Bombardier Global 7000 - Global 8000
atalanta89
Messaggio da atalanta89 »
Da Flightglobal:
http://www.flightglobal.com/articles/20 ... amily.html
Bombardier has taken the wraps off its revamped Global family of large, ultra long-range business jets on the eve of this year's National Business Aviation Association annual convention in Atlanta, Georgia.
The Global 7000 and 8000 join the Canadian manufacturer's Global 5000 and Global Express XRS models.
"The Global 7000 and Global 8000 jets will give our customers the ability to reach more destinations non-stop than ever before, delivering unprecedented levels of performance, flexibility, and comfort," says Bombardier Business Aircraft president, Steve Ridolfi.
The Global 7000 features a four-zone cabin which Bombardier says will enable passengers to "enjoy 20% more living space than the cabin of the current industry leader".
The aircraft will have a top cruise speed of M0.90, and a range of 7,300nm (13,520km) at M0.85 carrying 10 passengers. Entry into service is scheduled for 2016.
The Global 8000 offers a maximum range of 7,900nm (14,631km) at M0.85, carrying eight passengers, and is due to enter service in 2017.
The new Global models feature an all-new, high-speed transonic wing and will be powered by 16,500lb-thrust General Electric TechX engines. The aircraft also have enlarged windows, with 80% more surface area than the existing Global models, says Bombardier.
The Global 5000 and XRS models are equipped with Rolls-Royce BR710 turbofans.
Re: Bombardier Global 7000 - Global 8000
Novità in questi giorni per la famiglia Global. A EBACE è stata presentata l'aggiunta di due nuove versioni della famiglia, il Global 5500 e il Global 6500, con entrata in servizio prevista a fine 2019.
Rolls-Royce presenta la nuova famiglia di propulsori Pearl, che equipaggerà i Global 5500 e 6500.
L'ammiraglia Global 7000 (con entrata in servizio nella seconda metà del 2018) assume la denominazione Global 7500, in virtù delle performance migliori emerse durante i test rispetto a quanto previsto.
http://www.md80.it/2018/05/28/cresce-la ... obal-7500/
http://www.md80.it/2018/05/28/rolls-roy ... ne-family/
Il Global 7500 ottiene la Type Certification da Transport Canada:
https://www.md80.it/2018/09/29/il-bomba ... rt-canada/
Certificazione arrivata anche da FAA per il nuovo Global 7500, con entrata in servizio prevista entro la fine dell'anno:
https://www.md80.it/2018/11/08/bombardi ... dalla-faa/
Bombardier ha celebrato l'entrata in servizio del Global 7500:
https://www.md80.it/2018/12/21/bombardi ... obal-7500/
A proposito dei propulsori del nuovo Global 7500:
https://www.md80.it/2019/01/17/il-motor ... obal-7500/
Anche EASA rilascia la certificazione per il Global 7500:
https://www.md80.it/2019/02/08/bombardi ... e-da-easa/
barth
Messaggio da barth »
Osservando con attenzione il sito di Bombardier rimango sorpreso di come l'offerta di questo costruttore sia cosi ampia per le singole tipologie e versioni, Learjet, Global e Challenger, e per ognuna differenze per numero di posti disponibili e capacita'di distanze coperte, a mio modesto parere minime.
Mi chiedo quanto sia importante per un compratore la differenza di un paio di posti a bordo o una differenza minima di coprire alcune distanze, nel caso specifico rimango sorpreso delle varie versioni del modello Global.
Nel caso di questo settore aereo quali potrebbero essere le motivazioni nella scelta non tanto del modello ma della versione?
Vero, Bombardier ha una gamma molto varia, che spazia dai Learjet fino ad arrivare all'attuale ammiraglia, il Global 7500.
Il mercato dei business aircraft è particolare rispetto a quello dei velivoli commerciali, i profili di missione richiesti dai clienti possono essere anche molto diversi tra loro, in base all'utilizzo previsto.
Vi sono diverse varietà di allestimenti interni, che il cliente può customizzare in base alle sue preferenze. Bombardier offre già in partenza un ampio ventaglio di versioni, con diversa disposizione dei posti e diverso range. Il tutto è poi personalizzabile ulteriormente sia come disposizione che come allestimento interno e materiali.
Visto il genere di clienti e l'utilizzo che può essere anche molto differente tra un cliente e un altro, credo sia normale offrire già in partenza una buona base di versioni con diverso range e capacità.
Il Rolls-Royce Pearl 15, motore esclusivo per i Global 5500 e 6500, ha ricevuto la certificazione da Transport Canada:
https://www.md80.it/2019/09/23/il-rolls ... rt-canada/
Ed oggi anche i jet Global 5500 e Global 6500 hanno ottenuto la Type Certification da Transport Canada, aprendo la strada per l’entrata in servizio entro la fine dell'anno:
https://www.md80.it/2019/09/24/i-bombar ... rt-canada/
Certificazione anche da EASA per i nuovi Global 5500 e Global 6500:
https://www.md80.it/2019/10/15/i-bombar ... e-da-easa/
Certificazione da parte di FAA per i Global 5500 e 6500. FAA certifica anche il motore Rolls-Royce Pearl 15, motorizzazione esclusiva dei due velivoli.
https://www.md80.it/2019/12/23/i-bombar ... dalla-faa/
https://www.md80.it/2019/12/23/il-rolls ... dalla-faa/
Prima consegna per il Bombardier Global 6500:
https://www.md80.it/2019/12/23/bombardi ... obal-6500/
Sempre riguardo a Bombardier, il costruttore ha svelato che in futuro si dedicherà solo sulla Business Aviation. Nei mesi scorsi era già uscito dal ramo Commercial Aviation, con la cessione dei programmi C Series ad Airbus, del programma Dash 8 a De Havilland Canada e con la vendita del programma CRJ a Mitsubishi (che verrà finalizzata nei prossimi mesi). Oggi ha annunciato la cessione anche delle attività ferroviarie (Bombardier Transportation) ad Alstom.
