http://www.corriere.it/esteri/09_novemb ... aabc.shtml
L'ho appena letta, non so se è già stata riportata ma non mi pare. Dev'essere un gran bel problema con il volume di traffico che hanno ad Atlanta.
Computer di terra nel caos, ritardi ad Atlanta
- =Casio=
Re: Computer di terra nel caos, ritardi ad Atlanta
ecco l'articolo del WSJ
A computer glitch that caused flight cancellations and delays across the U.S. Thursday has been resolved, the Federal Aviation Administration said.
Many of the nation's airports weren't encountering departure delays as of late morning, according to the FAA's air-traffic command center. But major delays were reported in Washington, New York, Philadelphia and Chicago.
The FAA said the problem was fixed around 10 a.m. EST, but it was unclear how long flights would continue to be affected. The glitch involved the FAA computer systems in Salt Lake City and Atlanta that handle automated flight plans, forcing air-traffic controllers to revert to the much more time-consuming approach of entering flight plans by hand.
That produced a "domino effect" delaying flights around the country, the National Air Traffic Controllers Association said. Spokesman Doug Church said controllers were still entering flight plans manually in some locations.
The FAA system is a major, cutting-edge program full of redundancies that are designed to keep it from going down. As such, the problem is quite different from localized radio communication or computer problems the FAA suffers from time to time.
FAA spokesman Paul Takemoto said the problem started between 5:15 and 5:30 a.m. and affected mostly flight plans but also traffic management, such as ground stops and ground delays.
Flight delays began on the East Coast and rippled out to the west. The problem didn't affect radar coverage or communications with planes in the air, the FAA said. The air-traffic controllers union, however, said the FAA systems that provide information on weather and wind speeds at airports weren't functioning.
As of mid-morning, the delays appeared wane. FlightStats.com, which captures FAA flight data, indicated that departures from Hartsfield-Jackson Atlanta International Airport were delayed by 20 to 60 minutes. But departures scheduled for later in the day were generally showing to be on time.
"The airport is working to minimize the impact on customers by bringing in additional staff and ensuring that all facilities are operational and fully maintained," a statement from Hartsfield-Jackson officials said.
Departures from John F. Kennedy International Airport in New York were indicated running at more than an hour behind schedule for a handful of flights, according to FlightStats.com.
At Washington's Dulles International Airport, flights destined for New York's LaGuardia Airport averaged delays of one hour and 20 minutes. Philadelphia International Airport showed delays of 15 to 30 minutes on some flights, but departures scheduled for later looked to be on time. Traffic bound for Philadelphia from Dulles was running more than two hours behind. The FAA said gate hold and taxi delays at Dulles were averaging more than one and a half hours, and were lengthening.
US Airways Group Inc. said the FAA's problems created a systemwide slowdown for its planes, with some being delayed up to 30 minutes. The airline said it brought additional staffers to its operations center in Pittsburgh to cope with the slower, manual processing of flight information.
Atlanta-based Delta Air Lines Inc., the largest U.S. airline by traffic, said it was experiencing some delays but continued to dispatch flights and was assessing a situation that remained fluid.
American Airlines, unit of AMR Corp. and the second-largest U.S. airline by traffic behind Delta, said the process of entering plans manually is working better, spokesman Tim Smith said. "It's going much more smoothly now, so the system is flowing," Mr. Smith said. "It took a little while to get them up to speed."
American had yet to cancel any flights and was seeing delays of 10 to 20 minutes, though some stretched to an hour, Mr. Smith said. "We've had worse days driven by weather," he said. "This is perhaps broader but not as extreme."
An AirTran spokesman said as of 8 a.m. EST Thursday the airline had canceled 22 flight across the U.S. He said the cancellations were mainly at their Atlanta hub, but flights were affected nationwide.
Passengers are being asked to check the status of their flights online before going to airports
- =Casio=
Ecco grazie, questo è più completo. Inserire a mano i piani di volo non dev'essere per niente pratico ad ogni modo se i ritardi sono stati limitati tra i 20 e i 60 minuti direi che sono stati bravissimi, a fiumicino tendenzialmente i ritardi medi sono equivalenti anche senza problemi tecnici. In ogni caso se per un problema ai computer son state bloccate anche le informazioni meteo (suppongo metar e taf) e i venti al suolo mi fa presumere che sia abbastanza debole come sistema.
- Paolo_61
della serie "tutto il mondo è paese".
Pensate solo alle polemiche se fosse successo qui in Italia.
- Limosky91
- FL 300
scusate se vado un po' offtopic ma....
questa foto ha sotto la didascalia "L'aeroporto di Atlanta (da Current)"
http://www.corriere.it/Hermes%20Foto/20 ... 80x140.jpg
Questa francamente è una roba da Studio Aperto, non di certo dal Corriere....
basta chiudo l'OT
basta chiudo l'OT
LINO
del resto è trafficato come aeroporto
- Slowly
Non sono stato io.
