Interessante...
- sidew
- 87Nemesis87
Re: Interessante...
WOW! ...ecco a che serve essere ingegneri
...finalmente laureato!!!
...ATPL: Completato!!
-- MEP, SEP, IR, CPL, MCC --
-- CRJ-100/900 Type Rated --
- sidew
Re: Interessante...
Vorra dire che i 777 potrebbero decollare benissimo a FLR...
Fortuna che era leggero... senno chissa cosa sarebbe successo se fosse stato piu pesante...
trovato l'articolo su avherald: http://www.avherald.com/h?article=4306396f&opt=0
interessante anche la catena degli eventi:A British Airways Boeing 777-200, registration G-VIIR performing flight BA-2156 from Saint Kitts (St. Kitts and Nevis) to Antigua (Antigua and Barbuda) with 87 passengers and 14 crew, was preparing for departure from runway 07, when the crew was cleared to backtrack the runway 07. The captain however requested to depart from the intersection of the runway with taxiway Alpha (takeoff run available TORA 1915 meters/6280 feet) which was approved by the tower. The airplane however taxied onto the runway at taxiway Bravo (takeoff run available 1220 meters/4000 feet) and commenced takeoff from there. The airplane's main gear departed the runway surface about 1000 feet short of the end of paved surface, the airplane continued for a safe landing in Antigua.
Findings
1 Both the pilot and co-pilot were properly licensed and qualified to operate the aircraft.
2 The aircraft was certified, equipped and maintained in accordance with the existing regulations and approved procedures.
3 The crew had calculated the aircraft performance figures for a TORA of 1,915 m from Intersection Alpha.
4 The TORA from Intersection Bravo was 1,220 m.
5 The crew did not brief the taxi routing.
6 There were no taxiway or holding point signs on the airfield.
7 The crew misidentified Taxiway Bravo for Taxiway Alpha and departed from Intersection Bravo.
8 The ECCAA did not take appropriate action to ensure the findings of the 2006 airfield inspection were acted upon in a timely manner.
9 St Kitts had not filed any differences to Annex 14 with ICAO.
10 The lack of signage was not published in the ECAIP.
11 There was no formal means of incident reporting within ATC.
12 The operator had not conducted a physical survey of the airfield.
Contributory factors
1 The airport authority had not installed any taxiway or holding point signs on the airfield.
2 The crew did not brief the taxi routing.
3 The crew misidentified Taxiway Bravo for Taxiway Alpha and departed from Intersection Bravo.
4 The trainee ATCO did not inform the flight crew that they were at Intersection Bravo.
- sidew
Re: Interessante...
il rapporto finale rilasciato giusto 6 gg fa: http://www.skybrary.aero/bookshelf/books/1336.pdf
md82
