Air India 787 Crash (Thread Generico)
- Moth
Re: Air India 787 Crash (Thread Generico)
Grazie, ottimo a sapersi. Non ho mai trovato materiale su questi argomenti ma perché non ho mai cercato a fondo.
airplane
B787 Air India Crash
(AVH Tutorial)
Ranting against the (Tutorial) author is inappropriate
(By xxx ) In the comments section (AVH Tutorial) I see a lot of ranting against the author of this editorial.
Some even try to prescribe what the author is not allowed to publish on his own website.
This is rather disturbing to me, in particular as:
1) In the beginning of the editorial it is clearly stated that this is a personal opinion, which the author is
certainly allowed to express!
cite: "Let me summarize my own opinion on this preliminary report and provide my reasons"
2) Using an editorial, the author purposely separated his declared personal opinions (aka. speculations) from
the ordinary article with the accident report. Such an editorial is not supposed to be purely factual (see 1).
3) To my understanding, the AV Herald has been built up and maintained by the author himself, which
includes countless hours of his personal time. No-one else has the right to prescribe what he can or cannot publish.
Any kind of attempts for information control (or even censorship) are inappropriate.
While readers are certainly allowed to provide feedback and own opinions (that may or may not disprove
the author's opinions), IMHO some of the comments go way too far.
>This is my personal opinion, (your mileage may vary).
(NO Comment)
(AVH Tutorial)
(NO Comment)
- musicaldoc
ASSOLUTAMENTE d'accordo con te, il vero unico problema onnipresente sui social è che non si accettano pareri personali altrui, perché la maggior parte di chi ha tempo da perdere sui social lo fa per sparare sentenze assolutistiche, quindi non comprende che qualcuno gentilmente possa esprimere una propria opinione, anche se lo sottolinea che è a titolo personale.airplane ha scritto: 3 agosto 2025, 9:16 .
>B787 Air india AI171 Crash
(AVH) Editoriale,
Questa è solo La Parte Iniziale:
Editorial on India B788 at Ahmedabad on Jun 12th 2025, lost height shortly after takeoff, no thrust reported
There is a war of beliefs hitting the world following the crash of Air India's Boeing 787-8 VT-ANB in Ahmedabad on Jun 12th 2025, see our actual coverage at Crash: India B788 at Ahmedabad on Jun 12th 2025, lost height shortly after takeoff, no thrust reported.
One large part of people believe especially following the release of the preliminary report, it had been a deliberate act to crash the aircraft by one of the pilots and based on some unconfirmed and premature newspaper report even point towards the Captain of the flight, another part believe it might have been an accidental flip of the fuel switches, others believe the crash might have been caused by a technical failure.
Let me summarize my own opinion on this preliminary report and provide my reasons:
I believe, that the fuel switches have been moved indeed into CUTOFF and 10 seconds later back to RUN by one of the pilots.
However, not to crash the aircraft but in an attempt to RESCUE the aircraft in accordance with the memory checklist items for dual engine failure.
I believe, the engine run downs began prior to the fuel switch signal transitioning to CUTOFF and the crew reacted correctly according to the memory items for dual engine failure, which require the crew to move both fuel switches to CUTOFF, wait, then bring them back to RUN in order to reset both Engine Electronic Controls (EEC) and also force a switch to the other channel of each EEC in order to relight at least one if not both engines.
Now, how do I get to this opinion? Let me first summarize some of the relevant Boeing documentation, then provide my observations.
(AVH) Editoriale,
Questa è solo La Parte finale:
SUMMARY
It is therefore obvious that even on the base of the preliminary report the cause of this crash is anything but clear, any conclusion particularly pertinent the fuel switches and unintentional or intentional malicious human activity is completely premature.
As often happens, the humans in the cockpit can no longer defend themselves, and thus become all too easily the scapegoats in the conflict of interest between living parties such as designers, producers, makers, regulators, monitors, airlines, safety departments, dispatchers, maintenance personnel, ground personnel, and even investigators. As such, I always stand by the flight crew until their fault is proven or all other possible causes have been proven to be ruled out.
