B1 Lancer
B1 Lancer
Risulta anche a voi che il B1 possa montare sotto le ali i missili sidewinder??
Se è vero (cosa strana) come potrebbe riuscire ad utilizzarli contro un caccia??
Inoltre sempre il merito al B1 è stato risolto il problema del volo con i portelli della ultima stiva aperti??
- richelieu
Re: B1 Lancer
Riapro questa vecchissima discussione per non doverne aprire una nuova .....
L' USAF ha disposto la messa a terra provvisoria di tutti i B-1B a causa di un problema relativo al sistema di espulsione .....
FlightGlobal ..... https://www.flightglobal.com/news/artic ... es-449335/ .....
AFA ..... http://www.airforcemag.com/Features/Pag ... Flaws.aspx .....
TheAviationist ..... https://theaviationist.com/2018/06/08/r ... stigation/ .....
- richelieu
Re: B1 Lancer
Dal sito dell' AFA .....
(*) ..... http://www.afgsc.af.mil/News/Article-Di ... perations/B-1s to Return to Flight This Week .....
Air Force Global Strike Command announced Tuesday that its B-1Bs will return to flight this week following a June 7 grounding, which includes bombers deployed to the Middle East, due to an ejection seat issue.
The grounding gave the command time to “thoroughly evaluate the egress components” and assess risk, the command said in a statement.
“We have high confidence that the fleet’s egress systems are capable and the fleet is ready to return to normal flight operations,” Maj. Gen. Thomas Bussiere, commander of 8th Air Force, said in a release (*).
The grounding was announced following a May 1 incident where a B-1 was forced to make an emergency landing at Midland International Air & Space Port in Texas.
Pictures of the aircraft showed an open hatch above the weapons systems officer’s position, which indicates a possible attempt to eject.
That incident is still under investigation.
US Army Col. Sean Ryan, spokesman for Combined Joint Task Force-Operation Inherent Resolve, said he could not comment on military operations when asked Tuesday about the impact of the grounding and the B-1's return to flight.
- Brian Everstine
- richelieu
Re: B1 Lancer
Ulteriori dettagli sull' incidente .....
AirForceTimes ..... https://www.airforcetimes.com/news/your ... own-hatch/ .....
- richelieu
Re: B1 Lancer
Ritorno in servizio ... ma gradualmente ...
(*) ... afgsc.af.mil ... "AFGSC B-1Bs return to flight" ...
I precedenti ...
... flightglobal.com ... "USAF grounds B-1B Lancer fleet due to safety issues" ...
... flightglobal.com ... "USAF grounds entire B-1B Lancer bomber fleet again" ...
... airforcemag.com ... "B-1B Fleet Returning to Flight After Extended Grounding" ...The first B-1B bombers returned to flight this week following a nearly four-week stand-down due to issues with drogue chutes in the aircraft’s ejection seats.
Air Force Global Strike Command said in a Tuesday release (*) that more aircraft are expected to return to flight in the near future as inspections and maintenance are completed, but the command did not say how many aircraft already had returned to flying status.
I precedenti ...
- richelieu
Re: B1 Lancer
Soltanto SEI ...
... airforcemag.com ... "Senator: About 10 Percent of B-1s are Fully Combat-Ready" ...Only six of the Air Force’s 61 B-1 bombers are fully mission-capable, a South Dakota senator said July 30.
The B-1 fleet is in the midst of an intensive slate of maintenance work and upgrades.
Of the 61 jets, 15 are in depot maintenance and 39 aircraft are down for inspections or other issues, Sen. Mike Rounds (R-S.D.) said during a Senate Armed Services Committee confirmation hearing for Gen. John Hyten, the US Strategic Command chief who is under consideration to become vice chairman of the Joint Chiefs of Staff.
In response, Hyten implored lawmakers to provide B-1 maintenance funding to reverse the fleet’s problems.
- richelieu
Re: B1 Lancer
B-1B ... una modifica, per ora sperimentale, che guarda al futuro ...
(*) ... afmc.af.mil ... "Expanded carriage demonstration showcases possible B-1B capability" ...
... flightglobal.com ... "USAF shows larger B-1B weapons capacity for hypersonic missiles" ...The US Air Force (USAF) has modified a Boeing B-1B Lancer to enable the bomber to carry larger and heavier weapons, including hypersonic missiles.
The service's 412th Test Wing at Edwards Air Force Base in California showcased a B-1B with the improve weapons capabilities to an undisclosed group of industry partners on 28 August, the USAF says (*).
