Salve che differenza cè fra A340-600 ed A340-500???
						differenza Airbus
- MarcoGT
Re: differenza Airbus
Performance
Typical cruising speed Mach 0.83.
A340-500 - Range with 313 passengers 15,742km (8500nm).
A340-600 - Range with 380 passengers 13,890km (7500nm).
Weights
A340-500 - Operating empty 170,400kg (375,665lb), max takeoff 365,000kg (804,675lb).
A340-600 - Operating empty 177,000kg (390,220lb), max takeoff 365,000kg (804,675lb).
Dimensions
A340-500 - Wing span 63.70m (208ft 11in), length 67.80m (222ft 5in), height 17.80m (58ft 5in). Wing area 437.0m2 (4704sq ft).
A340-600 - Same, except length 75.30m (247ft 0in).
Capacity
A340-500 - Flightcrew of two. Typical three class seating for 316 passengers. A340-600 Typical three class seating for 372.
Weights
Dimensions
Capacity
				LuCa78
merci beaucoup
