Sukhoi PAK-FA ..... forse ci siamo .....
richelieu
Re: Sukhoi PAK-FA ..... forse ci siamo .....
Messaggio da richelieu »
Nuovi motori e nuove armi in arrivo .....
Russia’s T-50 fifth-generation fighter aircraft will enter flight-test with new engines in the fourth quarter of next year.
The Sukhoi-designed jet is also known as Pakfa (Russian acronym for Perspective Aviation Complex of Frontal Aviation).
More detail about the T-50’s weapons fit has recently emerged.
Fonte ..... "New Engines, Weapons for Russian Stealth Fighter" .....
Vultur
Messaggio da Vultur »
Da Komsomol sull'Amur le prime foto dell'ottavo T-50. Così, a spanne, è dipinto come il "55". La produzione in serie dei primi aerei dovrebbe iniziare nel 2017.
http://politikus.ru/industry/88038-suho ... -t-50.html
richelieu
PAK-FA ..... si va verso una nuova fase di collaudi .....
Russia’s T-50 PAKFA fifth-generation stealth fighter is about to undergo flight testing by military pilots for the first time.
The Russian Aerospace Forces (VKS) said on January 6 that it would take delivery this year of five of the aircraft that have been flight-tested by Sukhoi at the Gromov Flight Research Institute (LII) in Zhukovsky.
But the VKS, which since last year has encompassed the Russian Air Force and the Russian Aerospace Defense Forces, made no further mention of any order for production aircraft.
Fonte : AINonline ..... "Russia’s New Stealth Fighter Starts New Test Phase" .....
richelieu
Entro l' anno il nuovo motore .....
According to a spokesperson for the United Engine Corporation, Russia's Sukhoi T-50 (PAK FA) fifth-generation fighter aircraft is expected to carry out its first flight with a new engine in the fourth quarter of 2017.
Fonte: SputnikNews ..... "Russia's T-50 Jet to Get New Engine, Will Carry Out 1st Flight in 4Q 2017 - UEC" .....
richelieu
Secondo AW&ST .....
Russia Delays T-50 Purchase to 2018 .....
(Maxim Pyadushkin, Moscow)
The Russian air force will continue to purchase advanced Sukhoi heavy jets this year, but procurement of Sukhoi’s next-generation T-50 fighter is slipping beyond 2018, Deputy Defense Minister Yury Borisov revealed during his tour across United Aircraft Corp.’s facilities last week.
The air force is expecting more T-50 prototypes this year from the Sukhoi facility in Komsomolsk-on-Amur, in Russia’s Far East, Borisov said.
“Three new aircraft that this facility will deliver in 2017 will join the first stage of [evaluation] trials,” he said.
The first T-50 prototype made its initial flight in January 2010.
Seven prototypes and several airframes have been assembled for ground tests.
According to Borisov, the first stage of the evaluation trials is expected to end in 2018.
After that the military may approve the fighter’s serial production and place the first order.
The T-50 purchases will be included in the new defense procurement plan for 2018-25, which has not been approved.
Sukhoi’s T-50 is intended to replace Russian air force Su-27 and -30 aircraft.
Because of ongoing delays, the air force continues to purchase the latest modifications of the Flanker family.
Dopo numerosi annunci relativi alla prossima entrata in servizio dell' aereo ..... questa sembra essere una chiara smentita a quanto, una volta, solevano dire ..... "Tutto procede secondo i piani prestabiliti" .....
Vultur
richelieu
Si direbbe stiano sperimentando nuove livree .....
Vultur
Presunti ПТБ (PTB: Podvesnye toplivnye baki, o serbatoi di carburante sospesi).
https://vk.com/pakfa
Vultur
Russia e India potrebbero firmare per lo sviluppo dell' FGFA già nella seconda metà del 2017. Tra le specifiche indiane anche il biposto e la lunghissima autonomia senza rifornimento. (La foto del biposto è finta).
https://www.aex.ru/news/2017/5/10/169435/print/
richelieu
Interessante .....
