http://www.avherald.com/h?article=46b36b7c&opt=0
Vi faro' sapere qualcosa in piu' se riesco.
Ryanair, odour on board
ghiga
Re: Ryanair, odour on board
C'é qualche notizia in piú al riguardo ?
Sembra semplicemente una sfortunata coincidenza e un semplice problema nel sistema dell'aria condizionata. Mi sembra l'equipaggio si sia comportato egregiamente!
Al momento sono in ferie, non appena rientro (se rientro) chiedo un po' in giro.
- sidew
Leggendo il titolo "odour on board" mi faceva venire in mente a un farting colettivo a bordo...
Al momento sembra un problema al sistema air conditioning, secondo quanto riporta AvHerald:
"Maintenance determined an air conditioning fault causing a pipe to blow dust and/or debris into the cabin.
The airline reported a passenger reported fumes in the cabin, the crew alerted the fire services in Seville, who were on standby for the arrival of the aircraft, that landed normally. The passengers were taken to a replacement aircraft which continued towards Dusseldorf's Niederrhein (Weeze) Airport. Engineers inspected the aircraft and found a fault in the air conditioning system, the relevant safety agencies in Spain and Ireland have been advised.
On Nov 14th 2013 Spain's CIAIAC reported that cabin crew reported dense white smoke with no odour while climbing through 8000 feet out of Tangier. The flight crew stopped the climb and diverted to Seville, the aircraft vacated the runway and stopped on the taxiways, doors were opened and passengers disembarked normally. An investigation has been opened"
(http://www.avherald.com/h?article=46b36b7c&opt=0)
