In-flight engine shutdow per un A380 di LH
AF77W
Messaggio da AF77W »
Notizia fresca fresca di FlightGlobal. Decisione comprensibile ai fini precauzionari per la sicurezza del volo.
Lufthansa has disclosed that its second Airbus A380 has undergone an in-flight engine shutdown just a couple of days after entering into service.
The aircraft, powered by Rolls-Royce Trent 900 engines, was delivered on 19 July and put into service last week on the Frankfurt-Tokyo route.
Lufthansa says that the aircraft was flying the return sector on 6 August when, about an hour before landing at Frankfurt, the crew took a "precautionary" decision to shut the engine down.
A spokesman for the airline says the decision followed the generation of "confusing numbers" on a cockpit indicator.
The indicator showed that the problem centred on oil pressure. Lufthansa's main A380 maintenance base is located at Frankfurt, and the aircraft - serial number 41 - underwent an engine change in order to return it to service as quickly as possible.
Inspection revealed "substances" in the filter but Lufthansa has not given further details. The company had a spare engine available and the aircraft went back into service on 7 August.
Both of the carrier's A380s are operating the Tokyo Narita route, providing a daily service to the Japanese capital from Frankfurt.
ciccioxx92
Re: In-flight engine shutdow per un A380 di LH
Messaggio da ciccioxx92 »
AF77W ha scritto:Notizia fresca fresca di FlightGlobal. Decisione comprensibile ai fini precauzionari per la sicurezza del volo.
Che si intende per confusing numbers?
Aggiungo anche quanto riportato da AvHerald:
http://www.avherald.com/h?article=42f53033&opt=0
Superkick
Messaggio da Superkick »
Ma non c'è scritto quale motore(i) hanno spento, o non l'ho letto io?
VENDO JOYSTICK SAITEK X52 PRO
***Il mio Tour Mondiale su IVAO***
Ministro della Stampa - Birra Point
Prisucci89
Messaggio da Prisucci89 »
Superkick ha scritto:Ma non c'è scritto quale motore(i) hanno spento, o non l'ho letto io?
"ENG 2 was shut down due to a Low Oil Pressure warning. On ground LH maintenance found the oil pump shaft sheared and some metal chips & flakes in the filter". (the aviation herald )
PPL (A)- Student
Superkick
grazie
butterfly
Messaggio da butterfly »
Beh nell'articolo parla di metal debris nel filtro ma non dice nulla circa possibili failures a componenti.
Qualcuno ha qualche altra info? :|
skype id: ladymachbet
http://www.giuda.it
