L'Aia
Vangelis
L'Aia
Buonasera a tutti. purtroppo devo volare ancora. fino a poche settimane fa c'era un volo diretto Bari - Lussemburgo che sarebbe stato l'ideale. ora sembra partire solo da Roma. a parte questo quale altra soluzione potrei considerare per arrivare in zona?
- **F@b!0**
Re: L'Aia
ma devi andare a l'Aia o in Lussemburgo?
no, perchè l'Aia è in Olanda, e il Lussemburgo manco ci confina con l'Olanda!
Non bat dinare a pacare
una vida pro miserat chi siat
s' omine
no er de imbolare
pro una gherra chi
est' unu affare
*Virtute Siderum Tenus*
s' omine
no er de imbolare
pro una gherra chi
est' unu affare
- sidew
Re: L'Aia
Non ti conviene andare a Schilpol, e da li prendere il treno o pullman che fanno spola tra aeroporto e L'Aia (Den Haag o The Hague)?
http://www.lawofthefuture.org/223/
Schiphol Airport is located next to Amsterdam but is also quite close to The Hague (only 45 km). The easiest way to arrive from Schiphol Airport to The Hague is by public transportation, namely by train, which is simple, inexpensive and efficient.
Travel by train from Schiphol Airport to The Hague
Trains from Schiphol Airport to The Hague Central Station depart right below the arrivals terminal, normally from tracks 5 and 6, approximately every 15 minutes. Note that tickets must be purchased before you board the train (there are booths and automatic machines in the main hall before you go down to the train platforms). A 2nd class, one way ticket between Schiphol and The Hague Central Station will cost €7,40. The journey time is approximately 35 minutes.
Travel by taxi from Schiphol Airport directly to The Hague
Taxis are reliable and widely available at the airport outside the arrivals terminal. Depending on traffic, it will take anywhere between 45 and 75 minutes to get from Schiphol Airport to The Hague Central Station. Prices vary according to your journey time, but expect to pay at least €100,-.
