Free Apitude Test Online
Pier Giovanni
Messaggio da Pier Giovanni »
Ciao a tutti!!!
navigando ho trovato questo: "European Pilot Selection & Training" ... da la possibilità (gratuitamente) di effettuare un test della durata complessiva di circa 50' minuti....
http://www.nitex.nl/apst/
per non stare a speigare, faccio prima a fare un copia e incolla :mrgreen:
""Welcome to IPAS the Initial Pilot Aptitude Screening program. This program has been developed by APST Holding. The IPAS program is designed to offer men and woman interested in a career as a professional pilot a preliminary indication of their ability in five key pilot aptitude areas before they start their pilot training. After completing the IPAS program you will be given your scores for each of the five tests and guidance about interpreting the results. The equipment required for the tests is a PC, keyboard and mouse with modem and an open internet connection plus a Java enabled webbrowser. Total time to complete the tests is about 50 minutes.
There are five IPAS tests. These are:
1 "BallGame"; a hand / eye co-ordination test
2 "Total Recall"; a test of short term memory
3 "Math class"; a quick math test
4 "Wings And Things"; an orientation test
5 "Bingo"; a dual task management test
Please read all on screen instructions carefully as some of the tests are not intuitive. Before each test you will be given instructions and a short practice run.
ho provato a farlo, risultato: 2658
dopo il risultato non mi comunica altro...quindi non so se è un buon numero o meno...
a voi curiosi e appassionati i commenti e i risultati! :wink:
"E' meglio fare e pentirsi che pentirsi di non aver fatto.."
PPL
hawk-eyed
Re: Free Apitude Test Online
Messaggio da hawk-eyed »
grazie ! l'ho provato... ho raggiunto score 3027 . un teste unsatisfactory, due satisfactory, un good e un excellent... :lol:
tanto per cambiare devo indossare il cappello d'asino per quanto riguarda il math test... :oops:
bulldog89
Messaggio da bulldog89 »
4174
Satisfactory: 184
Good: 13
Good: 10
Excellent: 29
Good: 31
Abbastanza divertente, anche se un paio di domande mi sono partite in bianco grazie all'applet java e una di matematica dove sinceramente non ho ancora capito quale sia la risposta (o mi ricordo male le istruzioni per i decimali)
Pier Giovanni
anch'io ho avuto problemi con i decimali... sto cercado uno schema o qualcosa che possa dire a che livello corrisponde il punteggio ottenuto... :roll:
PPL
MarkAir
Messaggio da MarkAir »
Io ho fatto circa 4100, non mi ricordo più... :oops:
Per il problema con i decimali, i dati erano questi:
7 galloni ogni ora
1h e 30m di volo
atterrare con 2.6 galloni
le cose per me sono due:
1) andava arrotondato, e 13,1 si arrotonda per difetto a 13, però così si sarebbe atterrato con 2.5 galloni e non 2.6
2) andava arrotondato per eccesso (quindi 14), e quindi il testo intendeva che si dovevano avere ALMENO 2.6 galloni all'atterraggio
Che ne dite?
bulldog89
Sarei più orientato sulla seconda, ma secondo me abbiamo letto male le regole dei decimali
Io ho fatto 765445376658970989657456780908767549837498237439852389709237598437529837429038759837529837429380765445376658970989657456780765445376658970989676544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742938057456780908767549837498237439852389709237598437529837429038759837529837429380908767549837498237439852389707654453766589709896574567809087675498374982374398523897092375984375298374290387598375298374276544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742938093809237654453766589709896574567809087675498374982374398523897092375984375298374290376544576544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742938037665897098965745676544537667654453766589709896574567809087675498374982374398523897092375984375298374290387598375298374293807654453766589709896574567807654453766589709896765445376658970989657456780908767549837498237439852389709237598437529837429038759837529837429380574567809087675498374982374398523897092375765445376658970989657456780908767549837498237439852389709237598437529837429038759837529837429380765445376658970989657456780765445376658970989676544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742938057456780908767549837498237439852389709237598437529837429038759837529837429380908767549837498237439852389707654453766589709896574567809087675498374982374398523897092375984375298374290387598375298374276544537665897098965745678090876754983749823743985237654453766589709896574567809087675498374982374398523897092375984375298374290387598375298374293807654453766589709896574567807654453766589709896765445376658970989657456780908767549837498237439852389709237598437529837429038759837529837429380574567809087675498374982374398523897092375984375298374290387598375298374293809087675498374982374398523897076544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742765445376658970989657456780908767549837498237439852389709237598437529837429038759837529837429380938092376544537665897098965745678090876754983749823743985238970923759843752983742903765445765445376658970989657456780908767549837498237439852389709237598437529837429038759837529837429380376658970989657456765445376658970989657456780908767549837498237439852389709237598437529837429038759837529837429380780908767549837498237439852389709237598476544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742938037529837429038759837529837429380875983752983742938075984375765445376658970989676544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742938057456780908767549837498237439852389709237598437529837429038759837529837429380298374290387598375298374293808970923759843752983742903875983752983742938093809237654453766589709896574567809087675498374982374398523897092375984375298374290376544576544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742938037665897098965745676544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742938078090876754983749823743985238970923759847654453766589709896574567809087675498374982374398523897092375984375298374290387598375298374293803752983742903875983752983742938087598375298374293807598437576544537665897098967654453766589709896574567809087675498374982374398523897092375984375298374290387598375298374293805745678090876754983749823743985238970923759843752983742903875983752983742938029837429038759837529837429380984375298374290387598375298374293809087675498374982374398523897076544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742765445376658970989657456780908767549837498237439852389709237598437529837429038759837529837429380938092376544537665897098965745678090876754983749823743985238970923759843752983742903765445765445376658970989657456780908767549837498237439852389709237598437529837429038759837529837429380376658970989657456765445376658970989657456780908767549837498237439852389709237598437529837429038759837529837429380780908767549837498237439852389709237598476544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742938037529837429038759837529837429380875983752983742938075984375765445376658970989676544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742938057456780908767549837498237439852389709237598437529837429038759837529837429380298374290387598375298374293805897098965745678090876754983749823743985238970923759843752983742903875983752983742938078090876754983749823743985238970923759847654453766589709896574567809087675498374982374398523897092375984375298374290387598375298374293803752983742903875983752983742938087598375298374293807598437576544537665897098967654453766589709896574567809087675498374982374398523897092375984375298374290387598375298374293805745678090876754983749823743985238970923759843752983742903875983752983742938029837429038759837529837429380.