The investigation principles therefore are clear: rule out all technical possibilities as the cause of an occurrence, only then look at the possibilities for human (intentional or unintentional) action to be the cause.
India's AIB as well as India's Ministry of Transport were sent a copy of this editorial beforehand but did not comment nor did they answer questions to clarify the sequence of events.
Ps.
Questo Editoriale pare sia “sotto un Fuoco di fila”;
Perciò, ho voluto dare un’occhiata, ma, ho visto
solo la parte iniziale e la parte finale.
Su queste due parti dell’editoriale, non vedo
niente di strano, anzi sono ponderate.
(Poi con calma lo leggerò tutto).
Si chiama proiezione in psicologia/psichiatria, vedi nell'altro quello che invece sei tu.
airplane
>B787 AIR INDIA CRASH
"PARE ...SI RITORNA ALL’INIZIO"
(ACQUA BRUTTA BESTIA)
They find likely E/E Bay flooding;
Very interesting, since there was a “New AD”
against E/E Bay insulation
Just days after the Air india AI171 Crash .
Ps.
Ps.
Non mi risulta. Di quale AD parli?airplane ha scritto: 13 agosto 2025, 13:04 .
against E/E Bay insulation [/b]
Ps.
Quale e' la fonte?
airplane
>(AVH) EDITORIAL
"GIRA E RIGIRA, SPUNTA SEMPRE":
(L’ACQUA BRUTTA BESTIA)
By Captain (XXXXX) Good (AVH) Editorial, (Simxxx).
A big thing that supports your theory is a lack of definitive timestamps after liftoff.
Every event before then has an exact timestamp.
We know we already had a data bus problem. An MEL ed "Core Network" deferred item in the logbook.
From my readings, I have gathered that there's 2 Core Network Cabinets in the hell hole (E/E Bay)
that SHARE THE SAME ARINC data bus with:
Remote Power Distribution System (RPDS)
Generator/Bus Power Control Unit (GCU/BPCU)
Landing Gear Indication and Control
Thrust Management Function
Flight Management Function
Pax internet/entertainment system
EAFR flight data recorder inputs
Let's hypothesize that one Common Core Network is already dead from water leakage
from the overhead lav AD. This could explain why the pax internet system was videoed t
o be unusable on the previous leg.
Now Horstroad's MEL book says you can still dispatch with one Core Network inop.
So what happen's if the other one fails at liftoff after water sloshes through it?
I think you'll lose:
EAFR flight data recorder inputs = no timestamps for events Gear retract function
Thrust Management Function = UHT (Uncommanded High Thrust AD.)
Each EEC spots N2 overspeed and will close the metered fuel valve on the ground or in the air.
Corrections by anyone are invited. An interesting primer of how the Core Network works is here:
Seeearch: reverse-engineers-perspective-on-the B787-51-days-airworthiness-directive/
(All my posts are just my opinions only,
and I could be wrong about everything.)
Ps.
>(AVH) EDITORIAL
Ps.
airplane
.airplane ha scritto: 30 giugno 2025, 23:40 .
>Sigmet, hai visto il video postato qui sopra?!
a parte, si parla, di FDR e CVR, che non corrispondono
a quelli montati sul B787 crash AI171;
Ovvero, dei 2 EAFR della GE (montati uno nella parte anteriore e l'altro nella parte posteriore)
uno solo EAFR quello anteriore è autoalimentato per 10 minuti,
>Come si sa "se tutto va a farsi friggere" rimane solo un microfono ( Overhead-Cockpit)
e relative voci e suoni registrati?!
>Con Riferimento al Post riporto qui sopra del 30-Giu-2025, (in risposta a Sigmet)
e quello che avevo postato prima più sopra
VA SOTTOLINEATO:
e relative voci e suoni registrati nel cockpit?!