Quindi in futuro l'impegno di Bombardier sarà completamente focalizzato sui business jet, con Bombardier Aviation.
https://www.md80.it/2020/02/18/bombardi ... -division/
Entra in servizio il Global 5500:
https://www.md80.it/2020/06/26/bombardi ... iness-jet/
Bombardier consegna il primo Global 7500 dotato di Dual Head-up Display (HUD):
https://www.md80.it/2020/08/24/bombardi ... splay-hud/
Bombardier, ora società centrata completamente sulla business aviation, ha annunciato, insieme ai suoi risultati 2020, la decisione di sospendere la produzione dei Learjet verso la fine del 2021:
https://www.md80.it/2021/02/12/bombardi ... stre-2021/
Bombardier ha presentato il nuovo Challenger 3500:
https://www.md80.it/2021/09/15/bombardi ... nger-3500/
Ottimi risultati per Bombardier nel 2021:
https://www.md80.it/2022/02/10/bombardi ... tero-anno/
Bombardier ha presentato oggi a EBACE 2022 l’ultimo membro del suo business jet portfolio, il Global 8000.
https://www.md80.it/2022/05/23/bombardi ... obal-8000/
Performance eccellenti per Bombardier nel 2022, che ha sovraperformato la guidance prevista:
https://www.md80.it/2023/02/09/bombardi ... -nel-2023/
Bombardier conferma gli obiettivi per il 2025 e rivela le leve di crescita fino al 2030:
https://www.md80.it/2024/05/01/bombardi ... o-al-2030/
Inoltre Bombardier fornisce i dettagli del Firm Order di dicembre 2023 da parte dI NetJets per 12 Challenger 3500 e 232 opzioni:
https://www.md80.it/2024/05/01/bombardi ... 2-opzioni/
Bombardier annuncia di aver consegnato il 200° Global 7500 business jet a un cliente a dicembre, a testimonianza del successo internazionale e di settore di questa piattaforma.
https://www.md80.it/2024/12/09/bombardi ... obal-7500/
Ottime performance per Bombardier nel 2024:
https://www.md80.it/2025/02/06/bombardi ... nanziarie/
Bombardier annuncia la consegna del suo 1.000° super-midsize aircraft, che segna una pietra miliare significativa nella storia della business aviation. Questo traguardo storico è stato celebrato con la consegna di un velivolo Challenger 3500 a un cliente Bombardier di lunga data.
https://www.md80.it/2025/02/28/bombardi ... nger-3500/
Bombardier ha annunciato che il suo Global 8000 business jet program sta procedendo secondo i piani, con il suo primo Global 8000 production aircraft che continua nella fase di assemblaggio. L’aereo sta procedendo attraverso il processo di produzione verso l’entrata in servizio pianificata (EIS) nel 2025.
https://www.md80.it/2025/04/08/bombardi ... -previsti/
Bombardier ha riportato risultati molto positivi nel primo trimestre 2025:
https://www.md80.it/2025/05/01/bombardi ... stre-2025/
Bombardier ha annunciato che il primo production Global 8000 aircraft ha completato con successo il suo volo inaugurale.
https://www.md80.it/2025/05/20/il-primo ... naugurale/
GE Aerospace ha annunciato che spedirà il suo 500° motore Passport questo mese e ha consegnato i primi motori certificati per il nuovo Global 8000 business jet di Bombardier.
https://www.md80.it/2025/10/13/ge-aeros ... rt-engine/
Bombardier ha annunciato che il Global 8000 ha stabilito un nuovo punto di riferimento del settore per la cabin altitude a 2.691 piedi a 41.000 piedi, la più bassa mai prodotta nella business aviation.
https://www.md80.it/2025/11/04/il-bomba ... -altitude/
Bombardier ha annunciato che il Global 8000, il business aircraft più veloce al mondo, ha ottenuto la Transport Canada Type Certification, aprendo la strada all’entrata in servizio quest’anno. Seguiranno le certificazioni della Federal Aviation Administration (FAA) e dell’European Aviation Safety Agency (EASA), in linea con i requisiti di consegna.
https://www.md80.it/2025/11/05/il-bomba ... ification/
Bombardier ha annunciato solidi risultati finanziari per il terzo trimestre 2025, con diversi parametri chiave che hanno registrato ampi guadagni su base annua:
https://www.md80.it/2025/11/06/bombardi ... stre-2025/
Bombardier ha celebrato l’entrata in servizio del suo nuovo Global 8000 business aircraft:
https://www.md80.it/2025/12/09/bombardi ... obal-8000/
Il Bombardier Global 8000 riceve la certificazione della Federal Aviation Administration (FAA) degli Stati Uniti:
https://www.md80.it/2025/12/20/il-bomba ... ati-uniti/
Il Global 8000 ha ricevuto la type certification da Transport Canada (TC) il 5 novembre 2025 ed è entrato in servizio a dicembre 2025. La certificazione da parte dell’European Union Aviation Safety Agency (EASA) è in attesa.
