JSF
richelieu
Re: JSF
Messaggio da richelieu »
A quasi due mesi dall'incidente ..... un ulteriore allentamento delle restrizioni ..... ma solo per i velivoli impiegati nei collaudi ..... mentre l'Esercito riesce ad ottenere la sua fettina di torta .....
The F-35 Joint Strike Fighter test fleet will be able to fly six hours between engine inspections for weapon test and refueling missions, as restrictions on the fifth-generation fighter continue to ease.
Previously, the entire F-35 fleet was limited to three hours of flight time before an engine inspection was required as an investigation continues into a fire that heavily damaged an F-35A model on June 23.
Fonte ..... "Further Restrictions Lifted for F-35 Test Fleet; Army Awarded Contract" .....
http://www.defensenews.com/article/2014 ... d-Contract
richelieu
Re: JSF
Ecco quanto riporta questa mattina il "Daily Report" dell'AFA .....
http://www.airforcemag.com/DRArchive/Pa ... Eased.aspx
The F-35 program office said investigators are still working to pinpoint the exact cause of the fire at Eglin, although they have tentatively said a fan blade rotor was excessively rubbing against the engine casing.
Program officials said fixes under consideration range from an engine redesign to establishing a “break-in” period for each motor that would allow for the gradual contraction, expansion, and strain on the engine to prevent premature structural cracking.
However, a final solution awaits a definitive “root cause” for the fire.
Mica tanto incoraggiante ..... :mrgreen:
richelieu
Re: JSF
Per gli F-35 norvegesi ..... un parafreno ad hoc .....
"Cold Stops" ..... http://www.codeonemagazine.com/article.html?item_id=138
richelieu
Re: JSF
Alcuni giorni fa avevo segnalato l'editoriale (non firmato) apparso sull'ultimo numero di 'AW&ST' .....
richelieu ha scritto:Editoriale ..... dall'ultimo numero di 'AW&ST' .....
"JSF Program Has Some Explaining To Do" ..... http://aviationweek.com/defense/editori ... laining-do
Mi permetto di attirare nuovamente l'attenzione su di esso ..... in quanto, in seguito alla sua pubblicazione, si è scatenata, fra i seguaci della rivista, una discussione alquanto rovente che, ritengo, sia meritevole di essere letta .....
:wink:
richelieu
Re: JSF
L'ultima spiaggia ..... ora si rivolgono all'Esercito ..... #-o
The F-35 Joint Strike Fighter program will soon be getting Army assistance for the safety analysis of the next-generation strike aircraft’s flight software, which is essential to the combat operation of what is the most complex and expensive weapons program in the military’s history.
The Joint Strike Fighter program office selected the Army Aviation and Missile Research Development and Engineering Center’s Software Airworthiness and Safety Lab, or SASL, to perform independent software safety analyses of the plane .....
Fonte ..... "Army lab to provide software analysis for Joint Strike Fighter" .....
http://defensesystems.com/Articles/2014 ... 814&Page=1
MatteF88
Re: JSF
Messaggio da MatteF88 »
Pista bagnata e vento al traverso
sidew
Re: JSF
Messaggio da sidew »
Fa strano vedere il FBW usare gli elevoni di coda a mo di flaps, aerofreni, e alettoni nello stesso tempo...
Aldo
richelieu
Re: JSF
Dichiarazioni (invero alquanto caute) del CSM-USAF generale Welsh e dei portavoce di P&W e JPO ..... in relazione alla prossima (?) soluzione dei problemi motoristici che hanno portato alla 'devastazione' di un F-35A poco più di due mesi fa .....
Engine manufacturer Pratt & Whitney is close to performing tests on a potential design change for its F135 engine following a June incident that led to the devastation of an F-35 Joint Strike Fighter.
Fonte ..... "USAF Chief: Pratt Close To Developing F-35 Engine Fix" .....
http://www.defensenews.com/article/2014 ... 308280040/
richelieu
Re: JSF
Non recentissimo ..... ma interessante .....
The F-35 joint strike fighter may well come to rule the skies of the future, but for decades to come it will need to work with existing “fourth-generation” fleets.
Finding ways to make that work is an early topic being discussed at this year’s Farnborough International Airshow.
BAE, a major partner on both the F-35 and Eurofighter Typhoon programs, is undergoing tests to find ways to link the training systems for the two planes together in order to determine best tactics for operations, according to a company spokesman.