>Vuol dire che "in mancanza dei relativi imput" ai 2 EAFR (l'anteriore e il posteriore)
Va ricordato, che Solo EAFR anteriore e autoalimentato per 10 Minuti.
quindi, con le voci del cokpit si sicavavo molti dati ad esempio:
variometro positivo, sù i carrelli e quant’altro nella breve fase di volo ecc.
Ps
Ovviamente, anche dopo che i mototi e
tutto il resto "va farsi friggere".
(Staremo a vedere)
.airplane ha scritto: 4 settembre 2025, 0:38
No, i microfoni sono sempre 4 .
EAFR 3254
The Cockpit Voice Recorder function records the flight deck
communications between crew members and also captures the
general acoustical sound environment of the flight deck. The CVR
function receives three analog audio crew channels provided by
the Flight Deck Audio System and one analog audio channel from
the cockpit Area Microphone and Preamplifier (AMP). The cock-
pit area audio and the three audio crew channels are recorded in
both the forward and the aft installed EAFR recorders. The CVR
recording duration is two hours minimum. Recorded audio can
only be downloaded when the EAFR is off the aircraft..
Power supply is a stand alone module. Either unit can be switch between
(fonte GE)
airplane
>Io ricordo che quello anteriore è
autoalimentato solo per 10 minuti.
Come ho già detto, anche dopo che i motori e tutto il resto
"va farsi friggere” (ovviamente compresa anche la 28VDC)
EAFR Anteriore rimane autoalimentato solo 10 Minuti.
(Staremo a vedere)
(Staremo a vedere)
Indipendentemente da quanto dura ma , se hai letto bene , entrambe le EAFR registrano su quattro canali (CM1,CM2,CM3 e Cockpit area) e non uno solo come avevi scritto.Ergo non si perde nulla..airplane ha scritto: 5 settembre 2025, 5:36 .
airplane
Come ho già detto,
io ricordo solo questo:
>EAFR installato nella parte anteriore insieme al microfono e al preamplificatore dell'area cockpit,
sono collegati al RIPS (Recorder Independent Power Supply),
Fornisce una fonte di alimentazione di riserva per 10 minuti in caso di interruzioni di
corrente.(Ovviamente a tutto l’ambaradan elettrico/elettronico del Dreamliner).
Ps.
Il post (“Corposo e interessante”) che avevo postato più sopra mi ha fornito lo spunto
che in “mancanza totale di imput”, le voci del cockpit, subito disponibili per 10 minuti,
erano molto importanti per capire la sequenza del breve volo
(variometro positivo, sù i carrelli ecc.)
Come ho già detto,
Ps.
Che intendi per "mancanza totale di input"?airplane ha scritto: 6 settembre 2025, 20:18 .
Il post che avevo postato più sopra mi ha fornito lo spunto
airplane
>B787 PILOT
"DUAL ENGINE RELIGHT DELAY"
I’m sorry but I’m struggling a find a source to back this up for myself.
I’m wondering if someone could help?
I’m B787 PILOT and I’m struggling to find any reference to a having a delay in
moving the FCS (fuel control switches) to aid in an (all Engine) in flight restart .
I can’t see this in the FCOM, FCTM, QRH,
or any official investigation.
Ps.
L'ho visto solo ora:
(Aug 2nd 2025)
>B787 PILOT
Ps.
(Aug 2nd 2025)
airplane
airplane ha scritto: 25 agosto 2025, 22:09 "GIRA E RIGIRA, SPUNTA SEMPRE":
[...] By Captain (XXXXX) Good (AVH) Editorial, (Simxxx).
Every event before then has an exact timestamp...[...]
[...] Let's hypothesize that one Common Core Network is already dead from water leakage
Now Horstroad's MEL book says you can still dispatch with one Core Network inop.[...]
>I think you will lose:
EAFR flight data recorder inputs = no timestamps for events Gear retract function...[...]
>Sigmet
[…So what happen's if the other one fails at liftoff after water sloshes through it?...]
EAFR flight data recorder inputs =”No timestamps”
for events Gear retract function ecc. ecc...
