Armed MC-27J on target for February firing trial .....
By: Luca Peruzzi (2 hours ago - February 7, 2013)
Source: Flight International
Alenia Aermacchi and ATK will complete the first phase of testing for an armed, multi-mission version of the C-27J battlefield airlifter by the end of February.
"The MC-27J version is not just a gunship", according to an Alenia Aermacchi source, "but an adaptable, agile and affordable platform solution to be equipped with a sensor, communication and weapon suite able to execute a wide range of customer-driven missions."
Unveiled as a product at the Farnborough air show in June 2012, the MC-27J is being developed and marketed by an Alenia and ATK team, with the companies acting as platform system integrator and modular mission and weapon system supplier, respectively.
"We are introducing roll-on and secure pallets, quick connect interface with avionics and aircraft systems, and working on an external antenna and sensor configuration to reduce operational limitations for transport missions," Alenia Aermacchi says.
The companies are offering a mission suite based on a roll-on/roll-off module, with two mission control operator stations, a cockpit display and command units capable of accomplishing a wide range of missions. The aircraft also boasts two electro-optical/infrared sensor (EO/IR) turrets for surveillance and weapon targeting, a new synthetic aperture radar, fire control system, secure radios and a datalink.
The armed configuration is based on a pallet-mounted ATK GAU-23 Bushmaster 30mm automatic cannon, also selected for the US Air Force's Lockheed Martin MC-130W Combat Spear special mission/gunship.
Weighing less than 900kg (1,980lb), with 500 rounds of ammunition, the weapon is fitted at the rear left door with the gun barrel protruding.
Flight International understands the gun has a slant range of 2.2nm (4km) from a 5,000ft (1,520m) altitude, and will be fired in unpressured conditions to enhance accuracy. The MC-27J also can carry precision-guided munitions, including those released from launchers incorporated with the aircraft's rear ramp.
An Alenia Aermacchi source says the first firing test phase will be performed at a US range, using a company-owned C-27J with a fixed gun with manual adjustment and cameras installed. The process will include five or six flights involving single and multiple rounds being fired, and will be completed during February.
The companies have, meanwhile, already started a second phase of work with an ATK-provided GAU-23 gun trainable mount, fire control software, installed EO/IR turrets and a mission system. These activities are scheduled to be completed, with additional testing, before the end of 2013.
Alenia Aermacchi says the C-27J has so far been ordered by 10 customers, with the latest being Australia and an undisclosed nation from central Africa. The company has so far delivered 54 of the 91 aircraft ordered, with more than 60,000 flight hours amassed and the type delivering an average availability rate of over 70%.
C-27J Spartan (e c-27A/g222)
- richelieu
Re: C-27J Spartan (e c-27A/g222)
Verso la fine i primi collaudi della "cannoniera volante" .....
- MatteF88
Io voglio i brimstone o gli hellfire sotto l'ala però!
- richelieu
E magari ..... un po' di napalm .....MatteF88 ha scritto:Io voglio i brimstone o gli hellfire sotto l'ala però!![]()
- sidew
richelieu ha scritto: un po' di napalm .....
Il napalm, lo senti? Non c'è niente al mondo che abbia questo odore.
Mi piace l'odore del napalm al mattino.
Una volta abbiamo bombardato una collina, per dodici ore, e finita l'azione siamo andati a vedere. Non c'era più neanche l'ombra di quegli sporchi ba**ardi.
Ma quell'odore... sai quell'odore di benzina? Tutto intorno. Profumava come... come di vittoria.
Un bel giorno questa guerra finirà.
- MatteF88
Non è diventato illegale il napalm?richelieu ha scritto:E magari ..... un po' di napalm .....MatteF88 ha scritto:Io voglio i brimstone o gli hellfire sotto l'ala però!![]()
Però.... una cosa alla Harvest Hawk..