- richelieu
Re: B1 Lancer
Li ritiriamo ?
Si ... no ... forse ...
Sono troppo usurati ...
Teniamone solo una parte ...
Può darsi ...
Può darsi ...
Fonte ... airforcemag.com ... http://www.airforcemag.com/Features/Pag ... -Last.aspx ...The Air Force likely needs at least 225 bombers, and that means it should probably hang onto the B-1 fleet - if studies show the hard-used aircraft can hold up, Global Strike Command chief Gen. Timothy Ray said at AFA's 2019 Air, Space & Cyber Conference.
Fonte ... airforcemag.com ... http://www.airforcemag.com/Features/Pag ... ments.aspx ...The Air Force is considering reducing the B-1 bomber fleet and using the savings to pay for a range of bomber fleet improvements, including a speed-up in the pace of B-21 bomber buys, and more long-range weapons, Chief of Staff Gen. David Goldfein told reporters Sept. 17, giving a limited peek ahead at the fiscal 2021 budget request.
He said he could not “lean forward” with many details because the budget is not yet approved.
- richelieu
Re: B1 Lancer
Saranno i B-52H i sostituti dei B-1B nell'area del Pacifico ... sino a quando i problemi che affliggono il bombardiere supersonico con ala a freccia variabile non verranno risolti ...
... airforcemag.com ... "B-52s to Remain in Pacific as Global Strike Addresses B-1 Readiness" ...The Air Force’s continuous bomber presence in the Pacific will continue to rely on the venerable B-52 for the foreseeable future as Air Force Global Strike Command wrestles with improving the readiness of the B-1B.
Since 2004, the Air Force has kept bombers stationed at Andersen AFB, Guam, with the B-52s and B-1s rotating through the area, with B-2s occasionally deploying for short periods of time.
For the past couple of years, B-52s have been the mainstay at Andersen as AFGSC pulled B-1s back from deployments after flying hard in the Middle East for years at a pace that “broke” the jets, AFGSC boss Gen. Timothy Ray said.
- richelieu
Re: B1 Lancer
Dopo un periodo abbastanza nero ... la salute del velivolo sembra essere in via di miglioramento ...
... airforcemag.com ... "Improved B-1 Readiness Showcased in Short-Notice Middle East Deployment" ...The health of the Air Force’s B-1 fleet, which spent much of 2019 plagued with readiness issues, has improved, enabling Air Force Global Strike Command boss Gen. Timothy Ray to send the bombers on a short-notice deployment to the Middle East with plans for a full task force rotation in the near future.
Years of overuse has strained the fleet, causing structural issues with the airframe.
In Spring 2018, the bombers couldn’t fly because of an issue with a failed ejection seat and the fleet also was grounded earlier this year because of issues with the aircraft’s drogue chute.
But in recent months, the fleet’s readiness has improved thanks to a focus on fleet management, additional maintenance assistance from Boeing, success in working through time-compliant technical orders, and by addressing problems with the aircraft’s egress systems.
Now the B-1 is back in the planning rotation for deployments, Ray told Air Force Magazine on Dec. 8.
- Maxx
Re: B1 Lancer
Per me è sul podio degli aerei più belli della storia insieme all’F-104 e al B-25 Mitchell. 4° posto, ma vicinissimo agli altri, l’F4U Corsair.
- Vultur
Re: B1 Lancer
Qua tutti riarmano bombardieri.
- Vultur
Re: B1 Lancer
Il prototipo numero tre (sui portelli del carrello anteriore), in realtà il secondo a volare, del B-1A: 74-0160. L'aereo doveva essere prima di tutto un banco prova per l'avionica, ma poi volò davvero il 26 marzo 1976 ed effettuò 138 missioni sperimentali. La particolarità più evidente è che è stato l'unico a ricevere una mimetica desertica a tre toni. L'aereo aveva ancora il sistema di espulsione che comprendeva tutti e quattro i membri dell'equipaggio in un'unica navicella di salvataggio. Il sistema avionico era molto avanzato, sia offensivo, che difensivo. Si vedono la pinna dorsale che corre dall'abitacolo fino alla deriva e le due "apparecchiature" ospitate in quelle due sporgenze triangolari tipo "orecchie", subito dietro l'abitacolo. I due tecnici di volo ospitati nei due posti posteriori erano ancora sconosciuti al grande pubblico, perchè il B-1A non aveva ancora ricevuto i due finestrini trasparenti posteriori che si vedono oggi, aggiunti in un secondo tempo, a causa del fatto che, in loro assenza, l'equipaggio poteva sperimentare allarmanti segni di disorientamento spaziale.
