checklist boeing
checklist boeing
salve qualcuno avrebbe la pazienza di spiegarmi una checklist boeing 737 ng grazie mille .
Re: checklist boeing
LEFT/RIGHT TRANSFER BUS ‘SOURCE’ LIGHTS
REVERSER LIGHTS …………………………………………………………………….EXTINGUISED
PASSENGER OXYGEN switch ………………………………………………….NORMAL / Light OFF
SERVICE INTERPHONE SWITCH …………………………………………………….AS REQUIRED
IRS MODE SELECTORS ……………………………………………………………………………..NAV
Exterior
General Airplane Condition .....................................................................................................Check
Probes, sensors, ports, vents and drains…………………………………..Unobstructed/Undamaged
Doors latches and access panels ……………………………………………………….Closed/Secure
Tires, brakes and wheels …………………………………………………………….Check/Undamaged
Gear struts and doors ........................................................................................................Check
Gear Pins ........................................................................................................Removed
Nose gear steering lockout pin ………………………………………………………………As Required
Oxygen Pressure Relief Disc ...................................................................................................Check
Cargo compartments ........................................................................................................Check
Ram Air deflector door ...................................................................................................As Required
Flight Control Surfaces ………………………………………………..Unobstructed/Free of fluid leaks
Fuel Measuring Sticks ........................................................................................................Stowed
Wing Surfaces ........................................................................................................Check
A and B hydraulic reservoir quantity indicators ……………………………………………RF or higher
APU fire control handle …………………………………………………………………………………UP
Outflow valve …………………………………………………………………………………………Open
Tail Skid (800/900) …………………………………………………………………………………..Check
ELECTRICAL HYDRAULIC PUMP switches ………………………………………………………..OF
External Lights …………………………………………………………………………………As Required
Revision
Exterior
Revision
Rimosso dallo staff [JT8D]: dato che siamo su un forum pubblico, non è il caso di pubblicare in chiaro indirizzi mail o altri recapiti elettronici. Esistono gli mp per comunicarsi queste cose.
grazie mille potrei avere il tuo messenger !!?? graziee
