Sukhoi PAK-FA ..... forse ci siamo .....
richelieu
Re: Sukhoi PAK-FA ..... forse ci siamo .....
Messaggio da richelieu »
FGFA ..... l' India, costretta a scendere a compromessi, tenta ora di smussare gli spigoli .....
However, a final agreement, which will release a payment of about $6 billion as India's share in FGFA development, has yet to be inked because of conflict over issues relating to work share, a firm aircraft order from the Indian Air Force, its desired mix of single- and double-seat aircraft, and changes demanded by the Indian Air Force.
The Defence Ministry wants to reach an agreement, will not insist on the Indian work share at this stage and will agree to delivery of single-seater aircraft as against the earlier demand of two-seaters, the source added.
A firm order of 154 FGFAs will also be included in the draft agreement, the source said.
Fonte ..... "India Compromises To Smooth FGFA Disputes" .....
http://www.defensenews.com/story/defens ... /28730155/
richelieu
Il radar è quasi pronto .....
"MAKS: Russia’s T-50 radar almost ready for serial production" .....
http://www.flightglobal.com/news/articl ... on-416112/
richelieu
Ed ora si parla di almeno un anno di ritardo .....
Russia’s answer to the American F-22 and F-35 aircraft, the PAK FA T-50, will enter service with the Russian Armed Forces in 2017, Russian Air and Space Forces Commander Colonel-General Viktor Bondarev said over the weekend.
“Under the program, we will finish testing next year and will begin to receive the T-50 jets in 2017,” Bondarev told Sputnik News.
Back in June, during the Paris Air Show, the head of United Russia’s Aircraft Corporation, had still talked about a potential 2016 or early 2017 induction date.
However, serial deliveries are now slated to begin in 2017.
Fonte ....."Russia’s First 5th Generation Fighter Jet to Enter Service in 2017" .....
http://thediplomat.com/2015/09/russias- ... e-in-2017/
Vultur
Messaggio da Vultur »
Qualche bella foto non so se ne avete già parlato, ma forse c'è almeno una differenza, anche se le angolazioni sono diverse:
Beh, non credo possa esservi una variante senza derive, il primo sembra semplicemente essere incompleto (mancano anche almeno gli ugelli dei motori se non gli stessi nel loro insieme)
richelieu
La prima immagine ..... http://russianplanes.net/id175145 ..... non identifica neanche di quale prototipo si tratti e risale al Dicembre 2014 .....
La seconda ..... http://russianplanes.net/id173717 ..... mostra il prototipo 054 ed è datata 30 Agosto 2015 .....
Entrambe sono state scattate a Ramenskoye .....
Le pagine del sito 'russianplanes.net' dedicate al Sukhoi T-50 .....
http://russianplanes.net/search.php?sereq=T-50
Vultur
I motori di quello smontato mi sembra che non sono in metallo naturale, sarà un mock up o un aereo vero? Pero, se è un mock up, perché coprirlo e proteggerlo in quel modo?
richelieu
Vultur ha scritto:I motori di quello smontato mi sembra che non sono in metallo naturale, sarà un mock up o un aereo vero? Pero, se è un mock up, perché coprirlo e proteggerlo in quel modo?
Se guardi attentamente l'immagine ti potrai rendere conto che a quell' aereo manca probabilmente l' intera sezione di coda e, forse (ma è una questione di prospettiva), parte delle ali ..... ed ho anche l' impressione che i motori non siano neppure installati .....
Potrebbe essere un prototipo proveniente dalla fabbrica (che si trova a Komsomolsk sull' Amur nell'estremo oriente russo) appena trasportato, parzialmente smontato, in aereo a Ramenskoye ove si tengono le attività sperimentali .....
La mancanza di pitturazione definitiva potrebbe esserne la prova .....
A meno che non si tratti dell' esemplare 055, che andò a fuoco nel Giugno 2014, in fase di spostamento da un reparto ad un altro, all' interno della base, nel corso dei lavori di riparazione .....
Ma sono soltanto mie ipotesi ..... :dontknow:
"Sukhoi T-50 Prototype Suffers Fire On Approach To Land" .....
http://www.ainonline.com/aviation-news/ ... roach-land
MatteF88
Messaggio da MatteF88 »
Mi pare abbiano semplicemente coperto i buchi delle parti mancanti per non far entrare porcherie varie.