Fonte "BAE Working F-35 and Typhoon Interoperability" .....
http://www.defensenews.com/article/2014 ... perability
richelieu
Re: JSF
Inizio dei collaudi di un motore P&W F135 modificato .....
"Pratt to start testing F-35 engine fix this week" .....
http://www.reuters.com/article/2014/09/ ... P020140902
richelieu
Re: JSF
E allora vi spediamo in tribunale ..... ovvero ..... un'altra tegola ..... :shock:
The sole manufacturer of engines for the Lockheed F-35 Lightning II discovered in May 2013 that it had used substandard titanium alloy that might have been illegally purchased from Russia.
Pratt & Whitney halted delivery of F135 engines that contained the suspect titanium and has subsequently sued the supplier, A&P Alloys, of West Bridgewater, Massachusetts.
Fonte ..... "Pratt & Whitney sues supplier of titanium used in F-35 engines" .....
http://www.flightglobal.com/news/articl ... 35-403306/
richelieu
Re: JSF
Dicono di aver (quasi) capito qual'è il problema .....
Dal sito dell' AFA .....
Therein Lies the F135 Rub..... (John A. Tirpak 9/4/2014)
Investigators think they understand why an F135 engine problem caused an F-35 strike fighter to burn in June, slowing the test and training effort, program manager Lt. Gen. Christopher Bogdan said Wednesday.
Speaking at the COMDEF 2014 conference in Washington, D.C., Bogdan said the natural “flex” of the mishap engine under high-G conditions caused fan blades to “rub” and “dig too deep” in the rubber-like seal around the powerplant.
From 138 possible causes, “we’ve narrowed it down to four” and the root cause could be some combination of them all, Bogdan said.
Steps to address the issue are underway, including a “burn in” technique requiring two sorties per engine that could prevent the problem on other jets.
Bogdan expects a permanent fix in late October, but “I need 21 test airplanes” back to full capability “by the end of the month or else there will” be delays to the flight test program.
The engine problem has created a 30-45 day “headwind,” but Bogdan believes he can make up some of that.
Pratt & Whitney, maker of the strike fighter’s F135 engine, has been “very, very good” about solving the issue, Bogdan said.
“They’ve put their A-team on this” and agreed—before the likely root causes were identified—to bear the cost of retrofitting the 156 F135 engines now extant.
Pentagon acquisition, technology, and logistics chief Frank Kendall told reporters at the conference earlier in the day he expects a fix soon and at “a relatively minor cost.”
Bogdan said the mishap jet may be used for “battle damage repair” training.
The problem has nothing to do with a separate titanium supplier issue causing Pratt to replace parts in other F135s, Bogdan said.
richelieu
Re: JSF
Qualche dettaglio in più .....
The microcracks in the third stage of the integrally bladed rotor that caused a catastrophic F135 engine fire in an F-35A on June 23 began forming three weeks earlier when a pilot conducted a fairly benign maneuver with a unique combination of yaw, roll and g stresses, according to the F-35’s program executive officer.
Quanto mai singolare, per non dire involontariamente comica, questa dichiarazione del generale Bogdan .....
"Pratt and Whitney’s reaction to this problem from my opinion has been very, very good," Bogdan said.
"From a technical standpoint, they have put their A team on this.
From a business standpoint, they realize this is a problem they need to solve."
In pratica un elogio nei confronti del motorista perché aveva preso una serie di misure che non poteva in alcun modo esimersi dal prendere .....
Fonte ..... "F-35 Blade Microcracking Began Three Weeks Prior To Engine Fire" .....
http://aviationweek.com/defense/f-35-bl ... ngine-fire
'Jane's' mette invece in particolare evidenza il fatto che P&W si farà carico, assieme al governo USA, dei costi relativi alla messa a punto e al 'retrofit' delle future modifiche sugli esemplari di motore già prodotti .....
Pratt & Whitney, engine manufacturer for the Lockheed Martin F-35 Lightning II Joint Strike Fighter, has agreed to pay for retrofits of the 156 F135 engines delivered to the Pentagon once a solution is found to a design problem that caused an engine failure on 23 June, officials said on 3 September.
