Il vento forte solleva un aereo
Burb
Messaggio da Burb »
Now we're REALLY taking off! Unbelievable video shows strong winds lifting a parked jumbo jet into the air
If you're already afraid of flying, don't watch this.
Unbelievable footage has captured the moment extreme wind conditions lift a jumbo jet well into the air at a California boneyard.
The video, taken on Wednesday and posted on YouTube, shows the incredible result when winds reaching over 70 miles per hour come into contact with a heavy airplane, sitting stationary.
Normally during takeoff, an airplane flies into the wind, and air movement over the wings lifts the aircraft up into the sky.
But the video shows how a plane can still be lifted up when standing still, if the wind is strong enough.
The nose of the Southern Air jet, parked at the yard in Mojave, outside of Los Angeles, is lifted metres off the ground as the 747s wings generate enough movement to actually pick the fuselage.
The wind sees the plane bounce around while the back wheels stay in place.
The next day the plane was found to have rotated about 45 degrees from its original position.
The same wind storm damaged many rooftops, cut power and sent huge clouds of sand and dust billowing into the sky.
According to Gadling.com, the Southern Air 747 shown in the footage is scheduled to be scrapped, so the engines and much of the interior had been stripped off the plane's frame.
It was because of this reduced weight that the airplane was able to effectively take off. So don't worry, it is unlikely to happen on your next flight.
http://www.dailymail.co.uk/news/article ... l?ITO=1490
Video:
RaganellaImpazzita
Re: Il vento forte solleva un aereo
Messaggio da RaganellaImpazzita »
:shock:
Quell'aereo è un bel po' alleggerito in ogni caso...
Lelefanton
Messaggio da Lelefanton »
Il vento ha fatto volare un aereo :lol:
albert
Messaggio da albert »
Lelefanton ha scritto:Il vento ha fatto volare un aereo :lol:
non succede migliaia di volte al giorno? :mrgreen:
anonymous12345
Messaggio da anonymous12345 »
Dimostrazione che gli aerei hanno cuore e anima..
tarpagli le ali ma cercheranno sempre di tornare a casa ( per aria) :oops: :mrgreen: :mrgreen:
Messaggio da tartan »
Per tutti gli aerei, in genere, esiste un limite posteriore di escursione del baricentro che non deve essere superato altrimenti l'aereo si siede. Per questo motivo in alcune macchine esiste una specifica procedura di imbarco merci e passeggeri per evitare l'inconveniente. In alcuni casi è richiesta l'applicazione di un puntone in coda.
Quel 747 molto probabilmente aveva il baricentro molto arretrato, prossimo ai limiti di caricamento e quindi il vento sostenuto può aver facilitato lo spostamento. Il movimento continuo può derivare dal vento a raffiche.
Niente di trascendentale.
Non avevo letto il testo quando ho scritto il mio commento. Leggendo bene ho notato che mancano i motori e che il fenomeno viene attribuito all'alleggerimento dell'aereo. E' da considerare che l'eliminazione dei motori ha spostato indietro il baricentro confermando i presupposti di cui sopra.
Ultima modifica di tartan il 27 maggio 2012, 9:56, modificato 1 volta in totale.
ciccioxx92
Messaggio da ciccioxx92 »
AirGek ha scritto:Quell'aereo è un bel po' alleggerito in ogni caso...
Non c'ha manco i motori... :roll:
gattovolante
Messaggio da gattovolante »
Ma dai che è uno dei nuovi simulatori del 747 :mrgreen:
bigshot
Messaggio da bigshot »
Tra l'altro anche quello dietro ondeggia bene... (mi pare un dc-10/md-11 dalla forma del carrello anteriore e del cockpit, ma potrei toppare).
Tra l'altro con i Krueger e gli slat aperti e lo stabilizzatore leggermente trimmato a cabrare mi sa che era difficile aspettarsi altro da quell'aereo (e forse l'hanno fatto pure apposta per sfizio, tanto è da demolire :mrgreen: )
b747-8
Messaggio da b747-8 »
bigshot ha scritto:Tra l'altro anche quello dietro ondeggia bene... (mi pare un dc-10/md-11 dalla forma del carrello anteriore e del cockpit, ma potrei toppare).
Praticamente avete fatto tutte le osservazioni che stavo facendo io...però è un bello spettacolo! Peccato che vogliano demolirlo... :(
BIRRA POINT
Ministro rapporti CULturali
gattovolante ha scritto:Ma dai che è uno dei nuovi simulatori del 747 :mrgreen:
:lol: Meglio di cosi non si può! :mrgreen:
MatteF88
Messaggio da MatteF88 »
il video è vecchio (2011), non so se sia già stato postato (usando "cerca" non l'ho trovato), in caso contrario: pazienza.. :mrgreen:
sardinian aviator
Un evento del genere capitò a Elmas molti anni fa ad un F28 dell'Itavia durante una notte di burrasca.
hawk-eyed
Messaggio da hawk-eyed »
sardinian aviator ha scritto:Un evento del genere capitò a Elmas molti anni fa ad un F28 dell'Itavia durante una notte di burrasca.
cioè, ad un "Fokker" 28? :shock:
sardinian aviator
Si a uno di questi, perché cosa ho detto di strano?
hawk-eyed
e chi ha detto che io ho detto che tu hai detto qualcosa di strano??? :lol:
Ultima modifica di hawk-eyed il 22 ottobre 2013, 20:12, modificato 1 volta in totale.
sardinian aviator
e chi ha detto che io ho detto che tu hai detto di strano??? :lol:
Ma se mi metti la faccina con gli occhi stralunati e con scritto shock che devo pensare? :D
hawk-eyed
solo credevo che sarei riuscito a trsmettere un po' di stupore, nient'altro... :shock: :shock:
Giuseppe Cei
Messaggio da Giuseppe Cei »
Da ignorante grezzo spalanco gli occhi alla "leggerezza" di un bestione pesantissimo.
Quando si dice l'aerodinamica......
