Boeing NMA .....
richelieu
Boeing NMA .....
Messaggio da richelieu »
NMA (New Midsize Airplane) ..... la rivelazione di Boeing a Le Bourget .....
Boeing partially unveiled a New Midsize Airplane (NMA) concept with a 787-like composite wing and fuselage, a likely narrower wingspan than the Dreamliner and, for the first time, what the company calls a "hybrid cross-section".
After achieving an authority-to-offer decision earlier this year, Boeing is still perhaps months or a year away from a launch decision for an aircraft sized to carry 200-270 passengers and fly 5,000nm.
Fonte: FlightGlobal ..... "PARIS: ​Boeing partially unveils New Midsize Airplane concept" .....
Inoltre ..... sempre da FlightGlobal .....
..... "PARIS: Initial reception largely positive to Boeing's NMA" .....
..... "Norwegian 'very interested' in Boeing NMA: CEO" .....
richelieu
Re: Boeing NMA .....
Ora lo chiamano 'New Mid-market Airplane' .....
Boeing has created a programme office to support the New Mid-market Airplane, and appointed a top 787 executive to lead the effort toward a future launch decision by the company’s board of directors.
The appointment of former 787 vice-president and general manager Mark Jenks to lead the NMA office signals that Boeing’s is closer to launching the new family of composite aircraft aimed at a market segment between the 737 Max 10 and 787-8.
Fonte: flightglobal.com ..... "Boeing creates programme office for New Mid-market Airplane" .....
Inoltre: reuters.com ..... "Boeing opens program office for potential new mid-market jet" .....
richelieu
Ma Willie Walsh ( http://www.iairgroup.com/phoenix.zhtml? ... vBioWWalsh ) ..... è poco convinto ..... :scratch:
IAG chief executive Willie Walsh is lukewarm to the prospect of Boeing’s proposed all-new middle-of-the-market aircraft, which he believes is coming late given the availability of Airbus’s A321LR variant of the A320neo family.
Speaking at the recent World Routes in Barcelona, Walsh praised the A321LR’s performance, explaining how Aer Lingus will use the extended range version of the re-engined twinjet to launch single-aisle transatlantic services in 2019.
He adds that he sees a wider role for the A321LR at other airlines within IAG.
Fonte: flightglobal.com ..... "Boeing’s NMA could be 'a bit late' to market: Walsh" .....
richelieu
Boeing procederà con cautela ..... prima di prendere una decisione definitiva .....
Boeing will not be rushing into a decision on whether to launch a New Mid-market Airplane (NMA), despite seeing a clear opportunity for such a product, the head of its commercial unit tells FlightGlobal.
"A decision to launch a new airplane is one that requires a ton of rigour on: is it the right market, is it the right airplane, and does it have the right business plan?" says Boeing Commercial Airplanes chief executive Kevin McAllister.
Fonte: flightglobal.com ..... "Boeing not rushing decision on NMA: commercial chief" .....
richelieu
Messaggio da Lampo 13 »
Sembra bello, simile al mai superato, esteticamente, B-757.
richelieu
Qualora venisse lanciato il programma di quello che potrebbe essere denominato '797' ..... Boeing punterebbe alla vendita di almeno 4000 esemplari .....
Momentum appears to be gathering around Boeing's proposed New Mid-market Airplane (NMA) – already being referred to by some as the 797.
Reports indicate a potential launch this year or in early 2019, although this is perhaps more likely to refer to an authority to offer (ATO), rather than the full industrial launch.
Boeing has said it is looking at a small twin-aisle in two sizes, with 220-270 seats and a range of up to 5,000nm (9,260km).
It sees a global market for about 4,000 aircraft in the NMA class.
..... https://www.flightglobal.com/news/artic ... er-448642/ .....
E' necessario il login .....
ally01
Messaggio da ally01 »
ma questo ipotetico Boeing NMA/797 esiste o è solo speculazione?
richelieu
ally01 ha scritto:ma questo ipotetico Boeing NMA/797 esiste o è solo speculazione?
