Sofia: A320 fuoco in cabina
a_ndrea
Messaggio da a_ndrea »
Incident: OLT Express A320 near Sofia on May 17th 2012, loss of cabin pressure, fire in cabin
By Simon Hradecky, created Thursday, May 17th 2012 13:00Z, last updated Thursday, May 17th 2012 15:23Z
An OLT Express Airbus A320-200, registration SP-IAE performing flight YAP-7107 from Warsaw (Poland) to Hurghada (Egypt) with 147 passengers and 8 crew, was enroute at FL370 about 60nm northnortheast of Sofia (Bulgaria) when the crew reported the loss of cabin pressure, initiated an emergency descent and decided to divert to Sofia. During the descent the crew reported a fire in the cabin, cabin crew attempted to extinguish the fire with fire extinguishers, after checking in with Sofia Tower the crew repeated they had a fire in the cabin. The aircraft landed safely on runway 27 about 13 minutes after leaving FL370 and stopped on the runway. The aircraft was evacuated via slides. No injuries occurred.
The airport was closed for about one hour.
Emergency services found soot on one of the passenger oxygen masks, which had deployed during the descent towards Sofia.
The airline reported the aircraft diverted to Sofia due to the loss of cabin pressure, one of the (chemical) oxygen generators feeding the passenger oxygen masks produced sparks and visible flames causing the carpet to catch fire, the fire was quickly extinguished by cabin crew. After evacuation the passengers were taken to the terminal and provided with assistance, a replacement Air Via aircraft is going to continue the flight at 19:30L (16:30Z).
http://avherald.com/h?article=44fafe93&opt=0
Che un dispositivo di sicurezza, come quello dell'ossigeno, abbia problemi di scintille mi prplime un po': a sensazione (mia) non dovrebbe essere tra quelli soggetti a manutenzione/ispezione piu' frequente?
MarcoGT
Software Integration Engineer
Messaggio da MarcoGT »
Certo, ma i problemi possono comunque insorgere
Re: Sofia: A320 fuoco in cabina
Il generatore di ossigeno per i passeggeri, quando attivato, genera anche un calore tremendo in fase iniziale di rilascio ossigeno.
Quello che e' successo e' che un passeggero, oltre a tirare la maschera verso se (come da istruzioni), ha tirato cosi violentemente da spaccare il pannello soprastante, con conseguente caduta del generatore (bollente) per terra, con conseguente scintille e incendio del tappeto.....
Il sistema funziona, ma non e' che devi appenderti a mo' di altalena per attivare il flusso di ossigeno....
willy73
Messaggio da willy73 »
SuperMau ha scritto: ha tirato cosi violentemente da spaccare il pannello soprastante,con conseguente caduta del generatore (bollente) per terra, con conseguente scintille e incendio del tappeto.....
:shock: Acc...! Pensa se gli cadeva sui gioielli di famiglia...! :confused3:
anonymous12345
Messaggio da anonymous12345 »
SuperMau ha scritto:Il generatore di ossigeno per i passeggeri, quando attivato, genera anche un calore tremendo in fase iniziale di rilascio ossigeno.
SuperMau quello che dici è giustissimo però, se permetti, mi sembra strano che tale apparecchiatura sia fissata così "alla leggera" da poter essere divelta tirando il tubetto di plastica dell'ossigeno.. anche perchè:
_è un dispositivo d'emergenza quindi, in teoria, viene utilizzato insituazioni di panico o quantomeno forte stress..
_è un dispositivo che per funzionare scalda parecchio ed è piazzato sopra i sedili, a rigor di logica dovrebbe esser ancorato saldamente.. non dico che ti ci devi poter appendere, ma almeno resistere più del tubetto no??
Roby,
verissimo...e difatti l'intera struttura e' ABBASTANZA solida, ma anche ancorata in modo da essere facilmente smontabile per la manutenzione.
Ora, non so cosa possa essere successo di preciso ma sono piu' propenso a una azione poco ortodossa da parte del passeggero, piu' che ad un errato fissaggio del pannello dopo una manutenzione...
Comunque, non e' il tubetto di plastica che aziona il dispositivo. In parallelo al tubetto sono fissati due cavetti che sono collegati ad uno spinotto di attivazione sul generatore. Sono i cavetti che hanno la resistenza necessaria per attivarlo, perche' come dici tu se tiri un po' troppo il tubetto di plastica questo ti resta in mano...
GUARDA CASO ho qui un pannellino di ricambio come esempio ... :mrgreen: :mrgreen: :mrgreen:
robygun82 ha scritto:SuperMau quello che dici è giustissimo però, se permetti, mi sembra strano che tale apparecchiatura sia fissata così "alla leggera" da poter essere divelta tirando il tubetto di plastica dell'ossigeno..
Infatti, come ti è già stato giustamente detto, non è il tubetto che aziona il generatore, ne avevamo parlato anche qui :wink: :
http://www.md80.it/bbforum/viewtopic.ph ... 42#p727842
anonymous12345
Ok.. quello che si tira è il cordino che sblocca il funzionamento del generatore d 'ossigeno..
però continua a sembrarmi un filo assurdo che tirando (anche troppo forte per carità) una cosa che ti dicon che devi tirare per farla funzionare (l'insieme mascherina-tubetto-cavo) rischi di trovarti il generatore bollente tra le mani...
è come se azionando la manigli del freno d'emergenza sul treno mi venisse in braccio l'intera cappelliera ..