Vultur
E' che di notte ho l'insonnia, ma a me sembra che:
1) Il cono di coda sporge tra i motori (freccia verde). Questo normalmente.
2) Prendendo come riferimento il cono di coda e due punti in cui scorrono gli attuatori (si dice attuatori?) dei due piani orizzontali di coda, frecce gialle (che sono coperti in quello smontato),
si vede che le superfici finora normalmente in metallo naturale (secondo me comprese grossomodo tra le freccie rosse che c'ho messo), nell'aereo smontato sono verniciate (mancano i motori certo e gli ugelli di scarico). Se invece dovessero prenderlo così com'è e aggiungerci i motori, il cono di coda non sporgerebbe più ma sarebbe dentro, tra i due ugelli. O no? (parlo da ex modellista a tempo perso).
MatteF88
Ah, beh alcuni esemplari hanno effettivamente il cono di coda accorciato o di forma diversa rispetto al primo (o ai primi) prototipi.
Ma qui non sappiamo che aereo è..
Vultur
Forse sono solo parti provvisorie, poi al posto loro ci montano i motori. La foto dell'aereo smontato e trainato è la prima che viene fuori battendo T-50 sotto поиск фотографий, su Russian Planes.
Vultur
L'aereo di cui parlavo sopra dovrebbe essere lo stesso scaricato a Zhukovsky con un Antonov-124-100 proveniente da Komsomolsk (parecchi mesi fà tra l'altro). Sarebbe uno dei due prototipi inizialmente designati come "06", in realtà secondo quel che c'ho capito io erano tre:
PAK-FA T-50-6-0 : aereo non completato, perchè le sue parti sarebbero servite per riparare il T-50-5 che aveva preso fuoco.
PAK-FA T-50-6-1 : ridesignato (e forse si vedrà con il serial 57) T-50-7 e dovrebbe essere il primo volante della seconda serie, con diversi cambiamenti.
PAK-FA T-50-6-2 : dovrebbe essere quello della foto in cui è scaricato dell'Antonov-124. Sarebbe il primo prototipo della seconda serie e sarebbe destinato a prove statiche e dinamiche a terra. I motori (o comunque gli alloggiamenti dei motori) a me sembrano proprio non più in metallo naturale, ma coperti o verniciati.
In costruzione (tutti seconda serie) ci sarebbero i T-50-8, 9, 10 e 11. Tutti seconda serie e vicini al completamento tra la fine dell'anno e i primi del 2016. Si parla di cambiamenti nei motori, cambiamenti aerodinamici, un HUD a 360° (forse nel casco) e altro.
http://sdelanounas.ru/blogs/56889/
Vultur
T-50-5R pare riprendere il volo dopo l'incidente, con una mimetica che mi sembra diversa da quella di prima, sotto è molto chiara. La foto in basso come località dà Kansk in Siberia.
richelieu
Dai commenti all' immagine si direbbe si tratti di un ibrido ..... http://russianplanes.net/id179241
Per la ristrutturazione sarebbero stati utilizzati elementi prelevati dal prototipo n. 6 ..... di cui era stata interrotta, a suo tempo, la costruzione .....
Qui alcuni dettagli ..... http://www.rg.ru/2015/10/21/pak-site-anons.html
Vultur
dai commenti, qualcuno lo chiama акула (akula), cioè squalo, per via del grigio scuro sopra e bianco sotto. I motivi di questa diversità rispetto agli altri prototipi non li conosco.
In una visita dello scorso 26 novembre, probabilmente a scopo promozionale, all'ufficio Sukhoi, il sindaco di Mosca Sergey Sobyanin (con i capelli bianchi) si fa ritrarre vicino a diverse "cose" che mi paiono interessanti. Nella undicesima foto si vede la coda di un nuovo prototipo in costruzione, anche qui a me sembra che ci sono rivestimenti sopra alle sedi dove verranno montati i motori:
https://www.mos.ru/press/media/photo/4718057
richelieu
La prima immagine, che risulta essere stata scattata a Ramenskoye, porta la data di oggi .....
http://russianplanes.net/id179323
Vultur
Si portava quella data, perchè?
Un paio di idee che mi sono venute, ma non ho niente che le comprovi: qualcuno ha usato il termine "akula", cioè squalo. Gli squali stanno in mare. La colorazione del T-50-5R è scura sopra, bianca sotto, come quella di molti aerei di marina.
