet.
That, Winstead said, “would require new engines.”
The notional design would have a longer airframe and somewhat larger wings and elevators than the U-2; it could be optionally manned, but more likely unmanned if USAF wants endurance of longer than 20-22 hours.
The U-2S limit today - driven by the endurance of the pilot - is about 14 hours.
Asked about prospects for a sale - given that the U-2 has been terminated and resurrected several times - Winstead said “the design will have to sell itself.”
The notional name, TR-X, harkens back to when the U-2 was called the TR-1, and had a distinctly tactical mission.
Lockheed sees a similar role for the jet in the future, Winstead noted.
richelieu
'Un nuovo U-2? Vedremo' ..... così parlò il generale Otto .....
New U-2? We'll See .....
Arie Church (10/02/2015)
Intelligence, surveillance, and reconnaissance boss Lt. Gen. Bob Otto .....
http://www.af.mil/AboutUs/Biographies/D ... -otto.aspx
said he hasn't discussed Lockheed Martin's proposed U-2 follow-on platform with the company but he is enthusiastic that industry is putting forward ideas.
"I think it's exciting that industry is coming up with ideas on how we can modernize, so I want to encourage that, my hat's off to Lockheed," Otto said, speaking at a roundtable in Washington, D.C., Oct. 1.
The next generation airborne ISR platform needs to be capable of penetrating anti-access, area-denial defenses, meaning "we're going to have to have some low-observable characteristics" as a given, said Otto.
Lockheed Martin's notional TR-X incorporates low observable elements with an optionally-manned capability anticipating high-end requirements.
"We want to improve upon things that we've seen with the Global Hawk - certainly we want the ability for it to be all-weather" and equipped with "exquisite sensors" that would allow stand-off as well as close-in ISR, Otto added.
"The question that I would have is 'what gap would it fill that is not currently being filled?'"
The company anticipates TR-X replacing the U-2 and Global Hawk fleets by roughly 2025, though Otto said both aircraft could last "much longer" if needed.
"So, what would cause us to do the upgrade? We'd have to see," said Otto.
Fonte ..... il 'Daily Report' dell' AFA .....
richelieu
LM elenca i 10 principali motivi ..... http://www.lockheedmartin.com/us/news/f ... op-10.html
Vultur
Io 12 ore seduto a fare da bersaglio non ci starei.
giragyro
Vultur ha scritto:Io 12 ore seduto a fare da bersaglio non ci starei.
e ti perderesti l'esaltante possibilità di correre a 100 Mph su un'auto in meniera legale ? per non parlare del privilegio di nutrirti con cibo spaziale ? .... :D :D
Vultur
Mi piacerebbe stare lassù per vedere la curvatura terrestre, ma quando si fa sul serio è solo un aereo che vola molto in alto e che ogni pilota da caccia sono convinto non vede l'ora di poter dire di essere riuscito a tirare giù.
Anche in tempo di pace, un "incidente" può succedere sempre. Non è sicuro, ma addirittura a Gary Powers avrebbero provato a speronarlo con un Su-9 che si trovava lì ed essendo disarmato avrebbe provato ad andargli addosso in arrampicata. E l'U-2 non mi sembra un grande acrobata, che può spostarsi in tempo (ammesso che si vede se uno ti viene addosso, il che non credo).
https://en.wikipedia.org/wiki/Sukhoi_Su-9
richelieu
Vultur ha scritto: Non è sicuro, ma addirittura a Gary Powers avrebbero provato a speronarlo con un Su-9 che si trovava lì ed essendo disarmato avrebbe provato ad andargli addosso in arrampicata.
Il pilota del 'Fishpot' si chiamava Igor Mentyukov e ricevette, tramite la catena di comando, l' ordine di speronare l' U-2 dal capo della Difesa Aerea sovietica (PVO) Yevgeny Savitsky (in codice 'Dragon').
L' episodio è stato raccontato in dettaglio da Sergei N. Chruščëv (figlio dell' ex premier dell' Unione Sovietica Nikita S. Chruščëv) nel volume di memorie "Nikita Khrushchev and the Creation of a Superpower" (The Pennsylvania State University Press - 2000) .....
..... e da Chris Pocock nel suo "The U-2 Spyplane: Toward the Unknown - A New History of the Early Years" (Schiffer Publishing Ltd. - 2000) .....
sidew
Messaggio da sidew »
A proposito di U2...
phpBB [video]
Aldo
giragyro
un grosso motoveleggiatore :-)
certo che dopo una decina di ore di missione chiusi nella tuta pressurizzata ( e se prude il naso ? ) ed incastrati nell'abitacolo mettersi a lottare in atterraggio con venti e turbolenze deve essere proprio uno spasso ...