The company, a division of United Technologies, has also agreed to share the cost of any future engine design changes with the government, said US Air Force (USAF) Lieutenant General Christopher Bogdan, the Pentagon's programme manager for the effort.
"Pratt & Whitney to absorb F-35 engine problem costs" .....
http://www.janes.com/article/42727/prat ... blem-costs
Bello sforzo ..... non avranno mica pensato di poterli accollare ai paesi partner ?
richelieu
Re: JSF
Il Canada ..... gira che ti rigira .....
Canada is likely to choose between two major U.S. firms when it buys a new fleet of jet fighters, excluding two European competitors, according to a source with direct knowledge of the matter.
The source, who spoke on the condition of anonymity, said Lockheed Martin Corp's F-35 stealth fighter and Boeing Co's F-18 E/F Super Hornet were deemed more suitable for the variety of tasks the military has laid out.
Fonte ..... "Exclusive: Canada seen buying fighter jets from U.S., not Europe - source" .....
http://www.reuters.com/article/2014/09/ ... MC20140904
Si direbbe che ormai i legami che il Canada ha con gli Stati Uniti siano più forti di quelli che ha con il Regno Unito .....
richelieu
Re: JSF
Bennett Croswell, presidente del settore 'motori militari' di Pratt & Whitney, risponde, sulle pagine dello stesso periodico, al critico editoriale non firmato apparso su AW&ST tre settimane fa .....
"Pratt & Whitney Offers Some F135 Explaining" .....
http://aviationweek.com/defense/pratt-w ... explaining
Bennett Croswell ..... biografia aziendale ..... http://www.pw.utc.com/Bennett_Croswell
richelieu
Re: JSF
P&W F135 ..... si sta cercando la soluzione ..... e intanto affiorano nuove (si può dire imbarazzanti ?) informazioni .....
The long-delayed operational debut for the Lockheed Martin F-35 Joint Strike Fighter is at risk of further slippage due to a safety-critical problem with its Pratt & Whitney F135 engine for which no single root cause has yet been identified.
Senior leaders initially dismissed the fire that damaged F-35 AF-27 at Eglin AFB, Florida, on June 23 as a “one-off incident,” as U.S. Marine Corps commandant Gen. James Amos called it in mid-July.
However, Aviation Week has learned that at least five engines have been removed from F-35s after showing signs of premature wear.
Five F135 engines have been pulled from F-35s after failing an inspection regime that was instituted after the June 23 fire.
One of the failed engines was removed from F-35 CF-9 (the ninth production F-35C), an aircraft with fewer than 70 flight hours, according to a retired military officer and JSF program veteran.
Fonte .... "F-35 Fire: In Search Of A Solution" ..... http://aviationweek.com/technology/f-35 ... h-solution
richelieu
Re: JSF
Questa notizia non è soltanto di carattere navale ..... in quanto su queste due navi dovranno, un giorno, operare gli F-35B di Sua Maestà Britannica .....
"UK's second aircraft carrier will enter service" .....
http://www.flightglobal.com/news/articl ... ce-403407/
"Cameron: UK Will Operate 2 Aircraft Carriers" .....
http://www.defensenews.com/apps/pbcs.dl ... 4309050019
"UK Royal Navy to operate both new aircraft carriers" .....
http://www.janes.com/article/42822/uk-r ... t-carriers
richelieu
Re: JSF
F-35C ..... non è ancora entrato in servizio ..... e ce ne vorrà ancora del tempo ..... che già la Marina USA sta meditando su come modificarlo o, addirittura, sostituirlo .....
More than four years before the aircraft is scheduled to enter service, the US Navy already is considering modifying the Lockheed Martin F-35C to perform future missions beyond 2030.
Navy officials announced on 9 September that an analysis of alternatives (AoA) for the FA-XX aircraft would begin in calendar year 2015 and will consider modifying both the F-35C and the Boeing F/A-18E/F Super Hornet, as well as building a new aircraft to fulfil the requirement.
Fonte ..... "US Navy already looking beyond carrier-based F-35" .....
http://www.flightglobal.com/news/articl ... 35-403511/
Anche qui ..... "Navy's FA-XX Discussion Includes Modifying F-35C " .....
http://www.ainonline.com/aviation-news/ ... ying-f-35c
Intanto ..... a quanto sembra ..... P&W starebbe cominciando a vedere la luce in fondo al tunnel .....
