Ci credo che cercano piloti
- air.surfer
THE TALE OF THE ARAB FLIGHT CREW Written by To The Point News Friday, 16 May 2008
The brand spanking new Airbus 340-600, the largest passenger airplane ever built, sat in its hangar in Toulouse , France without a single hour of airtime.
Enter the Arab flight crew of Abu Dhabi Aircraft Technologies (ADAT) to conduct pre-delivery tests on the ground, such as engine runups, prior to delivery to Etihad Airways in Abu Dhabi .
The ADAT crew taxied the A340-600 to the run-up area. Then they took all four engines to takeoff power with a virtually empty aircraft. Not having read the run-up manuals, they had no clue just how light an empty A340-600 really is
The takeoff warning horn was blaring away in the cockpit because they had all 4 engines at full power. The aircraft computers thought they were trying to takeoff but it had not been configured properly (flaps/SLAT , etc.) Then one of the ADAT crew decided to pull the circuit breaker on the Ground Proximity Sensor to silence the alarm.
This fools the aircraft into thinking it is in the air.
The computers automatically released all the brakes and set the aircraft rocketing forward. The ADAT crew had no idea that this is a safety feature so that pilots can't land with the brakes on.
Not one member of the seven-man Arab crew was smart enough to throttle back the engines from their max power setting, so the $200 million brand-new aircraft crashed into a blast barrier, totaling it.
The extent of injuries to the crew is unknown, for there has been a news blackout in the major media in France and elsewhere. Coverage of the story was deemed insulting to Moslem Arabs. Finally, the photos are starting to leak out.
jasair
Re: Ci credo che cercano piloti
Bel botto...
- air.surfer
Che dici? S'aggiusta?jasair ha scritto:Bel botto...
- I-AINC
- davymax
- B737 Captain
Checklist, checklist, checklist, checklist....non si inventa niente....
W la buona e vecchia meccanica...
Cito un amico 737 con un amico A320:
A320: "lo sai che sul 320 se ti dimentichi di tirare su i flap dopo il decollo, lui lo fa da solo?"
737: "lo sai che se ti dimentichi di tirare su i flap dopo il decollo, qui c'è qualcuno che ha sbagliato lavoro, e quello non sono io"
(colleghi airbussisti, non conosco il giocattolo in questione, se non esiste tale funzione correggetemi
Va bene tutte le protezioni di cui ormai gli aerei son dotati....però che "tirando" fuori un C/B il computer ti rilascia i freni a me non è che sconquiffera più di tanto come idea...Then one of the ADAT crew decided to pull the circuit breaker on the Ground Proximity Sensor to silence the alarm.
jasair
Ma si dai...magari tagliano la parte anteriore un pò ammaccata e lo mettono in linea come "A340 Compact"...air.surfer ha scritto:Che dici? S'aggiusta?jasair ha scritto:Bel botto...
zittozitto
a centocelle c'è "martelletto d'oro" un carrozziere da paura, una romanella e te lo rivendi usato al primo pollo.air.surfer ha scritto:Che dici? S'aggiusta?jasair ha scritto:Bel botto...
a proposito di caxxate ... sul 320 se non tiri su i flaps e raggiungi la VFE allora per evitare danni li retrae.
nessuno ha il navigatore GPS in macchina ?
- albert
Le info provengono dal rapporto ufficiale? Ma è uscito?
@I-AINC ...beh, lo hanno buttato circa un anno fa....
Il mondo dell'informatica è pieno di bachi, e di mancati controlli
...basta ricordare anche il caso dell' Ariane 5....
- N176CM
Ed erano in 7..... minxxxa che professionalità!
N176CM
n176cm AT md80.it
n176cm AT md80.it
- paoloair
Non ho capito se i piloti sono vivi....
Brutta botta....
Brutta botta....
W LUFTHANSA ITALIA!
HO SPENTO UN AIRBUS!
- gianloria
Ma si...due chiodi, un po' di colla...se vuoi ho la pasta abrasiva per le rifiniture!air.surfer ha scritto:Che dici? S'aggiusta?jasair ha scritto:Bel botto...
Ghandi.
Ghandi.
- dirk
Mi sa che erano ingegneri, non piloti.
La ADAT se guardate è una società distinta che offre manutenzioni, certificazioni, verniciature, etc...
