Passaggio visibile sull'Italia della ISS
Slowly
Messaggio da Slowly »
Segnaliamo il passaggio di stasera alle 21.30 circa sui cieli italiani della ISS che sarà ben visibile, tempo permettendo!
Qui maggiori dettagli
http://attivissimo.blogspot.com/2009/07 ... a-iss.html
Slowly
Re: Passaggio visibile sull'Italia della ISS
E NASATV è già partita la diretta video del lancio dello Shutlle Endevour, previsto per stanotte.
8)
Slowly
Il lancio mi pare di capire sia stato rimandato per un controllo al velivolo in seguito ad un temporale.
albert
Messaggio da albert »
Slowly ha scritto:Il lancio mi pare di capire sia stato rimandato per un controllo al velivolo in seguito ad un temporale.
Il lancio è stato rinviato a domani. L'area di lancio è stata colpita da 11 fulmini. :shock:
Dal sito della NASA:
"Careful Testing Under Way After Lightning Strikes
Sat, 11 Jul 2009 05:59:52 PM UTC+0200
The launch of space shuttle Endeavour was postponed until Sunday evening so engineers could evaluate the spacecraft's myriad systems following 11 lightning strikes in the Launch Complex 39A area.
None of the strikes hit the shuttle or its external tank and solid rocket boosters, but there were strikes to the lightning mast and water tower. The launch pad is equipped with a lightning protection system of wires that is intended to steer bolts away from the shuttle.
"We've seen nothing so far that shows anything affected any of the systems," said Mike Moses, chairman of the pre-launch Mission Management Team.
Two of the strikes were strong enough to trigger an evaluation by engineers just to make sure all of Endeavour's systems are ready for flight. Although early evaluations showed no problems, engineers wanted more time to make sure they have checked everything correctly.
"We need to be 100 percent confident that we have a good system across the board," Moses said.
The launch time for Sunday is 7:13 p.m. EDT. The weather forecast calls for a 60 percent chance of acceptable conditions
Zapotec
Messaggio da Zapotec »
Vista !!
Astrid
Messaggio da Astrid »
Avvisatata :wink:
Ottico Abilitato. Specialista in Contattologia.
Appassionato di Medicina Aeronautica.
Pilota.
albert
Zapotec ha scritto:Vista !!
eh.. fortunello.... :mrgreen:
da me è stato sereno fino alle 20:00, poi il tempo ha deciso allegramente di rannuvolare, per un simpatico temporale che si sta preparando :twisted: :twisted: :twisted:
Zapotec
da me il tempo è stranamente NON afoso... altrimenti sarebbe stato sereno ma il cielo non si vede comunque... in compenso anche le zanzare mi hanno visto bene :)
ho chiamato anche moglie e figlia a vedere sto puntino che si muoveva, la figlia è rimasta stupuita (dopo che gli ho fatto vedere in grosso su internet cos'era quello che ha visto) che ci potesse essere un aggeggio così la sopra
ciao !
Slowly
dovrebbe replicare poco dopo le 23
Zapotec
Slowly ha scritto:dovrebbe replicare poco dopo le 23
sono ancora che mi metto il fargan per quella prima ;)
DragonFly
Messaggio da DragonFly »
A meno di un mio errore...adesso da me è in vista.
Slowly
In questi minuti è cominciato l'imbarco dei 7 memebri di equipaggio di STS127.
Al momento il lancio è confermato, il tempo pare tenere.
-4h
http://www.nasa.gov/mission_pages/shutt ... index.html
CanarinoMannaro
Messaggio da CanarinoMannaro »
ieri sera l'ho vista bene nel cielo di milano! 8)
Slowly
Io mi guardando la diretta del lancio.
manca un'ora.
http://www.nasa.gov/multimedia/nasatv/index.html
Astrid
Per che ora è previsto il lancio?
Pilota.
albert
Astrid ha scritto:Per che ora è previsto il lancio?
Lancio rinviato, a causa del maltempo, alle ore 18:51 EDT del 13.07, (00:51 del 14.07 in Italia)
ciao!
Slowly
Dopo un raduno di MD80 ho fatto piovere sullo Shuttle...