Dal (Corposo e interessante) precedente Post (che avevo citato)
lo scritto riportato qui sopra è quello che “mi ha fornito lo spunto”.
Ps.
Penso che il “Captain” forse non aveva ben focalizzato
il (poco conosciuto) RIPS del EAFR anteriore.
Quindi “un cosiddetto timestamps” è ricavabile
grazie al RIPS dal EAFR anteriore.
Se l'aereo perde completamente l'alimentazione elettrica (compresa la hot battery bus) , l'EAFR continua a registrare?airplane ha scritto: 8 settembre 2025, 12:39 >Sigmet[/b]
airplane
Come si vede sopra,airplane ha scritto: 6 settembre 2025, 20:18 .
corrente. (Ovviamente a tutto l’ambaradan elettrico/elettronico del Dreamliner).
Se tutto “l’ambaradan Elettrico/Elettronico (l’acqua brutta bestia) va a farsi friggere”
anche ai 2 moderni EAFR non arriva alimentazione e imput.
Ma come ho già scritto, solo EAFR anteriore e collegato al RIPS
(valido solo per 10 minuti per area cockpit).
Quindi, dopo la rotazione, ottenere informazioni come variometro positivo, su i carrelli
e quant’altro, (sono dei "Cosiddetti timestamp" importanti, in mancanza di altro).
(Penso sia una valida "filosofia")
Ps.
airplane
airplane ha scritto: 8 settembre 2025, 1:58
>B787 PILOT
>E’ ORA DI SOTTOLINEARE
ALCUNI PUNTI IMPORTANTI
1) Questo ultimo è importante Post (riportato sopra) come si vede è scritto da un B787 PILOT;
Questo mi ha convinto di dover sottolineare alcune cose importanti sul breve volo-crash del B787 Air India.
2) Voglio dire, che ancora prima, c’era stata anche una parte dello scritto di (AVH) Editorial (6° observation)
che aveva attirato la mia attenzione.
3) Quest’ultimo, che ho citato, assieme a un altro post postato da un B787 CAPTAIN che aveva fatto,
Con un FFS=Full Flight Simulator una replicazione del breve volo-crash dell’Air India.
Ps.
"per dormire sonni tranquilli,
“insieme alla coscienza”.
sigmet ha scritto: 8 settembre 2025, 13:30
Non hai risposto alla mia domanda.airplane ha scritto: 10 settembre 2025, 0:57
Ps.
airplane
...ANCORA?!
"L'ACQUA BRUTTA BESTIA"
An article appeared in the Independent today,
sourced from Mike Andrews,
a lawyer for 100 of the bereaved families.
He suggests a water leak may have caused a reset in FADEC.
He draws attention to several "bulletins to air carriers in
the United States to perform waterproofing maintenance".
Ps.
...ANCORA?!
Ps.
airplane
Ps.
>Come avevo già detto, diverse volte, fin dall’inizio
“Io non riesco a credere ad un atto Voluto.
Detto questo, quando si ha “L’acqua brutta bestia” non
causa un reset, ma è “il tutto che va a farsi friggere”
Il B787, dopo il decollo nel breve tempo di volo, solo una manciata di secondi,
ai 2 piloti non restava che tentare il reset con i due FCS N°1 e FCS N°2.
airplane
.b747-8 ha scritto: 12 luglio 2025, 22:07Mi sembra che nel video abbia accennato al tempo che un turbofan impiega a riavviarsi, quindi implicitamenteairplane ha scritto: 12 luglio 2025, 16:40 .
>Il Video del Com.te anzellotti,
risulta molto lineare e chiaro, in tutta la sua esposizione.
Voglio solo sottolineare un particolare che non è stato evidenziato:
Non a fatto cenno (come da NNC checklist), al Riavvio (Reset) dei 2 motori del B787
e al dovuto posizionamento dei TLA=thrust lever angle
(Penso sia dovuto a una dimenticanza),
ha esposto l'argomento. Probabilmente non ha detto di più, a parte il dettaglio degli interruttori carburante su "on", perché, correttamente, prima del fina report, lui non si sbilancia.