L'aereo concluse il suo programma e oggi dovrebbe essere ospitato al Wings Over the Rockies Air and Space Museum di Denver, dove mostra una mimetica successiva, forse una "Lizard" anni 80.
- richelieu
Re: B1 Lancer
In 'partnership' con i Gripen svedesi ... e non solo ...
... usafe.af.mil ... "B-1s integrate with allies and partners; fly over Sweden for first-time" ...Two B-1B Lancers from the 28th Bomb Wing, Ellsworth Air Force Base, South Dakota, conducted a long-range strategic Bomber Task Force mission to the Nordic region May 20, 2020.
The mission marked the first time B-1s have flown over Sweden to integrate with Swedish Gripens while conducting close-air support training with Swedish Joint Terminal Attack Controller ground teams at Vidsel Range.
During the flight, the B-1s were escorted by Royal Air Force Typhoons over the United Kingdom.
Additionally, the B-1s integrated with Norwegian F-35s to fly tactical sorties and conduct a low-approach over Ørland Air Station, Norway.
Ørland Air Station is the home of the Royal Norwegian Air Force’s recently operational F-35 fleet.
- richelieu
Re: B1 Lancer
In addestramento a Guam ...
… pacaf.af.mil … Dyess Airmen arrive in Indo-Pacific for Bomber Task Force, integrate with Koku-Jieitai, U.S. Navy …Approximately 200 Airmen and four B-1B Lancer aircraft with the 9th Expeditionary Bomb Squadron (EBS) from Dyess Air Force Base (AFB), Texas, arrived at Andersen AFB, Guam, to conduct Bomber Task Force missions in support of Pacific Air Forces’ training efforts with allies, partners and joint forces, Oct. 20, 2020.
BTF missions enable Airmen to continuously conduct operations throughout the world at a moment’s notice to help maintain global stability and security while enabling units to become familiar with operations in different regions.
- richelieu
Re: B1 Lancer
E' iniziato il ritiro dei B-1B ...
(*) … afgsc.af.mil … AFGSC paving way for B-21, begins retirement of B-1 aircraft …
… airforcemag.com … First of 17 B-1Bs Heads to the Boneyard …The first of 17 B-1B bombers to be retired this fiscal year under a Congressionally-approved divestiture plan flew to the “boneyard” at Davis-Monthan Air Force Base, Ariz., on Feb. 17, Air Force Global Strike Command said.
The aircraft was based at Ellsworth Air Force Base, S.D., but the Air Force did not provide specifics on which aircraft retired.
“This action will not affect the service’s lethality or any associated maintenance manpower,” AFGSC said in a press release (*).
It will allow a focus of maintenance and “depot-level manpower on the remaining aircraft, increasing readiness and paving the way for the bomber fleet modernization.”
- richelieu
Re: B1 Lancer
Il tour europeo dei B-1B del 7th Bomb Wing, dopo la tappa in Norvegia, procede ...
… airforcemag.com … B-1 Touches Down in Poland for the First Time …B-1s operating in Eastern Europe as part of a bomber task force continued their tour of the region, deploying to Poland for the first time March 12.
The B-1B from the 7th Bomb Wing at Dyess Air Force Base, Texas, touched down at Powidz, Poland - the first time a Lancer has landed in the country.
While on the ground, the bomber conducted a “hot pit” refueling-filling up on fuel with engines running to return to flight rapidly ...
- richelieu
Re: B1 Lancer
Messi a terra ...
… airforcemag.com … AFGSC Stands Down B-1 Fleet to Inspect Fuel System Problems …Air Force Global Strike Command on April 20 ordered a safety stand-down of its B-1B Lancer fleet to inspect fuel system problems following an April 8 ground emergency.
After the emergency at Ellsworth Air Force Base, S.D., inspectors found a “discrepancy” with the B-1’s Augmenter Fuel Pump Filter Housing.
As a “precautionary measure,” AFGSC boss Gen. Timothy M. Ray directed inspections on all B-1s to resolve the issue ...
- richelieu
Re: B1 Lancer
Alcuni B-1B tornano a volare dopo che l'intera flotta era stata messa a terra il mese scorso ...
… airforcemag.com … Some B-1s Return to Flight Following Stand Down, Fuel System Inspections …The first B-1B Lancers have returned to flight following a grounding more than two weeks ago to inspect issues with the aircraft’s fuel systems.
Air Force Global Strike Command announced May 6 that an undisclosed number of the bombers are back to flying after the April 20 stand down order.
