Antonov 12 crash near Magadan
Un Antonov 12 è scomparso ieri dai radar dopo che l'equipaggio aveva dichiarato emergenza per engine fire. Oggi i soccorritori hanno raggiunto il velivolo, confermando il crash: per diverse ore vi è stata incertezza sulla sorte degli occupanti.
Qui trovate tutte le info sull'evento:
http://avherald.com/h?article=44102c56&opt=0
Il velivolo coinvolto (RA-11125), dovrebbe essere il più anziano velivolo operante nella flotta commerciale Russa, secondo ASN:
http://aviation-safety.net/database/rec ... 20110809-0
Re: Antonov 12 crash near Magadan
Ecco purtroppo l' esemplare coinvolto! :cry:
albert
Messaggio da albert »
Tutti gli AN-12 operanti in Russia sono stati messi a terra dal ministero dei trasporti.
Aggiornamenti sull'evento apparsi oggi su AvHerald:
"debris was found in a diameter of about 5km/2.7nm. Fragments of what is believed were human remains were recovered, the 11 occupants however are still officially listed missing (standing Aug 15th).
On Aug 15th 2011 the MCHS reported that remains believed to be human have been recovered from the crash site, that spreads out 5km in diameter. The occupants are still officially listed missing."
(http://www.avherald.com)
E' stato rilasciato dal MAK il Final Report relativo a questo evento. Questi i punti rilevanti, tratti dall'articolo di AvHerald:
"following the inflight shut down of engine #1 (outboard left hand) and feathering of the #1 propeller the longitudinal (roll) control of the aircraft was lost due to load-bearing properties of the left wing and possible damage to the left hand aileron control wiring resulting in the aircraft's uncontrolled excessive roll to the left and subsequent impact with terrain.
The fire started in the tail section of the #1 engine nacelle and spread forward and onto the wing.
The fire was most likely fed by fuel leaking from a fuel line connection to the low pressure fuel pump at engine #1, the fuel most likely ignited due to contact with hot engine parts. Due to the disintegration of the aircraft and fire damage it was not possible to establish the location of fuel leaks and the cause with certainty.
The inability of the fire suppression system to extinguish such a fire in its early stages as well as the lack of checklists/guidelines in the aircraft's flight manual for fuel leaks inside the engine nacelle contributed to the delay of more than 2 minutes to shut the engine down.
The mountaineous terrain underneath the aircraft, low level overcast cloud and lack of time due to continued fire did not permit the crew to select a proper site for an emergency landing."
(http://avherald.com/h?article=44102c56/0000&opt=0)