- MatteF88
http://www.google.it/url?sa=i&source=im ... 5351550370
- richelieu
E' da più di un mese che se ne parla ..... e poi ..... le Forze Aeree Afghane hanno ben poco da rallegrarsi della cancellazione del programma C-27A .....Draklor ha scritto:Brutte notizie per Alenia ...
http://www.xairforces.net/newsd.asp?newsid=2052&newst=3
Non c'è da meravigliarsi ..... quello dev'essere proprio un bell'ambiente .....
Fonte: Robert F. Dorr a pagina 11 del numero di Febbraio 2013 del mensile britannico "AIR International" ....."As part of Washington's splurge on the Afghan air arm, two Afghan women were brought to the United States and trained as helicopter pilots (although one does not drive a car).
They returned home wearing pilot wings only to be ignored by the brass of their own air force and kept away from helo controls - because of their gender.
At press time, neither had made a single flight in an Afghan helicopter."
- MatteF88
E' iniziata la dismissione dei nuovi C-27J dell'ANG, gli esemplari già consegnati sono trasferiti a Davis Monthan per essere storati, gli esemplari ancora da consegnare verranno consegnati ma saranno portati direttamente nel deserto in Arizona..
http://www.dodbuzz.com/2013/10/07/time- ... -on-c-27j/
- richelieu
Il Perù sì che se ne intende .....
"Il Ministero della Difesa del Perù sceglie il velivolo da trasporto" .....
http://www.aleniaaermacchi.it/it-IT/Med ... C-27J.aspx
- MatteF88
il primo (di 10) destinato all'australia ha volato:
http://www.flightglobal.com/news/articl ... ne-394316/
- richelieu
Alla Guardia Costiera i 14 rimanenti C-27J ex-ANG .....
"US Coast Guard to acquire USAF's remaining C-27J Spartans" .....
..... http://www.flightglobal.com/news/articl ... ns-394575/ .....
"Coast Guard to Take Control of Last USAF C-27Js" .....
..... http://www.defensenews.com/article/2014 ... SAF-C-27Js .....
- innox
Eh beh, la CG ha delle basi molto più interessanti...per fare l'Exchange Pilot!richelieu ha scritto:Alla Guardia Costiera i 14 rimanenti C-27J ex-ANG .....
It's always better to be down here wishing you were up there than up there wishing you were down here.
- richelieu
E che ..... sei già sul piede di partenza?innox ha scritto:Eh beh, la CG ha delle basi molto più interessanti...per fare l'Exchange Pilot!
- innox
Metto le mani avanti! E magari anche i piedi.richelieu ha scritto:E che ..... sei già sul piede di partenza?innox ha scritto:Eh beh, la CG ha delle basi molto più interessanti...per fare l'Exchange Pilot!
(ma ormai c'ho un' eta'…)
- richelieu
Il battibecco .....
"Medium airlift and the big sales spat" ..... http://www.flightglobal.com/blogs/the-d ... ales-spat/
- MatteF88
Sullo sfondo...c'è sempre l'India...richelieu ha scritto:http://www.flightglobal.com/blogs/the-d ... ales-spat/
- richelieu
Alenia Aermacchi ha aperto un sito in lingua spagnola tutto dedicato allo Spartan .....
"Alenia Aermacchi: The C-27J Spartan Spanish Website is Live Online " .....
http://www.aleniaaermacchi.it/en-US/Med ... nline.aspx
Era ora che si decidessero ..... dal momento che il principale concorrente 'parla' proprio quella lingua .....
http://es.wikipedia.org/wiki/CASA_C-295
- richelieu
Intanto ..... negli USA ..... l'ammiraglio comandante la Guardia Costiera esprime la propria soddisfazione per l'acquisizione dei 14 Spartan dismessi dall'USAF .....
"You Can't Beat Free" ..... http://www.airforcemag.com/DRArchive/Pa ... -Free.aspx
- MatteF88
Se passate su fr24 ce n'è uno in volo vicino a Terracina ...MM62250
- richelieu
Come lo preferisci .....MatteF88 ha scritto:Se passate su fr24 ce n'è uno in volo vicino a Terracina ... MM62250![]()
..... con i contrassegni della Quaranteseiesima AB .....
