B772 Egyptair 29/7/11 - Cockpit Fire - Final Report
E' stato rilasciato il Final Report riguardante l'evento che ha interessato un B777-200 di Egyptair il 29 Luglio 2011, cockpit fire al gate prima della partenza, con gravi danni alla macchina:
http://avherald.com/h?article=44078aa7/0000&opt=0
La causa dell'incendio non è stata determinata con assoluta precisione, ma ha avuto origine in prossimità dei tubi di alimentazione dalla maschera del f/o, e quindi le indagini si sono focalizzate sul crew oxygen system.
"It was found: "contact between aircraft wiring and oxygen system components may be possible if multiple wire clamps are missing or fractured or if wires are incorrectly installed."
A laboratory analysis concluded: "A short circuit from electrical wiring, which is supposed to be in contact with or routed near the stainless steel oxygen supply tubing, would be the most likely source to provide electrical energy to the spring. It is supposed that the stainless steel spring had been subjected to high energy level, which heated the internal spring until it became an ignition energy source, causing the flexible oxygen hose to ignite and sustain a fire. The time to failure, may took few seconds depending on the amount of energy supplied to the internal spring."
(Da AvHerald, link sopra riportato)
Re: B772 Egyptair 29/7/11 - Cockpit Fire - Final Report
Di sicuro un qualcosa ha alimentato quel fuoco a giudicare dalla fusione dell'alluminio.
Certo che con quel nome...
