Filmati mozzafiato .....
richelieu
Messaggio da richelieu »
Guardate questi filmati .....
Features of the Auto-GCAS automatic safety system are demonstrated in a simulator at Edwards AFB, California. Note how the large chevrons on the HUD converge as the threat of a collision becomes imminent. If the pilot takes no action, or is incapacitated, the system automatically takes over and a 'fly-up' symbol appears on the display as the aircraft recovers. As well as protecting against impact with rising terrain, see how Auto-GCAS reacts when the pilot attempts an airshow-like maneuver at too low an altitude.
Auto-GCAS demonstration flight, from the ACAT F-16 cockpit, in company with NASA F-18 photo chase. Note how, in the later stages of the clip, the chevron markings on the aft cockpit HUD repeater converge to indicate proximity to a potential 'fly up' situation in which the system will automatically recover the aircraft. The demonstration flight was undertaken from Edwards AFB, California and covered almost 500 nautical miles of desert and mountain terrain.
Auto-GCAS demonstration flight from the aft cockpit of the ACAT F-16.
The aircraft is being flown at extremely low level across the Cords Road practise area close to Edwards AFB, California. Despite the aggressive S-turns at high speed and low altitude, no nuisance 'fly-ups' were triggered by the safety system.
This portion of the Auto-GCAS flight was a prolonged terrain-masking run through a low-level route from the barren wastes of the Panamint Valley to the snowy tops of the Sierra Nevada mountains. The Blue Low Level route encompasses some of the most rugged terrain anywhere in the world, and provides a major test of the system with precipitous peaks, knife-edge ridges and narrow, winding ravines. Initially flown in high protection mode, the F-16 was pushed into the only 'nuisance' fly-up of the entire flight as we hurtled up a ridge at the top of Rainbow Canyon at the northwest end of the Paramint Valley. The maneuver momentarily sent us up several hundred feet.
Beginning with a straight run-in across Owens Lake towards the Sierra Nevada mountain range, this part of the Auto-GCAS demonstration flight took us in an instant from the arid heat of the valley to the snow and frozen lakes of the Inyo National Forest. The true robustness of the system to nuisance fly-ups was then demonstrated during a dramatic, gut-wrenching descent down the narrow, twisting Kern River valley. With ridge and mountain tops either side, and the river flashing below, Kevin Prosser flew the F-16 within the tight confines of the valley at less than 200 ft and more than 500 kts without provoking a single fly-up despite the fact the collision avoidance demonstration was flown with elevated 'buffers'.
With fuel running low, we returned to Edwards AFB, the demonstration having thoroughly convinced me that Auto-GCAS will save lives and aircraft without getting in anyone's way. The landing was made on runway 4L-22R following an approach offering spectacular views of the base and Rogers Lake and its enormous runways. The longest of these - runway 17-35 - is just over 39,000-ft long!
:shock:
davide.pasq
Re: Filmati mozzafiato .....
Messaggio da davide.pasq »
cioè sarebbero ricerche su un sistema per il volo a bassa quota? ma il tornado non ha da sempre un sistema radar che gli consente di volare costantemente a 14 metri dal suolo ad alta velocità?
Almost Blue
Messaggio da Almost Blue »
Si, ma mi sa che con il terrain following tu le mani le tieni ferme sulle ginocchia (se ci riesci), mentre con l'ACAT tu piloti l'aereo dove ti pare a bassa quota e il sistema ti elimina e corregge tutti i casi in cui ti schianteresti per terra, quindi puoi volare in tutta sicurezza e a occhio, perchè il sistema aggiunge tutte le correzioni necessarie a non sbattere per terra.
Hartmann
Messaggio da Hartmann »
Sembra che la cosa più difficile da fare con il Tornado sia insegnare al pilota a non toccare niente
davide.pasq
ah ecco, questo non lo sapevo.. grazie mille! :wink:
