Avro Lancaster
Black Magic
Avro Lancaster
Messaggio da Black Magic »
Parlavamo di B2...questo e` il bisnonno ;)
Details for Lancaster I
Length: 69ft 4in (21.08m)
Wingspan: 102ft 0in (31.00m)
Height: 20ft 6in (6.23m)
Maximum Speed: 287mph (462km/h)
Cruising Speed: 200mph (322km/h)
Ceiling: 19,000ft (5,793m)
Range: 2,530 miles (4,072km) with 7,000lb (3,178kg) bomb load.
Powerplant: Four Rolls Royce Merlin XX, 22 or 24 of 1,280hp each.
Payload: Up to 22,000lb bombs carried internally. Later versions modified to carry a variety of single high explosive bombs of 8,000lb (3,632kg), 12,000lb (5,448kg) or 22,000lb (9,988kg) for special missions.
Defensive Armament: 2 x .303 Browning machine guns in nose turret, 2 x .303 Browning machine guns in mid-upper turret and 4 x .303 Browning machine guns in tail turret. Early models also had ventral turret with a single .303 machine gun. Special versions were stripped of aramament to carry increased bombloads.
Recognition: Slab-sided fuselage with heavily-framed canopy mounted well-forward on the upper fuselage. Nose, tail and upper rear fuslage contain turrets housing defensive guns. Twin tail unit with unswept horizontal surfaces. main undercarriage housed in the cowlings of the inner engines. Some aircraft had the H2S radar bulge aft of the bomb-bay while a few other carried a mid-lower gun-turret.
Ora qualche immagine.
Magnifico!
Morpheus7
Messaggio da Morpheus7 »
wow che bello rivedere i miti è davvero fantastico a un qualcosa che non so ,che lo rende affascinante ai miei occhi stupendo comunque dove hai fatto le foto?
Immagine Luigi G. :indian:
Black Magic
Al British imperial war museum di Duxford.
Quell`aereo non e` un modello satico; vola ancora.
Morpheus7
fichissimo non imaginavo beh guardandolo bene è ancora ben tenuto davvero stupendo mi piacerebbe tantissimo poterci salire e fare un bel voletto FICO
pippo682
Messaggio da pippo682 »
Belle le immagini dell'interno.
Nicolino
General Aviation Technician
Messaggio da Nicolino »
Bellissimi!!! Grazie Black!!!
Nicolino
Black Magic
RR Merlin
Aggiungo con piacere qualche foto e i dati del propulsore.
Raga` perdonatemi, ma io so` drogato per gli aerei militari a pistoni...:lol:
Model: Rolls-Royce Merlin V-1650-9
Application All models
Engine Type: V-12 Piston Aero Engine, 60° "V" (angle between banks)
Material: Aluminum heads, water jacket, crankcase; Steel cylinder liners; Forged aluminum alloy pistons
Bore x Stroke 5.4" x 6.0"
Compression Ratio 6.00:1
Supercharger type: Two stage engine driven supercharger, 12.0" first stage, 10.1" second stage
Supercharger Ratio: 6.391 (low blower), 8.095 (high blower)
Anti-detonation: 50:50 water-methanol injection anti-detonation injection (ADI)
Fuel System: Bendix-Stromberg PD18, Type G-9 pump, 9 psi idling, 12-16 psi operating
Weight: 1,690 lbs
Power: 1735 bhp @ 3000 rpm 66" boost
Rotation: CCW crankshaft rotation when viewed from supercharger end
Cylinder ID: Bank: Right - A, Left - B when viewed from supercharger; "A" has oil regulator; 1-propeller end, 6-supercharger end
Firing Order: 1A-6B-4A-3B-2A-5B-6A-1B-3A-4B-5A-2B,
Spark Plug: 14mm thread, 0.011-0.014" gap
Magneto: BTH C6SE12S/2 (Ex: AN SF 12RG-P-3 or SF 12RA-P-3, In: AN SF 12 LG-P-3 or SF 12LA-P-3)
Northeast (Ex: AN SF 12RA-P-4, In: AN SF 12LA-P-4)
Magneto Direction: Exhaust Side -- CW, Intake Side -- CCW, viewed from driving end
Spark timing Fully Advanced: Intake 45° btc, Exhaust 50° btc, Magneto breaker gap 0.011-0.014
Cam Timing (crank degrees) Intake: Valve opens 31° BTDC, Closes 52° ABDC, 0.015" clearance (cold), 0.590" max lift -- Note: Time w/0.020
Exhaust: Valve opens 72° BBDC, Closes 12° ATDC, 0.020" clearance (cold), 0.590" max lift 263° intake duration, 264° exhaust duration
Note: Tappet clearance for timing -- 0.020"
Averadge Cost: £15,000 (2007)
Slowly
Messaggio da Slowly »
Certo che potremmo anche organizzarlo un raduno a un museo eh?