Dite che posso fare il pilota?
hawk-eyed
AirGek ha scritto:Io ho fatto 765445376658970989657456780908767549837498237439852389709237598437529837429038759837529837429380765445376658970989657456780765445376658970989676544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742938057456780908767549837498237439852389709237598437529837429038759837529837429380908767549837498237439852389707654453766589709896574567809087675498374982374398523897092375984375298374290387598375298374276544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742938093809237654453766589709896574567809087675498374982374398523897092375984375298374290376544576544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742938037665897098965745676544537667654453766589709896574567809087675498374982374398523897092375984375298374290387598375298374293807654453766589709896574567807654453766589709896765445376658970989657456780908767549837498237439852389709237598437529837429038759837529837429380574567809087675498374982374398523897092375765445376658970989657456780908767549837498237439852389709237598437529837429038759837529837429380765445376658970989657456780765445376658970989676544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742938057456780908767549837498237439852389709237598437529837429038759837529837429380908767549837498237439852389707654453766589709896574567809087675498374982374398523897092375984375298374290387598375298374276544537665897098965745678090876754983749823743985237654453766589709896574567809087675498374982374398523897092375984375298374290387598375298374293807654453766589709896574567807654453766589709896765445376658970989657456780908767549837498237439852389709237598437529837429038759837529837429380574567809087675498374982374398523897092375984375298374290387598375298374293809087675498374982374398523897076544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742765445376658970989657456780908767549837498237439852389709237598437529837429038759837529837429380938092376544537665897098965745678090876754983749823743985238970923759843752983742903765445765445376658970989657456780908767549837498237439852389709237598437529837429038759837529837429380376658970989657456765445376658970989657456780908767549837498237439852389709237598437529837429038759837529837429380780908767549837498237439852389709237598476544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742938037529837429038759837529837429380875983752983742938075984375765445376658970989676544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742938057456780908767549837498237439852389709237598437529837429038759837529837429380298374290387598375298374293808970923759843752983742903875983752983742938093809237654453766589709896574567809087675498374982374398523897092375984375298374290376544576544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742938037665897098965745676544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742938078090876754983749823743985238970923759847654453766589709896574567809087675498374982374398523897092375984375298374290387598375298374293803752983742903875983752983742938087598375298374293807598437576544537665897098967654453766589709896574567809087675498374982374398523897092375984375298374290387598375298374293805745678090876754983749823743985238970923759843752983742903875983752983742938029837429038759837529837429380984375298374290387598375298374293809087675498374982374398523897076544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742765445376658970989657456780908767549837498237439852389709237598437529837429038759837529837429380938092376544537665897098965745678090876754983749823743985238970923759843752983742903765445765445376658970989657456780908767549837498237439852389709237598437529837429038759837529837429380376658970989657456765445376658970989657456780908767549837498237439852389709237598437529837429038759837529837429380780908767549837498237439852389709237598476544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742938037529837429038759837529837429380875983752983742938075984375765445376658970989676544537665897098965745678090876754983749823743985238970923759843752983742903875983752983742938057456780908767549837498237439852389709237598437529837429038759837529837429380298374290387598375298374293805897098965745678090876754983749823743985238970923759843752983742903875983752983742938078090876754983749823743985238970923759847654453766589709896574567809087675498374982374398523897092375984375298374290387598375298374293803752983742903875983752983742938087598375298374293807598437576544537665897098967654453766589709896574567809087675498374982374398523897092375984375298374290387598375298374293805745678090876754983749823743985238970923759843752983742903875983752983742938029837429038759837529837429380.
min*** Gek ! vai a fare domanda alla NASA o ESA !! che score incredibile !... :lol:
Sammynumberone
Messaggio da Sammynumberone »
ma per entrare che programma java c'è bisogno????...sono tre giorni che cerco di entrare ma mi blocca sempre!!!-.-"
bulldog89
Prova con internet explorer, a me non funzionava con Firefox...
ardix
Messaggio da ardix »
Anche a me non andava con Firefox 11. Con IE 9 tutto ok.
Ho fatto circa 4500 comunque. Il risultato del primo test dipende anche da che mouse e a quale sensibilita' lo si sta utilizzando...
