antonioq2005 ha scritto:ciao amici
ho le idee un pò confuse riguardo una questione, e cioè: una volta preso il PPL per poter fare l'esame CPL devo avere 200 ore di volo. come le metto su le ore? non mi dite che mi tocca pagarle tutte!!
potrei già fare qualcosa tipo l'istruttore o serve l'abilitazione anche per quello?
aiutatemi voi a capirci meglio...
grazie
A 200 ore ci arrivi fra IR+ME sul PPL aggiungendo poi tutte le ore di manovre minime necessarie per i conseguimento del CPL e naturalmente i crosscountry. Che siano 200 o 250 (come negli USA il CPL part 61) non cambia la sostanza.
Ecco le specifice per il SEL CPL (che differiscono di poco dal MEL):
00 hours in powered aircraft, of which 50 hours must be in airplanes.
(2) 100 hours of pilot-in-command flight time, which includes at least—
(i) 50 hours in airplanes; and
(ii) 50 hours in cross-country flight of which at least 10 hours must be in airplanes.
(3) 20 hours of training on the areas of operation listed in §61.127(b)(1) of this part that includes at least—
(i) 10 hours of instrument training of which at least 5 hours must be in a single-engine airplane;
(ii) 10 hours of training in an airplane that has a retractable landing gear, flaps, and a controllable pitch propeller, or is turbine-powered, or for an applicant seeking a single-engine seaplane rating, 10 hours of training in a seaplane that has flaps and a controllable pitch propeller;
(iii) One cross-country flight of at least 2 hours in a single-engine airplane in day VFR conditions, consisting of a total straight-line distance of more than 100 nautical miles from the original point of departure;
(iv) One cross-country flight of at least 2 hours in a single-engine airplane in night VFR conditions, consisting of a total straight-line distance of more than 100 nautical miles from the original point of departure; and
(v) 3 hours in a single-engine airplane in preparation for the practical test within the 60-day period preceding the date of the test.
(4) 10 hours of solo flight in a single-engine airplane on the areas of operation listed in §61.127(b)(1) of this part, which includes at least—
(i) One cross-country flight of not less than 300 nautical miles total distance, with landings at a minimum of three points, one of which is a straight-line distance of at least 250 nautical miles from the original departure point. However, if this requirement is being met in Hawaii, the longest segment need only have a straight-line distance of at least 150 nautical miles; and
(ii) 5 hours in night VFR conditions with 10 takeoffs and 10 landings (with each landing involving a flight in the traffic pattern) at an airport with an operating control tower.
