Nuovo Caccia leggero Scorpion
richelieu
Re: Nuovo Caccia leggero Scorpion
Messaggio da richelieu »
A volte ..... ritorna ..... :eeeeek:
Textron AirLand’s Scorpion light attack fighter has demonstrated its close air support capability for the first time during a weapons exercise at White Sands Missile Range in New Mexico.
Operating from Holloman AFB in New Mexico, the developmental aircraft launched three different munitions during tests that ran from 10-14 October.
Under evaluation were Hydra-70 unguided 2.75 in rockets, the BAE Systems Advanced Precision Kill Weapon System, and Lockheed Martin AGM-114F Hellfire missile.
Weapons guidance was supported by the aircraft’s L-3 Wescam MX-15Di sensor and a ground-based laser designator, Textron says.
Fonte ..... "Scorpion carries out weapons testing over White Sands" .....
Textron AirLand ..... "Scorpion jet successfully completes first weapons capability exercise" .....
richelieu
Produzione limitata iniziata .....
Interessa a molti ..... però, al momento, nessuno lo ha ancora ordinato ..... :o
“We have a lot of customer conversations going on right now. We think there’s a number of opportunities to demonstrate this aircraft,” Donnelly said.
“We have a lot of customers that want to fly the aircraft, and that’s really what led us to want to accelerate both the expense side as well to … initiate a limited rate of production. Because we need to have these assets available for customer demonstrations, customer flights and hopefully, eventually, customer sales.”
Fonte ..... "Textron Begins a Limited Production Run of Scorpion Jet, But No Contract Yet" .....
richelieu
Si spende ..... in vista della prossima uscita del primo esemplare di produzione .....
Textron AirLand is accelerating research and development spending on its Scorpion light attack programme as it prepares for an imminent maiden sortie of the first production example.
It has been pulling forward investment in order to drive maturity into the platform as it looks to clinch a launch order, says Scott Donnelly, chief executive of Textron Aviation, one of the partners in the joint venture.
Speaking on a third-quarter results call on 20 October, Donnelly said a number of activities, including recently announced weapons tests, were under way as the programme entered what was essentially a “limited-rate production run”.
Fonte ..... "Scorpion nears flight milestone as R&D accelerates" .....
richelieu
Ha volato il primo esemplare 'vicino allo standard di produzione' dello Scorpion .....
Il comunicato dell' azienda ..... http://www.scorpionjet.com/first-produc ... st-flight/ .....
richelieu
E FlightGlobal fa notare un certo particolare .....
Conducted from McConnell AFB in Kansas on 22 December, the 1h 42min first flight “verified the avionics and aerodynamic performance, as well as a number of aircraft systems”, the Textron company says.
Registered as N530TX, the jet “performed extremely well”, it adds.
L' articolo ..... "PICTURE: First production-standard Scorpion gets airborne" .....
richelieu
Il secondo esemplare (N530TX) in una immagine che mostra la configurazione aggiornata .....
..... changes to the airframe include four degrees of sweep to the wings, an enhanced aft horizontal stabilizer for improved high-speed performance, a simplified landing gear design .....
richelieu
Lo 'Scorpione', di tanto in tanto, riemerge .....
As Textron Aviation eyes the US Air Force’s lucrative T-X trainer competition, its dual light-attack fighter and trainer Scorpion aircraft could remain in the running for a low-end fighter role in the USAF.
Scorpion is one of several aircraft the USAF will examine during an experiment slated for this spring that will consider low-cost fighter options, USAF chief Gen David Goldfein told an audience at a Washington think tank 18 January.
The experiment is not a competition and the service has not issued a request for information, Goldfein adds.
..... mentre l' USAF e il Senatore McCain spingono affiché venga realizzato il successore dello A-10 .....
In a 18 January defense budget recommendation white paper, Senate Armed Services Chairman Senator John McCain called the USAF to buy 300 low-cost, light-attack fighters requiring minimal development.
McCain recommended the service buy the first 200 of these aircraft, which would perform CAS and other missions in permissive environments, by fiscal year 2022 in addition to continued A-10 sustainment.
Goldfein called McCain’s proposal a “great idea,” saying the air force must sustain readiness for both high and low-end campaigns.
Fonte: FlightGlobal ..... "Air Force mulls low-end fighter experiment" .....
Il Libro Bianco di McCain ..... "Restoring American Power" .....
DefenseNews ..... "US Air Force Chief Lends Support to Light Attack Aircraft Buy" .....
richelieu
Era da un pò di tempo che non si avevano sue notizie .....
Ora ..... spara ..... :leftfighter7:
Textron is demonstrating a 20mm cannon on its Scorpion twin-jet ahead of the US Air Force’s light attack OA-X experiment later this summer.
Scorpion is now demonstrating the 20mm cannon at US Naval Air Station Patuxent River, Maryland, along with a .50-calibre HMP 400 pod, vice-president of Scorpion sales Bill Harris tells FlightGlobal in an interview this week.
