A parte un inquinamento ambientale niente male, parrebbe non vi siano vittime o feriti, quantomeno:
http://video.corriere.it/papua-aereo-ca ... 879a266c65
Wamena (Papua), cargo si incendia in pista, distrutto
- a_ndrea
Re: Wamena (Papua), cargo si incendia in pista, distrutto
Perdindirindina (autocensura) un cargo che trasporta petrolio ne fa si di danni.
Meno male che nonostante tutto non ci sono vittime... credo che pure per i pompieri il rischio sia stato elevato
- sardinian aviator
Ma...succede sempre tutto in Indonesia o con compagnie indonesiane? Comunque un bell'addestramento per i VVF in condizioni reali.
Qui l'articolo su AvHerald:
http://avherald.com/h?article=461f6645&opt=0
"Wamena's police chief said, that a fuel drum fell from the aircraft spilling its contents onto the hot brakes of the aircraft and ignited resulting in a blaze that set the aircraft on fire, too.
An observer on the ground reported the fire broke out just before 11:48L (02:48Z) when a fuel drum dropped and ignited with the source of ignition unknown, two airport fire engines responded together, both with similiar tank capacity so that both engines needed to refill their supplies at about the same time, which needed quite some long time so that the fire flared up during those refills. By 12:14L the tail plane had already separated and was on the ground but the wings were still intact, at 12:26L a major explosion occurred probably because of the right hand wing separating releasing the content of its wing fuel tank, fire fighters managed to put the fire out at 12:50L."
