Nose wheel ran over foot of worker
Un incidente decisamente insolito:
http://avherald.com/h?article=43f5e70c&opt=0
Non deve essere stata una sensazione piacevole :shock: !!
tommy92
Re: Nose wheel ran over foot of worker
Messaggio da tommy92 »
Ma che male!
noone
Messaggio da noone »
Con tutto il dispiacere e la simpatia per l'agente di rampa, però... ùmuhahah :lol:
Oggi NTSB ha rilasciato un factual report su questo evento:
"On Sep 13th 2012 the NTSB released their brief factual report stating that the nose gear had been turned to 80 degrees but not past the limit when the shear pins fractured. The crew was requested to set the park brake while workers arrived to assist removing the tow bar. Initial attempts to release the tow bar were unsuccessful. The ground staff, with the intention of releases tension from the tow bar, therefore requested the flight crew to release the park brake, the flight crew, unaware of the problems with the tow bar, however believed the push back would continue and therefore released the park brakes although company procedures required park brakes to be and remain set during removal of the tow bar. After the brakes were released attempts to open the locking handle were successful and the tow bar was removed, the aircraft however made an unexpected movement forward, ran over the tow bar and made contact and trapped a worker's foot before the aircraft came to a stop. Post accident investigation revealed no anomaly with the aircraft braking system."
(http://avherald.com/h?article=43f5e70c&opt=0)
Rilasciato da NTSB il Final Report su questo evento:
http://www.ntsb.gov/aviationquery/brief ... 1957&key=1
da AvHerald: "On Nov 8th 2012 the NTSB released their final report concluding the probable cause was: The ground crewmembers’ failure to follow proper procedures for removing a stuck or jammed tow bar, which resulted in a ground crew injury".
(http://www.avherald.com/h?article=43f5e70c&opt=0)
Una volta mi passarono sopra il piede con una Clio, e fece un male che ancora me lo ricordo, immagino quanto possa far male quando ti passa sopra un aereo, min**ia... :D