Ora la stessa notizia in inglese ..... http://economictimes.indiatimes.com/new ... 561125.cms .....
..... più facilmente leggibile del russo ..... :mrgreen:
richelieu
richelieu ha scritto:Interessante .....
Non sono passate neanche tre settimane che ..... punto e a capo ..... :lol:
Just when its production was about to take off, the Indo-Russian fifth-generation fighter aircraft appears to be "lost" because Russians are demanding an "unaffordable price for the aircraft," according to a senior Indian Air Force official.
The Russians are demanding more than $7 billion as part of India's share in the development of the FGFA.
The Russian side argues that the higher price is justified because the aircraft's development will include transfer of technology of several high-tech systems.
"India is not in a position to pay this kind of money, and the aircraft project appears to be lost " the official said.
Fonte: DefenseNews ..... "Steep price rise hits Indo-Russian 5th-gen fighter project" .....
In Francia ..... stanno sghignazzando ..... [smilie=to funny.gif]
Vultur
Gli aerei di serie dovrebbero essere stati battezzati: "Su-57". Per il 2020 attesi solo 8 nuovi aerei.
https://topwar.ru/121561-t-50-poluchil- ... su-57.html
richelieu
Il capo delle Forze Aeree russe conferma la nuova denominazione .....
..... "Su-57: Russian Air Force chief confirms 5th-gen fighter jet name" .....
richelieu
Vultur
Sono comparse foto del probabile "Izdeliye 30", o Prodotto-30. I nuovi motori per il Pak-fa nel laboratorio del centro ricerca e produzione motori del Gas-turbine Engineering Research and Production Center "Salyut", a Mosca, nel giorno in cui la struttura compie 105 anni. Non si è certi al 100%, ma è probabile che si tratti di loro. Attualmente il Pak-fa monta il motori AL-41F1 (Izdeliye 117). I nuovi motori dovrebbero avere una spinta a secco pari a 107 kn e a 176 kn con postbruciatore.
https://en.wikipedia.org/wiki/Salyut_Ma ... ssociation
https://life.ru/t/%D0%BD%D0%B0%D1%83%D0 ... nie_tochno
richelieu
Ora gli Indiani, a quanto pare, stancatisi degli estenuanti giri di vàlzer con i Russi sul Su-57 ..... hanno adocchiato lo F-35 .....
Senior IAF leadership recently expressed apprehension to the Ministry of Defence, claiming the proposed FGFA program with Russia does not meet desired requirements like U.S. F-35 fighter type capabilities, disclosed a senior IAF official.
That official added, that “IAF is not keen to continue with the program.”
The proposed FGFA program does not meet desired stealth and cross section features compared to a F-35 fighter, the official explained, thus major structural changes are needed that cannot be met in the existing Russian prototypes.
Fonte: defensenews.com ..... "Indian Air Force wants out of fighter program with Russia" .....
:scratch:
richelieu
Il sindaco di Mosca Sergei Sobyanin visita la fabbrica 'Salyut' .....
phpBB [video]
Vultur
Il Su-57 052 ha testato in un volo di 17 minuti un nuovo motore della serie "Izdeliye 30", che ha sostituito l'AL-41F1 sinistro.
https://topwar.ru/131281-eksklyuzivnye- ... lyami.html
richelieu
Il comunicato ufficiale del Ministero dell'Industria e del Commercio russo .....
..... minpromtorg.gov.ru ..... "СОСТОЯЛСЯ ПЕРВЫЙ ПОЛЕТ ЛЕТАЮЩЕЙ ЛАБОРАТОРИИ Т-50 С ДВИГАТЕЛЕМ 2-ГО ЭТАПА" .....
Anche su: flightglobal.com ..... "VIDEO: Russia flies first Su-57 fitted with new Product 30 engine" .....
Ultima modifica di richelieu il 6 dicembre 2017, 12:00, modificato 1 volta in totale.
richelieu
Post eliminato ..... :oops:
Vultur
00:17 il decollo è senza postbruciatori (mi sembra).
richelieu
Da AINonline ..... qualce ulteriore dettaglio sul nuovo motore .....