"We're reasonably confident we're looking at the right thing, and then we're reasonably confident it's going to prove out in the next couple of weeks," Rear Admiral Randy Mahr, deputy director of the F-35 program, told .....
Fonte ..... "REUTERS SUMMIT-Pratt sees clarity on 'root cause' of F-35 engine issue by end Sept." .....
http://www.reuters.com/article/2014/09/ ... 2C20140909
..... mentre sarebbero a buon punto le trattative per il finanziamento dell'ottava tranche ..... nella quale, nonostante la sospensione di taluni pagamenti .....
http://www.analisidifesa.it/2014/03/f-3 ... pagamenti/
..... dovrebbero essere previsti 2 velivoli destinati al nostro paese .....
Lockheed Martin Corp is in the final stages of negotiations with the Pentagon about an eighth batch of F-35 fighter jets, with an agreement weeks or perhaps only days away, a company executive and a senior military officer said Tuesday.
The deal, valued by analysts at over $4 billion, will cover 43 of the most advanced U.S. warplanes.
Lockheed is building three models of the Joint Strike Fighter, or Lightning II, for the U.S. military and nearly a dozen foreign countries.
Fonte ..... "Lockheed, Pentagon say near deal on next batch of F-35s" .....
http://in.reuters.com/article/2014/09/0 ... XQ20140909
bulldog89
Re: JSF
Messaggio da bulldog89 »
Secondo il Corriere JSF sta per Join Straight Fighter...i miei più grandi complimenti...
http://www.corriere.it/politica/14_sett ... 3bce.shtml
MatteF88
Re: JSF
Mitico il corriere...il bello é che lo scrivono due volte, devono essere convinti che sia così :blackeye:
richelieu
Re: JSF
bulldog89 ha scritto:Secondo il Corriere JSF sta per Join Straight Fighter ... i miei più grandi complimenti ...
Semplicemente ..... M-E-R-A-V-I-G-L-I-O-S-O ..... per non dire altro ..... :laughing3:
..... e per non parlare dei sempre disponibili e volenterosi 'firmaiòli' .....
http://www.treccani.it/vocabolario/firmaiolo/
FAS
Re: JSF
Messaggio da FAS »
sembra un gruppo rock.....
comunque questo aereo mi paice sempre di piu....frutto di raffinata tecnologia, spero vivamente di poterlo vedere sotto la bandiera italiana.
Ovviamente insime magari a dei nuovi EF T3b......sono estremamente necessari se non vogliamo "jeopardise"...come si dice in italiano???? la capacitá di missione delle nostre forse armate... :bigsmurf: :albino: :mrgreen:
richelieu
Re: JSF
FAS ha scritto:sembra un gruppo rock.....
Ovviamente insime magari a dei nuovi EF T3b......sono estremamente necessari se non vogliamo "jeopardise"...come si dice in italiano???? la capacitá di missione delle nostre forse armate ...
"jeopardise" = mettere a repentaglio, compromettere ..... :wink:
Quanto al 'dreamfighter' USA ..... sono, nel mio piccolo di semplice appassionato di cose aeronautiche, quanto mai perplesso ..... ma tu, dalla tua posizione, sei sicuramente assai più indicato ad emettere valutazioni appropriate .....
richelieu
Re: JSF
Dal 'Daily Report' dell'AFA ..... una serie di dichiarazioni rilasciate dal sempre ottimista (e..... come potrebbe fare a non esserlo?) generale Cristopher Bogdan in occasione dell'annuale 'Air & Space Conference' dell'associazione .....
Bogdan: F-35A Schedule Low Risk .....
(John A. Tirpak 9/16/2014)
Achieving operational capability with the Air Force's version of the F-35 strike fighter in August 2016 is "low risk," said Lt. Gen. Christopher Bogdan, F-35 program executive officer, at AFA's Air & Space Conference in National Harbor, Md., on Monday.​
Bogdan said "there is margin" in the program to accommodate delays even with the aircraft's recent engine problems and perpetually challenging software issues.
In software, the program has consumed four to five months of its six-month cushion, but Bogdan said he is not yet concerned, because the problems are being worked.
As for other well-publicized F-35 technical issues—with the pilot's helmet, the carrier landing hook, a fuel-dump problem, and ability to absorb lightning strikes—they are "in the rearview mirror," he said.