>Come si vede qui sopra,
il B787-RESET, l'avevo già, precedentemente,
sottolineato (12 Lug. 2025)
airplane
B787-AI171
INFO
"During the hearing, advocate Prashant Bhushan, appearing for the petitioner,
pointed out that the preliminary report had selectively blamed the pilots.
In response, the top court stated:
'That is why we say some confidentiality has to be maintained.
Privacy and dignity must be respected, because even though the pilots are
no more, their families are still there and will be affected by such leaks.'
The court added that instead of 'selective leaks,' the 'final outcome of
the inquiry should come out.'"
Sorry, pilot's families. Being "affected" shouldn't be a consideration
in putting out a preliminary report. The facts should be the facts.
Today's update also attempts to bolster the speculative theory about a 100% mechanical cause,
when there's more evidence this was an intentional act.
B787-AI171
INFO
Ultima modifica di airplane il 22 settembre 2025, 20:19, modificato 2 volte in totale.
airplane
TO REMEMBER
Pure l'acqua "Brutta bestia"
…la direttiva AD 2016-14-04
[...] Water accumulations on the B747-400 came to light at rotate,
and took out a lot of electrical services.
My suspicion is some cause such as this will come to light shortly.
Both of the E/E bays contain stuff that is nice to keep dry and operating,
and prior events have shown that multiple system failures can and have occurred
when a flood is added to all the black boxes sitting innocently on their racks.
The ADs are not necessarily directly related to the specific cause,
they highlight the potential for water damage and that bad stuff happens.
In 2 cases I investigated, the event occurred at rotate.
Both were B747-400's one Pax, one Freighters…
Link Post (16-giugno-2025)
viewtopic.php?p=1025117#p1025117
Ps.
TO REMEMBER
Ps.
airplane
“QUALCUNO HA GIA’
…LA VERITA’ IN TASCA?!
This, and the China Eastern pilot suicide show how Annex 13 rules are not fit for purpose
when you are dealing with rogue states.
The State of Occurrence can refuse to publish CVR and FDR data or even any kind of report,
and the other states with access to the data cannot publish anything.
So India or China can say it is Boeing's fault, refuse to issue a report (as China formally has),
and Boeing cannot defend itself.
It needs to be amended so after 1 year of no final report is produced by the state of Occurrence
then the other assisting agencies have the right to report.
Ps.
L’ho già detto e lo ripeto:
Per ora, Io non riesco a credere
sia un atto voluto.
Inoltre, in quella manciata di secondi di volo, dopo il decollo,
non si vola l’aereo fino allo schianto, con quella “pratica abilità”.
“QUALCUNO HA GIA’
Ps.
sia un atto voluto.
Dove hai letto sta ca***ta?airplane ha scritto: 24 settembre 2025, 5:39 .
“QUALCUNO HA GIA’
Ps.
airplane
"LA GENERALIZZATA
PROFONDA CONVIZIONE"
The fact is that: The fuel control switches (FCS) were moved to the "cutoff" position after
takeoff, and then approximately 10 seconds later were moved to the "run" position.
No electrical fault or computer fault can physically move the switches.
They have to be moved manually.
Why the switches were moved by a pilot is up for debate.
Ps.
"Alcuni Punti
da sottolineare":
1) La cosiddetta “acqua brutta bestia”
2) Avaria di tutti I motori subito dopo la rotazione di decollo;
3) il Com.te =pilota monitor (PM) e il Copilota =Pilota Flying (PF).
Ps2
Come ho sempre detto:
sia un atto voluto.
"LA GENERALIZZATA
Ps.
"Alcuni Punti
da sottolineare":
Ps2
sia un atto voluto.
- gabbiano
- b747-8
C'è un dettaglio non trascurabile: i motori e l'impianto elettrico operativi dopo l'atterraggio e l'attivazione della RAT, a quanto pare.
Certo bisogna scoprire la causa che ha fatto attivare la RAT...
