Inconveniente ad A380 durante il pushback
MADMO 78
Messaggio da MADMO 78 »
Singapore: aereo sbanda in partenza, lievi danni
11 gen 07:33 Esteri
SINGAPORE - Un airbus A380 della Singapore Airlines e' uscito ieri sera dalla pista mentre si preparava a partire alla volta di Sydney. Il velivolo ha subito solo lievi danni, secondo quanto afferma la compagnia aerea. A bordo si trovavano 446 passeggeri, tutti rimasti illesi. (Agr)
:oops:
Cosa può essere successo???
Titolo modificato per maggiore chiarezza [JT8D]
beluga
Messaggio da beluga »
Articolo da Channel news Asia
Non è proprio sbandato...è andata un po' diversamente....
Forse sarebbe meglio spostare questo thread nell'area appropriata (INCIDENTI/INCONVENIENTI)
SINGAPORE : A Singapore Airlines A380 plane accidentally ended on the grass verge off the tarmac at Changi Airport's new Terminal 3 on Thursday.
Flight SQ221 involved in the incident was scheduled to depart Singapore for Sydney at 8.30pm.
SIA says a tow truck used to push back the aircraft experienced some hydraulic failure. The truck disconnected from the plane.
The plane then rolled off the tarmac, onto a grass verge.
The airline says the plane was not under its own power at the time.
The aircraft's 446 passengers disembarked so the plane can be positioned back onto the tarmac.
SIA says three-quarters of the passengers have been put on a replacement flight to Sydney on a Boeing 747 aircraft, which took off slightly past midnight.
The rest were put on flights to other destinations in Australia.
Some passengers stayed overnight in Singapore and took the first flight out to Sydney the next day.
No one was injured in the incident and SIA says there was no major impact on the aircraft as well.
However, it will investigate the incident and is filing reports with the relevant Singapore authorities.
Mr Steve Forshaw, SIA Spokesperson, said: "It would appear that the impact is quite small. We'll need now to conduct a thorough investigation on the aircraft to make sure all the aircraft components at the landing gear level that have come into contact with the grass are okay. If we need to replace them, we will before the aircraft comes into service." - CNA/vm/de
Warnehmung / Constatazione
Bertolt Brecht
MADMO 78
Praticamente il trattore che faceva il push back si è sganciato e l'A380 è finito nell'erba??!!!!
Ho capito bene
Sposto il thread in area inconvenienti.
beluga
MADMO 78 ha scritto:Praticamente il trattore che faceva il push back si è sganciato e l'A380 è finito nell'erba??!!!!
Ho capito bene
sembrerebbe essere andata così
Bertolt Brecht
aponus
Messaggio da aponus »
Quindi non sarebbe colpa di un errore progettuale delL'A380.
francesco.mi
Messaggio da francesco.mi »
aponus ha scritto:Quindi non sarebbe colpa di un errore progettuale delL'A380.
Direi di no... :roll:
Sarebbe da modificare il titolo ;)
aereo sbanda in partenza? [smilie=to funny.gif] [smilie=to funny.gif]
io aggiungerei anche come fanno di solito "tragedia sfiorata" :lol: :lol:
araial14
Messaggio da araial14 »
BA.ALE ha scritto:aereo sbanda in partenza? [smilie=to funny.gif] [smilie=to funny.gif]
Aspetta che la notizia sia riportata da un giornalista italiano...e vedrai! :wink: Scommettiamo? :lol:
dragonball
Messaggio da dragonball »
la notizia data da ns. giornalisti potrebbe suonare così: :D
Sfiorata la tragedia per un Piper PA380 che sbanda in fase di decollo...illesi ma terrorizzati gli oltre 400 passeggeri. Si pensa ad un errore di progettazione.
beluga
Vado un po' O/T: nel frattempo Singapore Airlines ha ricevuto il 2° A380 (fonte Dedalonews.it)
Articolo
Bertolt Brecht
Tixio
Messaggio da Tixio »
dragonball ha scritto:la notizia data da ns. giornalisti potrebbe suonare così: :D
Mah, più o meno potrebbe anche essere tipo: ATTENTATO! :roll:
Tixio®
SI TRATTA DI ATTENTATO!!!!! :D:D:D:D:D:D:D:D:D
Gozer
Messaggio da Gozer »
Infatti, proprio questo avevo in mente :lol: :lol: :lol:
po-paolo
Messaggio da po-paolo »
evidentemente siamo di fronte a una ... emergenza volo!
FAS
Messaggio da FAS »
foto
Ultima modifica di FAS il 21 gennaio 2008, 12:46, modificato 1 volta in totale.
Mach
Messaggio da Mach »
Ma questo A380 è stato già riparato, o è ancora in manutenzione?
Messaggio da Maxx »
Probabilmente sarà radiato.