Previously, Scorpion has carried the GBU-12 Paveway II and completed a live fire test with Advanced Precision Kill Weapon System guided rockets last August, he says.
Fonte: FlightGlobal ..... "PARIS: Scorpion tests 20mm cannon ahead of OA-X" .....
richelieu
Sperimentazione OA-X ..... "Essere stati invitati è un onore" ..... :)
The Air Force will soon begin flight-testing the aircraft participating in its OA-X light attack aircraft experiment at Holloman AFB, N.M.
Whether OA-X becomes an acquisition program of record or not, and whether a Textron aircraft wins this by-no-means-assured contract or not, company officials are clearly pleased the Air Force chose to invite two of the company’s products to the experiment.
Fonte: AFA ..... "Textron on OA-X: Since it’s an Experiment, It’s an Honor Just to be Invited" .....
richelieu
Di tanto in tanto ..... se ne riparla .....
Ora pare vi sia in vista un acquirente .....
FlightGlobal ..... "Saudi Arabia considering Scorpion deal: Textron chief" .....
..... e ci si sta preparando alla 'sperimentazione' nell' ambito del programma di ricerca dell' USAF per un velivolo da appoggio leggero .....
DefenseNews ..... "Textron, Sierra Nevada prep for OA-X experiment at US Air Force base" .....
28 agosto 2014...
http://www.md80.it/bbforum/viewtopic.ph ... 35#p914584
Valerio Ricciardi ha scritto:Non mi dispiace affatto lo Scorpion, non capisco perché la scelta di un'ala dritta "pura" senza un moderato angolo di freccia sia pure sul solo bordo d'attacco (come nel DC3).
28 dicembre 2016...
http://www.md80.it/bbforum/viewtopic.ph ... 05#p968991
richelieu ha scritto:Il secondo esemplare (N530TX) in una immagine che mostra la configurazione aggiornata
..... changes to the airframe include four degrees of sweep to the wings...
quando uno c'è portato c'è portato... 8)
eh eh eh
richelieu
Valerio Ricciardi ha scritto:28 agosto 2014...
28 dicembre 2016...
..... changes to the airframe include four degrees of sweep to the wings ...
quando uno c'è portato c'è portato ... 8)
eh eh eh
Valerio ..... ti prego ..... spiegamelo .....
Da solo non ci arrivo ..... :oops:
Giocavo... hanno semplicemente affinato il disegno dell'ala introducendo un poco di freccia nel solo bordo di attacco, come (in astratto) tanti tanti post fa avevo pensato io sarebbe stato forse opportuno... :lol:
richelieu
OK ..... giocavi ..... 8)
richelieu
La sperimentazione continua .....
da The Aviationist ..... https://theaviationist.com/2017/09/06/u ... n-testing/ .....
richelieu
Il generale Holmes, capo dell' Air Combat Command, interessato al velivolo .....
The Air Force is considering whether to press forward with a demonstration of inexpensive, off-the-shelf light intelligence, surveillance and reconnaissance (ISR) aircraft that could complement a potential light attack plane buy.
The service completed a demonstration of four light attack planes at Holloman Air Force Base, New Mexico, in August.
During the demonstration, Textron’s Scorpion aircraft caught the attention of Gen. Mike Holmes, head of Air Combat Command, because its modular design allows for a wide package of sensors.
As a result, Holmes said, some in the service are now intrigued by the idea of hosting a similar demonstration focused on ISR capabilities.
Fonte: defensenews.com ..... "Light ISR: The Air Force’s next experiment ?" .....
richelieu
In prova in Arabia Saudita .....
..... flightglobal.com ..... "Saudi testing precedes Scorpion's Dubai debut" .....
richelieu
richelieu
Un 'pod' multimpiego per lo Scorpion .....
The Air Force and Textron Aviation in December looked to prove the future of plug-and-play surveillance and open systems architecture by installing a newly developed pod on an aircraft that is not currently in the service’s fleet.
In late 2017, Air Force Research Laboratory officials met with Textron Aviation’s Defense Scorpion team and floated the idea of installing AgilePod - an Air Force-developed pod that can host a broad suite of sensors - onto the company’s light attack jet.
Within a few weeks, a Scorpion sat on the flightline at Wright-Patterson AFB, Ohio, with the pod attached.
Fonte: airforcemag ..... "Air Force Research Laboratory, Textron Demonstrate Plug and Play ISR" .....
Inoltre ..... wpafb.af.mil ..... "AFRL’s AgilePod shows ISR versatility during Scorpion fit test" .....
richelieu
Sperimentazione OA-X ..... lo Scorpion è fuori .....
The US Air Force has excluded the Textron Aviation Scorpion light attack aircraft from the next phase of the OA-X experiment, leaving the Textron’s AT-6 Wolverine and the Sierra Nevada/Embraer A-29 Super Tucano as the finalists for a potential follow-on acquisition deal.
Fonte: flightglobal.com ..... "USAF rejects Scorpion for OA-X, names A-29 and AT-6 finalists" .....