Altra cosa: forse i prototipi con sedi dei motori (apparentemente) rivestite sono aerei solo per prove a terra.
richelieu
Vultur ha scritto:Si portava quella data, perchè?
Significa che in quella data l'aereo si trovava ormai a Ramenskoye, presso Mosca, e non più nell' Estremo Oriente russo .....
Quanto al resto ..... sembra che ne sia prevista una versione navale .....
http://www.aame.in/2013/07/naval-t-50-p ... -navy.html
richelieu
Secondo 'AIR & COSMOS' .....
"PAK FA: les essais sont terminés" ..... http://www.air-cosmos.com/pak-fa-les-es ... ines-52375
richelieu
A Ramenskoye ..... lo scorso Febbraio .....
http://russianplanes.net/id184433
..... risplendente nella nuova livrea .....
MatteF88
L'esibizione dello scorso anno al MAKS 8)
si vede abbastanza bene il movimento differenziale di quelle specie di flap sopra le prese d'aria mentre l'aereo scende tipo foglia morta..
richelieu
Vultur
Dovrebbe trattarsi di due kh-31 e due rvv-md. I primi hanno una versione antinave, gli rvv-md avrebbero anche le ali ripiegabili.
La versione antinave è quella che interessa la marina indiana, forse sarà biposto e potra portare anche il Brahmos (come anche i Tu-142 e i Su-30).
Vultur
Probabilmente ci saranno i corrispondenti video russi. Credo che sia cosa può succedere se i carichi appesi fuori non sono aerodinamicamente compatibili (si può dire così?) con l'aereo e con la sua scia.
richelieu
Vultur ha scritto:Probabilmente ci saranno i corrispondenti video russi.
:shock: :wohow:
richelieu
Prove ad alta intensità .....
The Sukhoi T-50 PAK-FA 'fifth-generation' combat aircraft has conducted trials of munitions launched from its internal weapons bays for the first time, the former commander-in-chief of the Russian Aerospace Forces (VKS) told state TV.
General Vladimir Mikhailov made the announcement, but the claim has not been confirmed by any other sources, and neither has it been disclosed which weapon types were launched during the trials.
Fonte ..... (216 of 346 words) ..... "Russian PAK-FA carries out intensive weapon testing" .....
Vultur
Il prototipo T-50-6-2, con livrea simile allo 055, ma con i motori ricoperti:
http://bmpd.livejournal.com/1918216.htm ... =192868104
richelieu
Da quel blog svizzero col punto esclamativo ..... !
"Calendrier respecté pour le Sukhoi T-50 !" .....
richelieu
Completata la fase iniziale dei collaudi .....
The Russian aircraft manufacturer Sukhoi has declared a flight test milestone for the T-50, before handing over the fifth-generation fighter to the Russian government for additional testing.
Sukhoi completed more than 700 flight tests, which confirmed aircraft requirements set by the Russian ministry of defense .....
Fonte ..... "Sukhoi completes initial flight tests on T-50" .....
richelieu
Sukhoi T-50/PAK-FA ..... i dubbi abbondano ..... in particolar modo quelli di provenienza USA ..... :usa
he PAK FA has played the bugbear for Western air forces for nearly a decade, the terrifying Russian jet that will eat F-35s for breakfast.
American aviation analysts in search of something, anything that might threaten U.S. air dominance settled on the PAK FA, a frankly evil looking jet that bore a very mild resemblance to the MiG-31 “Firefox” that Clint Eastwood made famous.
Say what you will about the F-35, but Lockheed Martin has actually built and delivered one hundred and seventy one aircraft thus far.
The Russian Air Force, meanwhile, has yet to receive its first PAK FA.
Fonte ..... "Russia's PAK FA Stealth Fighter: The US Air Force's Worst Nightmare?" .....
Vultur
Si legge in giro degli studi sia americani che russi su un nuovo tipo di radar che, invece di microonde elettromagnetiche, userebbe un fascio di fotoni generati da laser: il "quantum radar", o "radar a fotoni". Questo tipo di radar potrebbe rendere inutile la tecnologia stealth.
anonymous12345
Messaggio da anonymous12345 »
Beh il lidar è già realtà .. viene usato un molti anni..
Vultur
Non ne so niente, ma leggendo mi sembra che si parli di una tecnologia ancora alla fase embrionale, non in uso da anni.
Vultur