:book:
Mi sa che Polanski mi sta cercando... :D
Speriamo stanotte sia la volta buona o si rimanda tutto di un mese, leggevo.
geostazionario
Messaggio da geostazionario »
Slowly ha scritto:Segnaliamo il passaggio di stasera alle 21.30 circa sui cieli italiani della ISS che sarà ben visibile, tempo permettendo!
Se si ha fortuna, ma capita raramente, si può vedere lo shuttle vicino alla stazione durante il docking/undocking.
Mi è successo solo una volta ed è uno spettacolo pazzesco.
lrutragmi
Ashaman
Messaggio da Ashaman »
Gli ultimi giorni... attualmente fino dalla metà di giugno, dalle mie parti è quasi sempre nuvoloso. Certo, fa la calura più sopportabile, ma anche il più potente dei binocoli/cannocchiali/telescopi (per non parlare della visione senza aiuti) serve a poco quando c'è una copertura variabile da 4/8 a 7/8. :dontknow:
Ultima modifica di Ashaman il 13 luglio 2009, 15:57, modificato 1 volta in totale.
-Benjamin Franklin
Fabri88
Messaggio da Fabri88 »
Cavoli me la sono persa.
Non ho mai visto l'ISS!
Ma quando la si vede (perchè mi pare che non è la prima volta che viene segnalata su questo forum) è visibile ad occhio nudo oppure bisogna avere strumenti ottici?
Inoltre, è possibile vedere la posizione della ISS da qualche parte su internet?
Ashaman
Fabri88 ha scritto: Ma quando la si vede (perchè mi pare che non è la prima volta che viene segnalata su questo forum) è visibile ad occhio nudo oppure bisogna avere strumenti ottici?
Compra un binocolo da un cinese. 15 €uri (o anche meno se ci sai fare) e ti passa la paura. Ad occhio nudo magari trovi il punto da osservare, e poi tiri fuori il binocolo per migliore visione. :D
-Benjamin Franklin
Fabri88
Ho un canocchiale con 60X di ingrandimento. Altro che Zhongguo!
Fabri88
Per quanto riguarda la posizione ho trovato questo sito -----> http://www.amsat.org/amsat-new/tools/pr ... ellite=ISS
Dalla velocità in cui si muove dovrebbe fare il giro della terra in una mezzoretta.
Praticamente allora passa sopra quasi tutte le sere. O è un evento piuttosto raro (diciamo quell'1 o 2 volte all'anno)?
Slowly
Fabri88 ha scritto:Per quanto riguarda la posizione ho trovato questo sito -----> http://www.amsat.org/amsat-new/tools/pr ... ellite=ISS
Bé non è che passa SEMPRE sulla stessa verticale immagino.
In effetti come evento non è così raro, anche tra pochi giorni dovrebbe ripassare ed essere ancora più luminosa.
geostazionario
Qui sotto il link che vi permette di sapere quando l'ISS e visibile dalla vostra città.
http://esa.heavens-above.com/esa/iss_step1.asp?nored=1
lrutragmi
Slowly
Endeavour ancora fermo per maltempo, si riprova, ora italiana, poco dopo la mezzanotte di domani notte.
Slowly
Mi sa che stavolta è quella buona!
Slowly
Go to launch!
-10
albert
Slowly ha scritto:Go to launch!
-10
e... -8 lanci al grounding degli shuttle... :(
Zapotec
... e poi ? :(
albert
Zapotec ha scritto:... e poi ? :(
L'Orion... utilizzando i vettori Ares I, nell'ambito del progetto Constellation.
Paolo_61
Messaggio da Paolo_61 »
Trovi sul sito della Nasa l'illustrazione completa dei prossimi vettori utilizzati per l'esplorazione umana dello spazio.
neutrinomu
Messaggio da neutrinomu »
Giovedì nuovo spettacolare passaggio visibile in tutta italia (magnitudo -3.5 !)
Whisky Charlie
Messaggio da Whisky Charlie »
Gli orari indicati sono UTC? Ora locale italiana? GMT?
Grazie.
neutrinomu
Whisky Charlie ha scritto:Gli orari indicati sono UTC? Ora locale italiana? GMT?
Grazie.
Ora italiana (cioè tra 45 minuti sirca). Per chi si perde lo spettacolo si replica sabato, stessa traiettoria a partire però dalle 20:55. Qui è possibile vedere real-time la posizione della ISS (ricaricare la pagina per agiornare)