The Item 30 engine is described as a generation ahead of the AL-41FM1 that powers the other Su-57s.
It provides about two tonnes more thrust at takeoff, at 17,000 kg (37,500 pounds) and therefore gives a notable boost to the Su-57’s thrust-to-weight ratio.
Unlike the older practice of one design bureau heading the development process, the new engine is a joint effort of several specialized design houses and engineering teams at manufacturing plants, each taking work packages from the central office of the United Engine Corporation (Russian acronym ODK).
Key companies taking part in the development effort for the Item 30 are UMPO in Ufa, Saturn in Rybinsk, and Salut in Moscow.
..... "Powerful New Engines Take Flight on the Sukhoi Su-57" .....
Vultur
Mosca. 6 gennaio. INTERFAX.RU - Il decimo prototipo del caccia della quinta generazione Su-57 (PAK FA) ha iniziato i test di volo, ha dichiarato la United Aircraft Corporation.
Con quali motori ha volato ancora non si sa.
A giudicare dalle foto pubblicate da UAC (ancora non trovate), il primo volo del decimo prototipo si è svolto il 23 dicembre 2017.
http://www.interfax.ru/russia/594519
richelieu
Secondo svariate fonti .....
..... http://www.thedrive.com/the-war-zone/18 ... s-to-syria .....
..... http://www.news.com.au/technology/innov ... c43e04038d .....
..... https://sputniknews.com/middleeast/2018 ... -fa-syria/ .....
..... https://warisboring.com/russias-stealth ... ous-farce/ .....
..... http://www.janes.com/article/78119/russ ... n-in-syria .....
..... i Russi avrebbero inviato un paio si Su-57 in Siria .....
Non è dato sapere, almeno per il momento, se la notizia risponda a verità nè quali siano i motivi che hanno portato alla decisione di inviare velivoli non ancora completamente testati in una zona di guerra il cui cielo è assai 'trafficato' .....
:scratch:
richelieu
La notizia era dunque vera .....
I due aerei sono stati infatti fotografati da un satellite israeliano .....
..... http://www.jpost.com/Middle-East/Stealt ... ria-543510 .....
richelieu
Sputnik News, citando il quotidiano Kommersant, conferma la presenza in Siria di quattro Su-57 che sono stati colà inviati allo scopo di proseguire la sperimentazione degli apparati di bordo in prossimità di zone di guerra ..... ma non per prendere parte ad operazioni di combattimento .....
..... https://sputniknews.com/military/201802 ... ent-radar/ .....
richelieu
Il commento di RID .....
..... "Su-57 in Siria: ragioni e rischi" .....
richelieu
La preoccupazione di Israele ..... :scratch:
Israeli sources assess that Russia has sent dozens of new weapon systems to Syria, to undergo testing under combat conditions.
But the Su-57's arrival – which places two of the world's most advanced stealthy combat aircraft within close proximity – creates a unique situation.
While Israel has not reacted officially to the development, a senior source says there is no doubt that Moscow has sent its newest fighter to the region in order to test it against Western technologies.
Fonte: flightglobal.com ..... "Israel concerned over Su-57 debut in Syria" .....
Vultur
I quattro Su-57 inviati in Siria sono tornati in Russia da una settimana, dopo aver eseguito tutta una serie di tests, durante due giorni di operazioni in ambiente reale. Secondo il ministro della difesa Sergey Kuzhugetovich Shoygu, gli aerei erano accompagnati da una serie di altri velivoli di appoggio e registrazione dati. Sempre secondo Shoygu le foto da satellite pubblicate in giro non sarebbero attendibili: i Su-57 in Siria sono stati parcheggiati in hangar.
https://tvzvezda.ru/news/opk/content/20 ... 7-3tfk.htm
richelieu
Questo ..... secondo Sputnik News ..... https://sputniknews.com/middleeast/2018 ... sts-syria/ .....