Il più bello e più vicino?
:roll:
dragoIV84
Messaggio da dragoIV84 »
Quando si puo' organizzare un raid da quelle parti????
China su fronte chi ses sezzidu pesa! Ch'es passende sa Brigata Tattaresa!
FORZA PARIS
Slowly
MI, in UK intendi?
Magari! ma saremmo in pochi.
Un museo italiota? :oops:
Black Magic
A me quello dell`AM a Vigna di Valle (Bracciano RM) e` sempre piaciuto.
Hanno un sacco di pezzi di pregio.
dragoIV84
Vada per VIGNA DI VALLE, sicuramente più raggiungibile per tutti.
FORZA PARIS
Nicolino
Nicolino dopo la visione del Merlin si dichiara clinicamente invidioso di Black sotto ogni punto di vista :lol:
Nicolino
I-FORD
B777 Captain
B777 Captain
Messaggio da I-FORD »
Magia Nera
magari mi sbaglio ma mi sa che nel costo medio del Merlin (se funzionante) ti manca uno zero.
Grazie per le belle foto e per i dati del propulsore. Bellissimo il RR Merlin :D :D
Nicolino
I-FORD ha scritto:Magia Nera
A quel prezzo lì un pensierino ce lo farei.....quasi quasi me lo monto sul TB10!!!!!
Nicolino
pippo682
Un bel "mostro"!
Black Magic
Sembra strano, lo so.
Rolls Royce fa questi prezzi per un Merlin perfettamente funzionante e revisionato nelle nostre officine.
Ovviamente la condizione per poterlo comprare in RR e` che tu possegga gia` un aereo storico che necessiti di un Merlin (Spitfire, Hurricane...).
In aggiunta viene data consulenza di manutenzione base e fornitura dei ricambi GRATUITA.
Poi il mercato privato dei collezionisti fa speculazioni e prezzi diversi.
Anche se 150,000£ mi sembrano onestamente troppe.
deltagolf
Messaggio da deltagolf »
Black, sai se il Martin Marauder che hanno sbragato a Duxford un paio di anni fa è stato rimesso a posto?
libelle
Messaggio da libelle »
Non ho mai apprezzato particolarmente i bombardieri inglesi per un fatto estetico, ma devo dire che vedere un esemplare in tali condizioni e per giunta volante è sempre una grande piacere. Comunque preferisco il Mosquito appeso che si vede nella prima foto.
Per i musei comunque non è male anche il Deutsche di Monaco, hanno una colleziono piuttosto vasta forse tenuta un pochino peggio rispetto allo standard inglese. Interessantissima è la sezione aeronautica distaccata del Deutsche di Monaco con ulteriori collezioni di aerei e laboratori di restauro.
Black Magic
Sì, pagato dagli yankee.
Ma mi sembra che la certificazione airworth non sia stata rifatta (premio assicurativo troppo alto) e il B26 è in mostra statica nel padiglione americano.
AZ055B-)
Messaggio da AZ055B-) »
MI, in UK intendi?
Un museo italiota? Embarassed
Propongo il Parco Tematico dell'Aeronautica di Rimini 8)
piropiro
Messaggio da piropiro »
Condivido l'entusiasmo di Black Magic per il Lancaster, usato anche da una squadriglia speciale, quella degli "schiantadighe" che mi pare alla fine del '44 attaccò le dighe della Rhur usando una bomba speciale che doveva essere fatta rimbalzare sull'acqua a mò di sasso.. :shock:
Se fra i brit dici Lancaster, spero che fra gli americani sceglierai il B24 Liberator, meno performante del B17, ma stupendo come cassone volante.....e protagonista dell'eroico e sfortunato attacco alle raffinerie di Plojesti in Romania (le perdite furono, se non sbaglio il 70% )
la mia personale classifica fra i bomber della II WW è questa:
1 Lancaster
2 Liberator
3 b25 Mitchell (la versione con cannone in prua per attacco a terra) :x
4 Heinkel HE 111 (bella la prua stile veranda panoramica..)