Facendo un pò di ricerche tipo questa ..... https://www.flightglobal.com/search-res ... ing%20nma/ ..... o questa ..... https://www.ainonline.com/search/site/NMA ..... vedrai che qualcosa trovi ..... e potrai fartene un' idea .....
ally01
avevo già cercato info a riguardo, sembra che Boeing attenda di capire dove tira il vento di conseguenza non si vedrà nulla nel breve periodo. Il progetto verrà finalizzato nel 2019 con possibilità di averne la commercializzazione dopo il 2025. Airbus piazzerà una versione riveduta del 321 (322?) per contrastare il segmento?
richelieu
NMA ..... Boeing prende tempo .....
..... flightglobal.com ..... "Boeing buys time with 2020 NMA launch timeline" .....
Un paio di giorni prima ..... flightglobal.com ..... "Boeing CEO: No NMA firm launch decision this year" .....
Rolls-Royce si ritira dall'engine competition per la piattaforma Boeing New Midsize Airplane (NMA):
https://www.md80.it/2019/02/28/rolls-ro ... -platform/
ally01
Eurostar
Messaggio da Eurostar »
Molto interessante la figura.
ally01
richelieu
NMA ... “We are going to start with a clean sheet of paper, again.”
Boeing is taking a fresh look at the design of its so-called New Mid-market Airplane due to changes in the global aviation market and heightened focus on pilot-aircraft interactions.
“We are going to take, probably, a different approach,” Boeing chief executive David Calhoun says on 22 January in response to questions about the NMA.
... flightglobal.com ... https://www.flightglobal.com/air-transp ... 96.article ...
richelieu
NMA ... o che altro?
Boeing is assessing which segment of the commercial aircraft market it should actually address with its next aircraft development programme, suggesting options other than its proposed New Mid-market Airplane (NMA) may be on the table.
Speaking during Boeing’s 2019 earnings call on 29 January, chief executive David Calhoun also insists the company will not design its next aircraft purely as a response to the hugely-popular Airbus A321neo.
“We have asked the team to step back and reassess our commercial product development strategy to determine what family of airplanes will be needed in the future,” Calhoun says.
... flightglobal.com ... "Boeing still deciding which market segment its next aircraft should target" ...
richelieu
Boeing ... non ha tempo da perdere !!!
... flightglobal.com ... "Boeing has no time to lose on NMA decision" ...
:usa2:
ally01
eviterei di dire che il progetto NMA ha ritardi a causa del grounding del max. Il 737 è a terra da meno di un anno e il suo progetto ha fatto risparmiare miliardi di dollari a Boeing (che poi i soldi risparmiati stiano uscendo sotto forma di crisi è altro discorso). L'NMA non è inritardo: non esiste prorpio.
richelieu
NMA ... emerge un'ipotesi ...
In considering its options for a New Mid-market Aircraft (NMA), Boeing could ponder using an early design of a bestselling twin-aisle aircraft which was shelved a decade ago, in an effort to keep development costs low and execute on an accelerated timeline, one analyst says.
As the company reevaluates its plans around building an NMA, Addison Schonland, founder and chief executive of AirInsight Research, says the answer for the Chicago-based planemaker could be relatively simple.
“The 787-3 died a miserable death,” says Schonland at the Pacific Northwest Aerospace Alliance meeting in Lynnwood, Washington on 6 February.
“What would happen if maybe the solution for Boeing and NMA is staring them in the face.”
... flightglobal.com ... "Boeing 787-3 could be reborn as its new NMA" ...
Marco92
Messaggio da Marco92 »
Riesumo questo topic. Cos'è successo in 11 mesi? Il 787-3 è ancora considerato in realtà il prossimo NMA? Non è troppo grosso per sostituire il 737 MAX e competere con il 321?
ally01
Marco92 ha scritto: 13 gennaio 2021, 21:37 Riesumo questo topic. Cos'è successo in 11 mesi? Il 787-3 è ancora considerato in realtà il prossimo NMA? Non è troppo grosso per sostituire il 737 MAX e competere con il 321?
per quale motivo dovrebbe sotituire il MAX?
Marco92
Aereo vecchio. Nato vecchio e spremuto fin troppo.
ally01
è entrato in servizio nel 2017, deve come minimo ripagare i denari spesi nella sua crisi prima di pensare di sostituirlo...
richelieu
Boeing ha l'intenzione di produrre i prossimi nuovi velivoli nello Stato di Washington …
… aerospaceglobalnews.com … Boeing intends to build upcoming new aircraft in Washington …
:usa