BIRRA POINT
Ministro rapporti CULturali
BIRRA POINT
La mia attenzione e’ stata attratta dalle foto dei due FDR (EAFR) e dal diverso esito del fuoco su di essi.
Mentre sul FWD (quello a destra nella foto e ancora utilizzabile) sono evidenti i segni di un post crash fire , sull’AFT lo stato di fusione dei metalli farebbe pensare ad un altro tipo di incendio tipico di un fuoco di origine chimica. Senza voler avanzare ipotesi c’e’ da rilevare la posizione del AFT FDR in prossimità di alcune batterie al litio.
- gabbiano
"The nature of the aft recorder’s destruction, including
melting of its crash-proof housing and absence of soot deposits, was
highly irregular and consistent with high-temperature lithium-ion type
combustion rather than ordinary fuel fire."
Allora , avevo visto bene...
airplane
airplane ha scritto: 10 settembre 2025, 9:28airplane ha scritto: 8 settembre 2025, 1:58
>B787 PILOT
I can’t see this in the FCOM, FCTM, QRH, or any official investigation.
> TO REMEMBER
(AVH) 6° OBSERVATION.
[...] The Preliminary Report makes clear, that the gear lever was still in the down position and was never attempted to be put up.
Usually the pilot monitoring (PM)- the captain - would announce "positive rate of climb", the pilot flying (PF) - the first officer - would then command "Gear up!"and the captain would move the lever and confirm "Gear coming up".
This procedure would likely have the pilot communication "positive rate of climb", "gear up" command and the gear lever put into the up position below 75 feet AGL. However, this did not occur, it is thus likely, that the pilots noticed an anomaly before the call "positive rate of climb".
None of this is mentioned in the Preliminary Report,
hence it remains unclear whether none of these calls occurred - or were just not mentioned in the selective excerpt. It thus also remains unclear why the gear lever was, according to the preliminary report, never moved into the gear up position.
If we assume that one of the pilots intentionally brought the aircraft down, it is quite possible and even likely, that such calls were not made this time. But then in this scenario, why do the engines run down prior to the actual deed of putting the fuel switches intentionally into CUTOFF?
So, we have based on the preliminary report, the videos and the Boeing Manuals suggesting that the engines began to run down before the fuel switches were brought into the position CUTOFF.
So, why the fuel switch transition from RUN to CUTOFF and back to RUN?
The memory items for dual engine failure require the crew to place the fuel switches to CUTOFF and move them back to RUN, as the Boeing Manuals make clear (quoted above). It is possible, that the crew was aware of the necessity to wait between CUTOFF and RUN in order to ensure a proper reset of the EECs as shown by simulator tests following incident B787 ANA NH-985 (2019).
The purpose of this is simple: Reset the EEC (Engine Electronic Control), and at the same time force the EEC to switch to the other channel, in the hope that this will enable at least one engine if not both engines to recover and run again.
As we know from the preliminary report, this nearly worked, one engine had already started to recover but had not yet reached sufficient thrust to prevent the crash.
Now, the question is what we conclude from the preliminary report's statement reading: "In the cockpit voice recording, one of the pilots is heard asking the other why did he cutoff. The other pilot responded that he did not do so."
This is not a verbatim quote, but a summarizing narrative which does not establish the context of that exchange, and may even be misleading of what was really communicated between the pilots. Only a proper transcript of the entire communication can clarify the context and the exact wording.
Could the scenario be that the crew noticed the engines running down, and after overcoming the surprise effect one pilot reminds the other to perform the memory items - "Did you do the CUTOFF?" and the other responds "No" and now performs these memory items?
I believe therefore, that the transition of the fuel switches from RUN to CUTOFF was indeed done by the crew with intention, as a reaction to observing both engines running down. However, this was not the start of the crash sequence nor was the intention to bring the aircraft down, rather it was the intention to save the aircraft by at least relighting one of the engines according to the checklist memory items.
Why did the engines run down?
This is the decisive question that so far nobody can answer without further evidence, investigation and analysis.