AFGSC boss Gen. Timothy M. Ray ordered the aircraft to stand down to inspect each plane’s Augmenter Fuel Pump Filter Housing as a “precautionary measure” after an April 8 ground emergency at Ellsworth Air Force Base, South Dakota.
- richelieu
Re: B1 Lancer
Collaborazione fra personale dell'USAF e dell'US Navy in occasione dell'esercitazione "MineX" che si tiene a Guam ...
(*) … pacom.mil … U.S. Air Force, Navy Integrate for Bomber Task Force MineX …
… airandspaceforces.com … B-1s Carry Naval Mines for Bomber Task Force Mission …B-1B Lancers deployed to Guam for a bomber task force joint training mission with the Navy, with Airmen and Sailors practicing loading and releasing naval mines from the B-1s.
The naval mine exercise, or MineX, took place Oct. 24, staged out of Andersen Air Force Base, according to a release from Pacific Air Forces (*).
As part of the exercise, Sailors from Navy Munitions Command’s Pacific Unit built and delivered the Mark-62 Quickstrike mines, then worked with Airmen from the 28th Munitions Squadron to load them onto the B-1s.
All told, an undisclosed number of B-1s were loaded with 21 mines total, each mine weighing about 500 pounds.
A B-1 can carry up to 84 of the mines.
- richelieu
Re: B1 Lancer
Avvenimento storico ... per la prima volta i bombardieri B-1 dell'USAF prenderanno parte ad un'esercitazione in India ...
… airandspaceforces.com … In Historic First, USAF Deploys B-1s to India for Exercise …A pair of B-1B Lancers from Ellsworth Air Force Base, S.D., will participate in a joint exercise with the Indian Air Force this week - the first time the BONE has participated in an exercise there.
F-15E fighters, C-130J cargo planes, and C-17 transport aircraft also are taking part in Cope India 2023, Pacific Air Forces told Air & Space Forces Magazine.
Indian news outlets first reported the B-1s’ participation, citing PACAF commander Gen. Kenneth S. Wilsbach.
The visit is the second trip to India in three months - in February, Lancers conducted flyovers at the biennial Aero India air show.
B-1s also participated in Aero India 21, the first time a Lancer had ever landed in India.
- richelieu
Re: B1 Lancer
Un nuovo tipo di pilone prodotto da Boeing potrebbe essere utilizzato per spostare i test dei missili ipersonici dal B-52 al B-1 ...
… airandspaceforces.com … New Boeing Pylon Could Shift Hypersonics Testing to B-1, Add Bomb Capacity …Boeing sta proponendo all'USAF di spostare i test dei missili ipersonici dal B-52 al B-1, mediante l'utilizzo di un nuovo pilone che potrebbe, come ulteriore vantaggio, aumentare del 50% la capacità di trasporto di munizioni del B-1 per molte delle armi esistenti, così afferma l'azienda che ha sviluppato, con i propri soldi, quello che chiama pilone "Load Adaptable Modular" (LAM), ma l'USAF sta anche utilizzando alcuni fondi aggiuntivi del Congresso per testarlo.
Tali test sono ora in corso.
L'USAF ha destinato otto B-52 per effettuare i test di motore, radar, armi e altri aggiornamenti.
Con 10-12 bombardieri che dovrebbero essere in deposito, riparazione o aggiornamento in qualsiasi momento per il prossimo futuro, rimangono solo da 56 a 58 dei 76 B-52 disponibili per le operazioni, creando un potenziale problema perché il B-52 ha una missione di deterrenza nucleare, mentre il B-1 non la ha.
- richelieu
Re: B1 Lancer
Due bombardieri B-1 statunitensi sono atterrati in Svezia per la prima volta ...
… airandspaceforces.com … PHOTOS: US B-1 Bombers Land in Sweden for First Time …Una coppia di bombardieri B-1 dell'USAF ha dato il via ad uno storico dispiegamento questa settimana, atterrando in Svezia il 19 Giugno scorso.
"Questa è la prima volta che bombardieri statunitensi atterrano in Svezia", ha dichiarato un portavoce dell'USAF in Europa ad Air & Space Forces Magazine.
Il dispiegamento segna l'ennesimo segno dei legami rafforzati tra gli Stati Uniti e la nazione del Nord Europa, anche se la sua offerta di aderire alla NATO è tuttora in discussione.
I due B-1B Lancer del 7th Bomb Wing della Dyess Air Force Base, (TX), sono atterrati nella base aerea di Luleå Kallax.