Vultur
Non penso lo facciano atterrare dove c'è troppo vento.
Io però non capisco tanto: di aerei con il carrello così (i russi lo chiamano "a bicicletta", forse pure gli americani, dicono che è molto "dolce" come decolli e atterraggi) ce ne sono, ma solo l'U2 viene seguito da una macchina? Forse perchè in pratica l'U-2 ha una sola vera gamba principale?
anonymous12345
Messaggio da anonymous12345 »
Viene seguito anche per aiutare il pilota che non ha molta visibilità con la tuta spaziale ..
sidew
Esatto... con i caschi pressurizzati, non hanno molta visibilità laterale e per questo non hanno possibilità di valutare a occhio la altezza rispetto al suolo.
Aldo
Vultur
Ma l'altezza la valutano a occhio?
E poi i caschi stratosferici li usa parecchia gente.
sidew
Aldo
anonymous12345
Vultur ha scritto:Ma l'altezza la valutano a occhio?
Son una serie di motivi. ..
La tuta di volo che limita i movimenti, il carrello monotraccia, le ali lunghissime, la conformazione dell'abitacolo, il comportamento in atterraggio... ecc...
giragyro
non ricordo dove l'ho letto , ma una delle difficoltà principali dell'atterraggio è il regime minimo del motore molto alto rispetto ad un motore similare ma montato su aerei con tangenze massime ben inferiori , tanto alto da avere comunque un effetto propulsivo sull'aereo ( in poche parole in idle il motore ha spinta a sufficienza per tenere in aria l'aereo bel al di sopra della velocità di stallo )
spiridione
Messaggio da spiridione »
Si, l' ho letto anche io....
In sostanza, si sosteneva che l'U2 non volesse mai atterrare.... :mrgreen:
Vultur ha scritto: E poi i caschi stratosferici li usa parecchia gente.
Ah anch'io spesso, l'ultima volta - intento a cambiare lo scaldabagno - stavo dimenticandomi di toglierlo.
richelieu
Valerio Ricciardi ha scritto:
Vultur ha scritto:E poi i caschi stratosferici li usa parecchia gente.
Grande ! :shock:
Io, solitamente, uso questo ..... :mrgreen:
sidew
phpBB [video]
Aldo
richelieu
TR-X ..... si torna a parlare del possibile successore dello U-2 .....
Lockheed Martin’s plan to construct a fleet of 30 high-altitude, single-engined tactical reconnaissance aircraft from cannibalised U-2S Dragon Lady and RQ-4B Global Hawk components would take 10 years and cost approximately $3.8 billion if adopted, a company official says.
Called TR-X, the programme would furnish low-observable airframes – powered by the U-2’s GE Aviation F118 non-afterburning turbofan engine – with sensor suites and antennas from the manned Lockheed U-2 and remotely piloted Northrop Grumman RQ-4B.
Fonte ..... Lockheed's 30-aircraft TR-X plan priced at $3.8 billion
richelieu
TR-X ..... ora diventa un programma Immagine NERO .....
Lockheed Martin will formally pitch the Air Force a program to replace the U-2 and Global Hawk in the coming months, Scott Winstead, the company’s strategic business manager, told reporters Tuesday.
The aircraft will have low-observable, or stealth features, so previous images of what Lockheed calls the TR-X are obsolete, and the company won’t release new ones, he said.
Fonte ..... TR-X Goes Black
richelieu
Da 'AINonline' ..... qualche ulteriore dettaglio sul possibile successore .....
"Lockheed Martin Shares More Insight, But No Images of TR-X"
richelieu
Nella fiduciosa attesa dell' arrivo (chissà quando) del successore di Dragon Lady ..... hanno ormai raggiunto quota 1000 i piloti che hanno volato sul longevo velivolo .....
​A USAF airman became the 1,000th pilot to fly the the 61-year-old U-2 Dragon Lady last month.
The 1st Reconnaissance Squadron student pilot completed the solo flight at Beale AFB, Calif., on Aug. 31, according to a 9th Reconnaissance Wing release.
Fonte ..... "1,000th Pilot Flies the Dragon Lady" .....
richelieu
Incidente ..... :(
One pilot was killed and another injured after ejecting from a Lockheed Martin TU-2S Dragon Lady training aircraft in California on 20 September, the US Air Force confirms.
An unconfirmed mobile phone video showed the TU-2S descending to the ground while two parachutes opened.
The incident occurred near Sutter Buttes, a geologic formation near a U-2S unit’s base at Beale AFB, California.
Fonte ..... "TU-2S crash kills one pilot, injures another" .....
Dal Daily Report dell' AFA ..... "One Pilot Killed, One Injured in California U-2 Crash" .....