There had been a similar case, in which the crew was able to recover the engines, which triggered the Service Bulletin FAA-2021-0273-0013 Attachment 2 of 2021.
This could be one possibility of how the simultaneous engine run downs could have been triggered by the simultaneous fault of two active MN4s sitting on the two EECs (with the other two inactive MN4s perhaps unaffected). A bump from the runway, the vertical acceleration of the beginning of lift off could have caused the already cracked, weakened solder balls to temporarily open completely and lose contact, causing the MN4s to send a thrust demand below flight idle to the engine control thus causing the engines run down. This is one of many possibilities (however one that is officially documented).
There are certainly other possibilities, too,
that need investigation and need to be ruled out.
Ps.
airplane
“UNA PICCOLA LUCE
IN FONDO AL TUNNEL”
[…]..i dati di volo acquisiti intorno alle 07:53 UTC registravano "guasti operativi
del gateway della BPCU sia sul lato sinistro sia sul lato destro.
>Le BPCU (Bus Power Control Unit Left & Right) sono fondamentali per la rete elettrica e di distribuzione dati
e un guasto al gateway suggerisce l'impossibilità di trasmettere o ricevere correttamente i segnali di controllo,
incluso il comando "RUN" al FADEC (Full Authority Digital Engine Control) del B787.
Questi risultati supportano fortemente la "Teoria del disturbo elettrico", secondo cui sono state anomalie
nei segnali, PIUTTOSTO CHE AZIONI DEL PILOTA, a innescare lo spegnimento dei 2 MOTORI del B787.
>L’Attivazione della RAT: (Ram Air Turbine);
è un dispositivo di sicurezza progettato come fonte di energia idraulica ed elettrica in situazioni di guasto
dei sistemi convenzionali.
La RAT funge da dispositivo di sicurezza, garantendo che l'equipaggio mantenga almeno
un controllo parziale sui sistemi di volo essenziali anche in caso di guasti catastrofici dei sistemi di alimentazione principali.
>Il Rapporto stesso registra che la RAT si è attivata durante la salita iniziale, con la sua pompa idraulica
che ha iniziato a fornire energia alle 08:08:47 UTC circa.
Il Rapporto non analizza le implicazioni tecniche dell'attivazione del RAT. Non stabilisce
il momento esatto in cui il comando di attivazione è stato emesso dai computer di bordo,
né esamina la sequenza di eventi che ha portato all'attivazione del RAT.
L'omissione di un dato così cruciale sopprime prove
che avrebbero potuto chiarire se lo spegnimento dei 2 Motori del B787 fosse involontario
Ps.
Finalmente,
si comincia un po' a soffiare via
"la pesante nebbia" sui Piloti.
“UNA PICCOLA LUCE
IN FONDO AL TUNNEL”
Ps.
Finalmente,
E' interessante verificare cosa di cruciale ci fosse "tutto intorno" a quel componente, che non immagino isolato un una bay tutta per lui.sigmet ha scritto: 10 ottobre 2025, 20:04 "The nature of the aft recorder’s destruction, including
airplane
B787 AIR INDIA CRASHairplane ha scritto: 10 settembre 2025, 0:57Come si vede sopra,airplane ha scritto: 6 settembre 2025, 20:18 .
Fornisce una fonte di alimentazione di riserva per 10 minuti in caso di interruzioni di corrente.
Ovviamente di tutto l’ambaradan elettrico/elettronico del B787 Dreamliner.
DAL REPORT
E' DA SOTTOLINEARE:
EAFR Anteriore (Anterior EAFR) ha registrato transizioni non comandate di entrambi gli interruttori di interruzione
del Fuel (FCS) da "CUTOFF" a "RUN" entro pochi secondi dallo spegnimento iniziale dei Motori del B787.
Questo vuol dire che all’ EAFR Anteriore, del B787 Air India, oltre all’alimentazione Autonoma
dell’area Cockpit, (RIPS 10 Minuti) usufruiva anche della presenza del 28VDC
Ps.
Cosa importante per
usufruire di molti altri dati.