FAS
Messaggio da FAS »
Maxx ha scritto:Probabilmente sarà radiato.
maxx ti invito per l´ennesima volta a non scrivere stupidate in quest´area
grazie!
Messaggio da Maxx »
FAS ti invito ad essere un pò meno intollerante con le frasi scherzose. Sottolineerei l'"ennesima volta", che significa che si sostiene che io spesso scrivo stupidate in quest'area: questo sono io a non poterlo tollerare e, in assenza di spiegazioni, non scriverò più nulla nel forum.
Ultima modifica di Maxx il 21 gennaio 2008, 12:53, modificato 1 volta in totale.
FAS
Messaggio da FAS »
Maxx ha scritto:FAS ti invito per l'ennesima volta ad essere un pò meno intollerante con le frasi scherzose. Sottolineerei l'"ennesima volta", che significa che si sostiene che io spesso scrivo stupidate in quest'area: questo sono io a non poterlo tollerare e, in assenza di spiegazioni, non scriverò più nulla nel forum.
non hai bisogno di spiegazioni!
dovresti capirlo da solo leggendo le note introduttive.
Non é la sezione giusta per le frasi scherzose.
Dany80
Messaggio da Dany80 »
Mach ha scritto:Ma questo A380 è stato già riparato, o è ancora in manutenzione?
Credo possa essere rimesso in volo quanto prima... se è solo finto sull'erba a velocità molto ridotta dovrebbero essere verificati in pratica solo i carrelli (soprattutto credo pneumatici e eventuale sporco / terra sui mozzi) e poi, sostituiti gli eventuali pneumatici danneggiati potrà tornare in volo quanto prima...
Non credo che Singapore Airlines voglia negarsi l'utilizzo di uno dei suoi due aerei nuovi fiammanti :)
Daniele
<br>
Scatto88
Messaggio da Scatto88 »
Incredibile il solco che ha lasciato nella foto 2 e lo stampo del pozzetto di cemento della foto 3 rimasto sul pneumatico..
rendono veramente bene l'idea del peso del velivolo..
FAS
Messaggio da FAS »
Scatto88 ha scritto:Incredibile il solco che ha lasciato nella foto 2 e lo stampo del pozzetto di cemento della foto 3 rimasto sul pneumatico..
Il numero di ruote del MLG (main landing gear = carrello atterraggio principale) e la loro geometria sono state studiate per ridurre al minimo il pavement loading (carico sul pavimento). Il 380 ha 20 ruote sul carrello centrale, facendo risultare meno peso per ruota rispetto al 777-300 ER (27 t per A380 28 t per 777-300ER).
Scatto88
beh 27t non sono certo poche..
che livello di danni può aver subito?
cioè,che controlli verranno effettuati prima di rimetterlo in volo(oltre a quelli citati da dany80)?
FAS
Messaggio da FAS »
Minor damage, la struttura non ha subito danni.
Alcuni dei pnumatici sono stati sostituiti
cioè,che controlli verranno effettuati prima di rimetterlo in volo?
é stato controllato ogni carrello, in particolare sono stati controllati i freni per assicurarsi che non ci siano state contaminazioni.
Toeloop
Messaggio da Toeloop »
Chiedo scusa per la domanda da profano quale sono: ma solitamente durante il push back non c'è una persona che *accompagna* l'aereo restando collegato tramite cuffia e microfono con la cabina di pilotaggio? Dal momento che dicono che il trattore si sia sganciato, non poteva chiedere ai piloti di azionare il freno per evitare che il 380 finisse nell'erba?
N757GF
Messaggio da N757GF »
Toeloop ha scritto:Chiedo scusa per la domanda da profano quale sono: ma solitamente durante il push back non c'è una persona che *accompagna* l'aereo restando collegato tramite cuffia e microfono con la cabina di pilotaggio? Dal momento che dicono che il trattore si sia sganciato, non poteva chiedere ai piloti di azionare il freno per evitare che il 380 finisse nell'erba?
Se mentre l'aereo va indietro si frena, si rischia che si sieda sulla coda :)
Maxx ha scritto:FAS ti invito ad essere un pò meno intollerante con le frasi scherzose. Sottolineerei l'"ennesima volta", che significa che si sostiene che io spesso scrivo stupidate in quest'area: questo sono io a non poterlo tollerare e, in assenza di spiegazioni, non scriverò più nulla nel forum.
La tua affermazione "Probabilmente sarà radiato" non era messa giù in modo scherzoso. Quindi una persona inesperta potrebbe anche prenderla per vera, quando invece sappiamo tutti che è fortemente inesatta. Quindi non te la prendere, perchè il richiamo di Marcello è giusto: questa è un'area tecnica in cui è importantissima ed essenziale la correttezza delle informazioni. Non è certo l'area per divagazioni più o meno scherzose.
