Incidente ad un Tu-154 in Siberia (thread tecnico)
albert
Messaggio da albert »
Le prime notizie riportano almeno una persona deceduta e tre dispersi, almeno 10 persone ricoverate in ospedale.
L'aereo appartiene alla Kogalymavia Airlines e l'incidente è avvenuto in fase di decollo dall'aeroporto di Surgut, in Siberia.
L'aereo, con 116 passeggeri e 8 membri d'equipaggio era diretto all'aeroporto Domodedovo di Mosca.
http://en.rian.ru/russia/20110101/162017397.html
albert
Re: Incidente ad un Tu-154M in Siberia (thread generico)
Update: tra le persone ricoverate sembra che almeno 4 abbiano respirato fumi tossici dell'incendio che si è sviluppato a bordo a seguito dell'incidente in decollo.
sinico.aeronauta
Messaggio da sinico.aeronauta »
Keep it flying! Fly safe! Share safer skies!
Re: Incidente ad un Tu-154 in Siberia (thread tecnico)
Aggiornamento apparso oggi su avherald:
"The MAK have initiated an investigation. On Jan 2nd the MAK added, that both flight data recorders have been recovered, analysis has begun.
Russia's Rostransnadzor (Ministry of Transport) said on Jan 1st, the airplane had just been pushed back, the engines were being started when ground staff ordered an emergency shut down of the engines due to a fire. The engines were shut down, the airplane de-powered and an evacuation was initiated. The fire reached the inside of the passenger cabin. Emergency services were able to extinguish the fire about 42 minutes after the fire broke out. The airplane was destroyed. 3 people were killed, 39 people were injured. The Ministry have initiated an investigation in cooperation with the Russian prosecution office. On Jan 2nd the Ministry added, that after the assessment of risk vs economics involving the continued operation of the 15 TU-154B types remaining in service in Russia the Ministry have proposed to suspend operation of TU-154B aircraft until the factors leading to the accident have been determined.
The airline reported in a press release dated Jan 2nd, that 43 people including 8 crew members were hospitalized with burns of first and second degree as well as injuries from smoke inhalation. Three persons have not been located so far. The airplane carrying 116 passenger and 8 or 10 crew was taxiing out for departure at the time and burned completely down.
Local Authorities in Surgut confirmed one fatality on Jan 2nd and reported two passengers (a father and son) missing."
(http://www.avherald.com)
Ulteriori aggiornamenti:
"On Jan 2nd the MAK added, that both flight data recorders have been recovered, analysis has begun. On Jan 3rd the MAK said, that all three engines had been started when the fire broke out. The quality of recordings is good, the work at the accident site is hampered by low temperatures however.
One of the pilots reported, that they had started the engines and were just connecting the generators when they received the command to shut down. Passengers started to shout "fire", almost instantly smoke came through all openings into the cockpit.
Passengers reported, that people in the last seat row started to shout fire, then smoke quickly entered the cabin followed by actual fire that rapidly spread through the cabin along the ceiling."
Sembra che l'agenzia Russa abbia sospeso i voli del Tu-154B :
http://www.ttgitalia.com/pagine/Stop-de ... -news.aspx
Inoltre su avherald è apparso oggi questo aggiornamento:
"On Jan 4th the MAK reported, that the fire broke out in the rear of the aircraft between frames 62 and 65, neither engines nor the APU were the source of the fire."
E' stato rilasciato dal MAK il final report su questo evento, come riportato qui:
http://avherald.com/h?article=4358a6d0/0002&opt=0