..... o con quelli del RSV ?
- MatteF88
RS, secondo me l'insegna è più bella
- richelieu
In dettaglio ..... le dichiarazioni dell'ammiraglio Papp ..... comandante dell'USCG .....
"Coast Guard Commandant ‘Delighted’ to Get Air Force C-27s" .....
http://www.defense.gov/news/newsarticle.aspx?id=122026
- spiridione
Da qualche ora un C27 (del quale non riesco a leggere le insegne) vola a bassa quota sulla Sardegna Meridionale. Ha già fatto tre/quattro low pass sul mio ufficio, a Villacidro.
C'è qualcosa che bolle in pentola (esercitazioni) ?????
P.s. Quando dico low pass, intendo proprio low.....
- richelieu
Hai verificato l'integrità del tetto ?spiridione ha scritto: P.s. Quando dico low pass, intendo proprio low .....
- richelieu
In viaggio .....
"First Australian C-27J heads to USA" ..... http://www.aviationweek.com/Blogs.aspx? ... b2f5e1f827
- spiridione
No. Non sono problemi miei. Almeno non ancora.......richelieu ha scritto:Hai verificato l'integrità del tetto ?spiridione ha scritto: P.s. Quando dico low pass, intendo proprio low .....
- richelieu
MC-27J .....
..... se ne parla nel sito dell'AFA .....
"Dark Spartan's First Flight" ..... http://www.airforcemag.com/DRArchive/Pa ... light.aspx
Si vedano, all'interno, i links con Alenia e Jane's .....
- richelieu
OT .....
Intanto ..... l'aereo della concorrenza (modificato all'uopo da ATK) è già stato consegnato al primo utilizzatore .....
"Jordan takes delivery of AC235 gunship" ..... http://www.flightglobal.com/news/articl ... ip-398981/
- richelieu
Il Perù raddoppia ..... per ora .....
"Ancora Spartan per il Perù" .....
http://www.analisidifesa.it/2014/05/aln ... r-il-peru/
"I cargo italiani C-27J Spartan alla conquista del Sud America" .....
http://www.lastampa.it/2014/05/07/econo ... agina.html
" Il Perù compra altri due aerei Alenia. L'azienda: 'Assunzioni in Piemonte' " .....
http://torino.repubblica.it/cronaca/201 ... -85499599/
"El Ministro de Defensa de Perú visita en Italia la factoría de Alenia Aermacchi" .....
http://www.defensa.com/index.php?option ... Itemid=163
ghiga
E' una buona notizia per l'industria nazionale che il sud America guardi al C-27. Secondo me un velivolo molto valido, meno grande che un C-130,ma molto piu,' versatile.
- richelieu
Il SOCOM e lo Spartan .....
"SOCOM progresses C-27J crew training ..... http://www.janes.com/article/37820/soco ... w-training
- richelieu
Cannoniere volanti a confronto .....
http://www.defensenews.com/article/2014 ... ionstories
Fonte ..... "Two New Gunships Seek International Customers" .....After years in which aerial gunships were synonymous with the US-built AC-130, not one but two new offerings were on display last week in Jordan, reflecting a growing demand from other nations for aerial strikes by slow moving aircraft.
- richelieu
Dal sito del RIAT .....
"First Arrivals Touch Down" ..... http://www.airtattoo.com/news/2014/jul/ ... touch-downThe first aircraft to touch down at RAF Fairford was a C-27J Spartan airlifter arriving from the Baltic state of Lithuania.
This sizeable unit is always popular with the enthusiasts and puts on one of the most eagerly-anticipated displays as it performs the sort of manoeuvres - loops and rolls - more commonly associated with a fighter jet.
- richelieu
Sostituzione, in India, dei vecchi bimotori Avro ..... sarà in corsa anche lo Spartan .....
"India advances Avro replacement programme" .....
http://www.flightglobal.com/news/articl ... me-401917/