Each was a "big risk two years ago; now, not so much," he said.
Technical solutions to all of those issues are in hand and several are already nearly through flight test, said Bogdan.
He said he loses little sleep over technical issues, because "there are no problems we can't solve on this program."
He has slightly more concern about "programmatics and affordability," and the latter is tied almost entirely to keeping the buy numbers intact.
Fixing the F135 .....
Engineers are "very, very close" to conclusively determining the root causes of why an F135 engine started a fire in an F-35 strike fighter in June, and a decision on various fixes will likely be final by the end of October, said F-35 Program Executive Officer Lt. Gen Christopher Bogdan on Monday.
He told an audience at AFA's Air & Space Conference outside of Washington, D.C., that the fix is proceeding along several lines, and some combination of "six options" will resolve the situation.
The options revolve around fixing the problem in new-build F135 engines—by potentially changing material that engine mounts rub against—and retrofitting some 150 extant motors, by gradually letting them "burn in," by performing certain maneuvers in the aircraft, said Bogdan.
Pratt & Whitney, F135 maker, will pay for the fixes, he noted.
In an interview with Air Force Magazine after his speech, Bogdan said "I don't think it will be a massive cost," and will be driven more by touch labor than by replacing parts.
P&W military engines chief Bennett Croswell, in a separate briefing for the press on Monday, noted that "we will validate the root causes [of the incident] by the end of the month," and that of all F135 engines, only three have been found with a similar problem brewing.
The company is on a "path to a solution … in six months," he said.
He also pointed out that the F135 is performing very well otherwise, "way above the maturity curve" of any previous fighter engine.
F-35 Incentives Plan .....
​F-35 contractors have put up some $170 million to invest in cost-reducing projects on the strike fighter under a plan that gives them high incentive to make the projects succeed, and quickly, said Lt. Gen. Christopher Bogdan, F-35 program executive officer, in a Sept. 15 interview.
He told Air Force Magazine that the contractors can get all their money back by sharing the savings with the services.
"The sooner these things pay off, the sooner they get their money back," and after that, the faster they will generate higher profits, said Bogdan.
"So it is 'win-win,' for us and for them," he said.
If the initiatives don't work out, the contractors don't get reimbursed, "so they have lots of incentive to make it work quicker," said Bogdan.
He added that "the beauty of it" for the program is that improvements negotiated in a given lot are "booked in that lot," and the government gets the savings right away, and from there on, whether the improvement works out or not.
It Was the Monster Mods .....
​A looming issue for the F-35 program is the process of reconfiguring already constructed aircraft to the final configuration needed to achieve initial operating capability, said F-35 Program Executive Officer Lt. Gen. Christopher Bogdan.
"The mod program is a monster … and you can quote me," he told Air Force Magazine in a Sept. 15 interview.
The challenge is that parts suppliers are "stressed" because they're producing parts in three configurations: one version for new production; one version to sustain aircraft already bought, and another version to support modification kits.
More suppliers have been brought in, said Bogdan, and that has "done a decent job" in reducing parts shortfalls.
But to produce the 10 airplanes the Marine Corps needs in a common configuration to achieve initial operating capability by next year "requires 58 modifications" to each jet, broken down into several groups, some of which have to be performed at depot, and others that can be accomplished at their operating base, he said.
It's a "full time job" for one of the F-35 deputies to manage the modification effort, said Bogdan.
E, a proposito della citata e prossima 'Initial Operational Capability (IOC)' degli F-35B dei Marines, ecco quanto scrive Jane's' .....
Marine Fighter Attack Squadron 121 at MCAS Yuma has begun training to IOC-specific standards.
The USMC plans to become the first of the three US military services to declare F-35 IOC in July 2015.
L'articolo ..... "First operational F-35B squadron on track to meet deployment standards .....
http://www.janes.com/article/43079/firs ... -standards
richelieu
Re: JSF
Altre dichiarazioni, sempre nella medesima occasione, da parte dello stesso Bogdan che, in questo caso, tratta della 'protezione' che verrà riservata al programma in caso di possibili restrizioni di bilancio causate dalla futura 'sequestration' .....
The F-35 joint strike fighter will likely be protected regardless of whether the Pentagon is operating under limits imposed by the Budget Control Act in fiscal 2016, the program’s top official said Monday.