- richelieu
Re: B1 Lancer
Il NORAD e gli Alleati si esercitano ad intercettare i B-1 "Lancer" di ritorno dall'Europa ...
… airandspaceforces.com … NORAD, Allies Practice Intercepting B-1s Returning from Europe …Il 26 Giugno scorso gli Stati Uniti e i loro Alleati hanno intercettato i bombardieri americani B-1 che attraversavano l'Atlantico verso il Nord America, in un'esercitazione guidata dal NORAD che simulava un attacco nemico.
Durante l'esercitazione, denominata "Noble Defender", i B-1 "Lancer" che stavano lasciando l'Europa dopo un mese di dispiegamento della Bomber Task Force sono stati successivamente rintracciati e intercettati dalle forze aeree statunitensi, canadesi, britanniche, danesi, finlandesi, norvegesi e svedesi.
Un funzionario del NORAD ha riferito ad Air & Space Forces Magazine che due B-1 sono stati incontrati nei cieli da quattro caccia britannici: due F-35 e due Eurofighter Typhoon.
La Danimarca ha inviato due F-16, la Svezia due JAS-39 Gripen, la Norvegia due F-35 e la Finlandia due F-18.
- richelieu
Re: B1 Lancer
Il piano dell'USAF ... mantenere credibile il B-1 attraverso l'installazione di nuovi piloni, stress test ed altro ...
… airandspaceforces.com … USAF Plan: Keep B-1 Credible Through New Pylons, Stress Testing, and More …L'Air Force Life Cycle Management Center non ha in mente una data prestabilita per il ritiro del B-1 Lancer, ma ha un approccio su più fronti per mantenere credibile il famoso bombardiere fino a quando il B-21 non sarà in servizio ...
- richelieu
Re: B1 Lancer
Il primo volo della "BESTIA" ...
… airandspaceforces.com … Modernized ‘BEAST’ B-1 Bomber Makes First Flight …
Anche qui … avianews.ch … Mise à jour des B-1B « Lancer » ! …
- richelieu
Re: B1 Lancer
Un bombardiere B-1 si è schiantato a Ellsworth … l'equipaggio si è lanciato ed è sano e salvo …
Anche qui … thedrive.com/the-war-zone … B-1B Bomber Crashes In South Dakota …
E qui … theaviationist.com … B-1B Bomber Crashes While Landing At Ellsworth AFB, Crew Ejects Safely …
… airandspaceforces.com … B-1 Bomber Crashes at Ellsworth; Crew Ejects Safely …Un bombardiere B-1B si è schiantato mentre tentava di atterrare alla base aerea di Ellsworth, SD, il 4 Gennaio scorso.
Tutti e quattro i membri dell'equipaggio si sono lanciati e sono sopravvissuti secondo quanto è stato riferito in una nota della Ellsworth AFB.
- richelieu
Re: B1 Lancer
La Ellsworth AFB ha sospeso le operazioni di volo dopo l'incidente occorso al B-1, ma il relitto del bombardiere non è stato ancora dichiarato distrutto …
… airandspaceforces.com … Ellsworth Pauses Flight Ops After B-1 Crash; Carcass Not Yet Declared a Loss …
Inoltre … thedrive.com/the-war-zone … B-1B Bomber’s Crash Landing Path Seen In Satellite Image …
- richelieu
Re: B1 Lancer
Il luogo dell'incidente del B-1 deve ancora essere ripulito, pertanto le operazioni di volo a Ellsworth continuano ad essere sospese …
… airandspaceforces.com … B-1 Crash Site Yet to Be Cleared, Keeping Flight Ops on Pause at Ellsworth …L'USAF ha affermato che le operazioni di volo dei B-1B Lancer dalla Ellsworth AFB, SD, sono ancora sospese a seguito dello schianto di un bombardiere sulla base avvenuto il 4 Gennaio e la pista rimane chiusa.
Un funzionario dell'USAF ha riferito all'Air & Space Forces Magazine che la scena non è stata ripulita e si prevede che la pista rimarrà chiusa dopo il 19 Gennaio, poiché le prove dell'incidente continuano ad essere elaborate ed indagate.
- richelieu
Re: B1 Lancer
Alcuni B-1, con i relativi equipaggi, si sono trasferiti dalla Ellsworth AFB alla Dyess AFB per continuare l'addestramento mentre il relitto del "Lancer" che si era schiantato il 4 Gennaio scorso viene rimosso …
… airandspaceforces.com … Some B-1s and Crews Move From Ellsworth to Dyess to Train While Wreck is Cleared …