Russian Defense Minister Sergei Shoigu confirmed on Thursday that two Russian fifth generation Su-57 fighter jets were carrying out two-day combat testing missions in Syria.
The statement was made after the Russian Kommersant newspaper reported, citing its military sources, that the Russian fifth-generation Su-57 fighter jets had been deployed to Syria to test radar systems and electronic warfare.
..... https://sputniknews.com/middleeast/2018 ... l-reports/ .....
However, the minister called the satellite images of the Su-57 in Syria, previously circulating in the media, fake as the jets were kept in hangars and never stood side by side.
"Concerning the various satellite photos, I can say that it's not 95 [1995] anymore - such planes never stand alongside each other," Shoigu told reporters.
"The photos that were published - I do not know where they came from, because all the planes were in shelters all this time. I hope that this year we will complete a full cycle of tests and this will be another surprise for our colleagues," he stated.
The Russian top military official specified that the jets had returned to Russia a week ago.
Dunque gli aerei, secondo quanto dichiarato da Shoigu, sarebbero stati soltanto due e non quattro (come era stato lasciato trapelare da alcune fonti russe ..... Sputnik News compresa) e la loro permanenza in Siria sarebbe stata, in realtà, una sorta di 'tocca e via' .....
A meno che, se si fosse trattato veramente di quattro velivoli, questo starebbe a significare che gli altri due sono tuttora presenti nel paese mediorientale .....
:scratch:
Vultur
Foto del prototipo numero 10. Ha volato per la prima volta il 23 dicembre 2017.
https://sdelanounas.ru/blogs/104594/
Vultur
Prototipo numero 11 a Zhukovsky. RF-81775.
"Vale la pena notare una certa confusione con i lati. A causa di una serie di circostanze, il decimo prototipo di volo - T-50-11 - volò prima del nono (il nuovo T-50-10). Ha volato per la prima volta il 6 agosto 2017. Allo stesso tempo, entrambe i mezzi si riferiscono al cosiddetto "Prototipi del secondo stadio". Cioè, questi combattenti sono il più vicino possibile alla versione seriale. Contrariamente alla credenza popolare, i "prototipi del secondo stadio" non sono dotati di motori "Tipo 30". Quest'ultimo solo in fase di test: molto probabilmente la produzione iniziale di Su-57 non avranno motori di "seconda fase", e [solo] il AL-41F1 - una profonda modifica del Soviet AL-31F.
Una maggiore attenzione alla copia del T-50-10 è dovuta al fatto che essa completa il lotto pilota del combattente russo di quinta generazione. Già nel prevedibile futuro, progettano di avviare la produzione in serie dell'aereo".
https://naked-science.ru/article/tech/p ... oto-samogo
Vultur
Due Su-57 parteciperanno per la prima volta alla parata per il giorno della vittoria a Mosca, il 9 maggio. Per allenarsi in previsione della parata, gli equipaggi della VVS hanno già raggiunto le basi intorno a Mosca, Kaluga, Tver, Voronezh, Saratov, Lipetsk e Nizhny Novgorod. Quasi tutti gli aerei sorvoleranno la Piazza Rossa a 150 metri e a una velocità di 200 Km/h, tranne quelli dell'aviazione a lungo raggio e i trasporti, che per ragioni di sicurezza voleranno sopra i 300 metri a una velocità fino a 600 Km/h.
https://www.m24.ru/news/tehnologii/09042018/29857
Vultur
Due Su-57 alla parata di Alabino, prova di quella del 9 maggio a Mosca. Dovrebbe trattarsi dello 053 e 054 (lo 054 porta una nuova mimetica pixelata, perchè prima era a "splinters").
E lo 055, che porta otto stelle rosse. Missioni in Siria?
http://visualrian.ru/story/list_567039/
richelieu
A Zhukovsky..... nell' imminenza della Parata della Vittoria .....
phpBB [video]
В подмосковном Жуковском прошли тренировочные полеты пилотов новейших российских истребителей пятого поколения Су-57 (ПАК ФА), которые готовятся впервые принять участие в Параде Победы.