“I have faith in the Department of Defense leadership that when they tell me and the services that if sequestration comes we’re going to do everything we can to minimize the impact on the program, because that is what we need to do,” Lt. Gen. Christopher Bogdan, the head of the F-35 joint program office, said.
Fonte ..... "Bogdan: F-35 Likely Protected in Next Budget" .....
http://www.defensenews.com/apps/pbcs.dl ... 4309150027
richelieu
Re: JSF
Chi dice una cosa ..... chi ne dice un'altra ..... e i tempi si allungano .....
Pratt & Whitney officials say they have identified a promising remedy for rubbing in the F135 engine that caused a catastrophic fire in June and destroyed a Lockheed Martin F-35 Lightning II, limiting test flights of the developmental fleet.
Contrary to statements by Lt Gen Christopher Bogdan, chief of the US F-35 Joint Program Office, engine manufacturer P&W says seal plating within the third-stage fan overheated during a “relatively aggressive” training manoeuvre.
Fonte ..... "P&W to test remedy for F135 engine fault" .....
http://www.flightglobal.com/news/articl ... lt-403721/
richelieu
Re: JSF
Altre fonti che trattano dei prossimi interventi sul motore 'P&W F135' .....
"Pratt: F-35 Fix Could Begin Installation Before End of Year" .....
http://www.defensenews.com/article/2014 ... e-End-Year
"F135 Test Fleet Retrofits Could Start in November" .....
http://aviationweek.com/defense/f135-te ... t-november
Le immagini di un paio di diapositive presentate dal generale Bogdan in occasione del suo intervento alla conferenza dell' Air Force Association .....
Fonte ..... Amy Butler@ABAviationWeek
richelieu
Re: JSF
LM ..... promette .....
Lorraine Martin, who leads Lockheed’s F-35 programme, outlined on 16 September a handful of the several hundred potential manufacturing and materials changes that seek to cut $10 million per year from the aircraft’s unit cost up to 2019.
The company has promised that by then, the F-35A will cost $80 million or less.
Fonte ..... "Lockheed outlines cost-saving design tweaks for F-35" .....
http://www.flightglobal.com/news/articl ... 35-403787/
richelieu
Re: JSF
'ALIS 2.0' in distribuzione .....
Lockheed Martin has delivered the latest iteration of the system that brings fifth-generation logistics and maintenance capability to the F-35 Lightning II fleet.
The autonomic logistics information system (ALIS) version 2.0 is being tested and validated for installation at all F-35 squadron locations, beginning in 2015.
An initial version of ALIS is currently operating at nine locations, and has been used to manage more than 12,000 sorties to date.
Fonte ..... "Lockheed Martin delivers improved ALIS for F-35" .....
http://www.flightglobal.com/news/articl ... 35-403800/
richelieu
Re: JSF
Procedura standard ..... e conseguenti, nonché imbarazzanti, ritardi nella diffusione delle informazioni ..... ovvero ..... tutto il mondo è preda della burocrazia ..... :laughing5:
When the F-35A exploded June 23 on the runway, it took about 10 days before the Pentagon had worked out how to communicate to the public, to the Navy, Marines and Air Force and to its international partners what had happened, was happening and would happen.
Today, Air Force Lt. Gen. Christopher Bogdan said that his office was doing a “complete rewrite” of its mishap planning process.
The problem was that the pilot reported to Air Education Training Command (AETC), so the command followed standard procedure and posted armed guards around the plane and did not share information with the Joint Program Office, with the Navy or Marines — let alone the rest of the Air Force or the international partners.
That made no one happy.
Fonte ..... "F-35 Engine Fix On Track; JPO Changing Mishap Notification" .....
http://breakingdefense.com/2014/09/f-35 ... ification/
richelieu
Re: JSF
Il punto sulla situazione .....
The F-35 is a complicated program.
That’s not really news, I know.
Technologically, the jet may be the most advanced piece of hardware the military has ever played with, requiring millions of lines of code and all sorts of gadgets spread over three physically different models.
Economically, it’s a Frankenstein’s monster of a program, with a trio of Pentagon services, eight partner nations who each have an economic hand in the program, and three foreign sales customers.
Keeping track of everything that’s going on is a challenge in the best of times.
Luckily for you, we here at Intercepts are ready to help.
