Laser aviotrasportato in azione .....
richelieu
Messaggio da richelieu »
Dal blog "Ares" di AW&ST .....
Ares
A Defense Technology Blog
Directed energy on display
Posted by Guy Norris at 10/1/2009 1:56 PM CDT
Boeing (Boeing/YouTube)
Boeing has released new video of the advanced tactical laser tests being conducted in New Mexico using an Air Force NC-130H. Full-scale firing tests of the high-energy chemical oxygen iodine (COIL) laser system began in August against target boards and more recently against a 1ft square target on the the hood of the vehicle seen in these clips. The Air Force says jitter does not appear to be a problem, and has also conducted “successful” firings against an unspecified moving target. There is no data yet released on how far away the aircraft was when firing at the truck, though it appears to be sufficiently distant for engine noise to be muted.
This video shows the effect of the high-energy laser beam from the Boeing Advanced Tactical Laser (ATL), fired at a stationary truck from a US Air Force NC-130H flying over White Sands Missile Range, New Mexico, on August 30, 2009. The ATL is a chemical oxygen iodine laser (COIL), and is a scaled-down version of the megawatt-class high-energy laser in the Boeing YAL-1 Airborne Laser (ABL). ABL and ATL are both technology demonstration programs.
87Nemesis87
Re: Laser aviotrasportato in azione .....
Messaggio da 87Nemesis87 »
incredibile.... :shock: :shock:
...finalmente laureato!!!
...ATPL: Completato!!
-- MEP, SEP, IR, CPL, MCC --
-- CRJ-100/900 Type Rated --
richelieu
Un'immagine dell'aereo .....
Almost Blue
Messaggio da Almost Blue »
Apre anche casseforti recalcitranti e caveau?
Quanto bisogna tenerlo sul bersaglio per perforarlo?
richelieu
Almost Blue ha scritto:Apre anche casseforti recalcitranti e caveau?
Appartenente alla "Banda Bassotti" ? .....
:mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
Almost Blue
richelieu ha scritto: Appartenente alla "Banda Bassotti" ? .....
No magari.
E' che volevo solo riferirmi al fatto che quanto ci metterebbe per perforare un paio di cm di acciaio o di titanio? No perchè un missile per definizione corre parecchio... In rete dice che dovrebbero bastare un 3-5 sec, ma davvero il laser "cadrebbe" sul missile per 3-5 secondi e con temperatura sufficiente a bucarlo ?
E' poi c'è anche scritto che tutto l'apparato dovrebbe trovarsi entro "...zone prossime..." ai lanci. Quanto prossime? Vogliamo fare un paio di cento chilometri? Ma se io sono un paese come la Cina o la Russia e metto le rampe ben in profondità nel mio territorio, come fate voi a raggiungerle coi laser ? A meno che il laser non sia fatto anche per bucare i missili in volo suborbitale (cento Km?), ma qui a che velocità si muove il missile rispetto alla terra?
Inoltre, per operare, questi aerei (747?) andrebbero costantemente protetti e quindi Tutti in aria per assicurare la copertura agli "aerei-laser"! AWACS, rifornitori, intercettori, disturbatori.... Auguri!
Mi sa che la montagna ha partorito il topolino. A meno che, non abbiano scopi che non si conoscono, ma che comunque interesserebbero solo regioni di confine di paesi "cattivi", in quanto le regioni interne rimarrebbero irraggiungibili manco fossero la Luna.
Paolo_61
Messaggio da Paolo_61 »
Ho la vaga idea che questo genere di armi sia destinata alla difesa contro paesi un po' meno dotati di armamenti della Russia (sulla Cina non ci scommetterei), in quanto il problema come sempre è anche quello della saturazione dei sistemi. Un conto è colpire un missile, un conto è prendersi cura di qualche centinaio di lanciatori.
Infatti credo di ricordare che per quel problema sia in sviluppo un sistema destinato ad intercettare le testate al rientro, basato esclusivamente sull'energia cinetica.
Almost Blue
Il problema secondo me è che quando volano missili balistici della gittata di 10.000 Km, oramai è tardi per tutto! Non so voi, io mi butto sulla ragazza della porta accanto, tanto che differenza fà.... :mrgreen: Altro che laser aviotrasportati.
Il resto sono tutte balle, per me.