Fonte ..... "The Current Status of the F-35, in Three Charts" .....
http://intercepts.defensenews.com/2014/ ... ee-charts/
richelieu
Re: JSF
Un nuovo balletto di cifre ..... con conseguente strascico di polemiche .....
The F-35′s long-term costs may “not be affordable” and appear to be substantially higher than those of the existing combat aircraft fleets that the Joint Strike Fighter will replace, the Government Acocuntability Office says in a draft report.
“The annual F-35 operating and support costs are estimated to be considerably higher than the combined annual costs of several legacy aircraft,” the draft says.
This issue is likely to be a topic of debate at the JSF Executive Steering Board meetings to begin Thursday in Oslo, Norway.
The nine countries that invested in the F-35′s development will hold bilateral meetings on Wednesday.
Then they gather in the shadow of the Norwegian parliament as a group the next day.
The estimated gap between the F-35 sustainment costs and those of the F/A-18, F-15, F-16 and the Harrier fleets as measured in 2010 is impressive, about $8.8 billion, an increase of 79 percent.
That estimate comes from the Pentagon’s authoritative Cost Assessment and Program Evaluation (CAPE) office, the GAO draft report says.
The draft says that costs for the legacy fleet were about $11 billion a year in 2010.
Based on CAPE’s estimate, the F-35′s annual costs will be $19.9 billion in 2012 dollars.
Fonte ..... "GAO Draft Slams F-35 On ‘Unaffordable’ Costs: $8.8B Over Legacy Fighters" .....
http://breakingdefense.com/2014/09/gao- ... -fighters/
Ovvero ..... non passa giorno che non emerga una qualche notizia sconfortante relativa al tormentato programma del 'wonderfighter' .....
MatteF88
Re: JSF
L'obiettivo fissato dalla mozione è quello "di massimizzare i ritorni economici, occupazionali e tecnologici". L'assemblea ha approvato anche le altre mozioni della maggioranza, tutte con il parere favorevole dell'esecutivo (da Sc la richiesta al governo di "aggiornare" il programma in relazione alle esigenze di bilancio) e quella presentata da Fi (anche in questo caso parere favorevole dal governo). Bocciate la mozione del Movimento 5 stelle che chiedeva la totale cancellazione della commessa dei caccia americani F35 di Lockheed Martin, programma al quale partecipa anche Finmeccanica, e quella della Lega Nord che chiedeva l'eventuale sostituzione della commessa degli F35 con altri caccia meno evoluti F22.
:lol: :lol: :lol: :lol: ma dai....
http://www.repubblica.it/politica/2014/ ... ref=HREA-1
richelieu
Re: JSF
:lol: :lol: :lol: :lol: ma dai ....
D'altronde ..... è cosa nota anche ai sassi che i nostri 'beneamati' politici ..... e non solo quelli ..... non sono in grado di distinguere un paracarro da un missile intercontinentale ..... :blackeye:
A parte gli scherzi ..... e tornando in argomento ..... tutto ciò mi da l'impressione che si tratti della consueta 'aria fritta' ..... in quanto a me sembra che il punto sia soltanto questo .....
"La discussione delle mozioni è del tutto intempestiva e demagogica - tuona Ferdinando Adornato (Udc) -. Prima di tutto perché il governo si è già impegnato a una revisione in base al Libro Bianco della Difesa, e quindi le valutazioni andranno fatte in quella fase".
Fonte ..... http://www.ilgiornale.it/news/politica/ ... 54328.html
richelieu
Re: JSF
C'è la possibilità che, alla luce dei ritardi accumulati dal programma e dalla ventilata possibilità di ulteriori tagli all'acquisizione dei velivoli (F-35A e tutti i B) destinati all' AM (mentre il numero dei B destinati alla MM ben difficilmente verrebbe toccato), potrebbe accadere questo .....
Italy also aims to continue operations for at least “10 or 15 years”, according to chief of air force operations Lt Gen Maurizio Lodovisi.
Fonte ..... "Tornado could fly on into 2030s, partners say" .....
http://www.flightglobal.com/news/articl ... ay-404109/
..... in attesa di futuri 'tempi migliori' (se mai ci saranno) che possano consentire l'acquisto di qualche esemplare di F-35A in più per l' AM .....
Si tratta comunque, al momento attuale, soltanto di mie elucubrazioni ..... Immagine
:drunken:
