... airforcemag.com ... "Brown’s CSAF Confirmation Hearing Slated for May 7" ...
USAF .....
- richelieu
Re: USAF .....
A giorni l'udienza in Senato per la conferma della nomina del nuovo CSM USAF ...
- richelieu
Re: USAF .....
Le previsioni di alcuni mesi fa sono state confermate ... il traguardo dell'80% non è stato raggiunto ...
... defensenews.com ... "US Air Force bails on Mattis-era fighter jet readiness goal" ...
- richelieu
Re: USAF .....
Nuove applicazioni dell' Intelligenza Artificiale ...
(*) ... news.lockheedmartin.com ... Artificial Intelligence Powers Novel ISR Capability For Operations In Denied Communications Environments ...
... flightglobal.com ... Lockheed Martin Skunk Works demos autonomous reconnaissance pod ...Lockheed Martin’s Advanced Development Programs, known as Skunk Works, has demonstrated an artificial intelligence-powered intelligence, surveillance and reconnaissance (ISR) pod autonomously searching out and confirming a target.
The demonstration was conducted at Edwards Air Force Base in California using an ISR pod mounted on a Lockheed Martin F-16 fighter, says the company on 8 May (*).
The demonstration was conducted in Air Force Test Pilot School.
- richelieu
Re: USAF .....
Joint Base Elmendorf-Richardson ... spettacolare “Moose Walk” ...
... airforcemag.com ... Inside Elmendorf’s Massive ‘Moose Walk’ ...When rows and rows of aircraft, 35 in total, lined up for the largest display of airpower in recent years at Joint Base Elmendorf-Richardson, Alaska, they had two audiences in mind: the Airmen on the ground that made it happen, and most importantly, those who would see the photographs from abroad.
The May 5 “Moose Walk” included 26 F-22s, two C-12s, two C-130s, two E-3 Sentrys, and three C-17s, in addition to HH-60s and a C-17 already in the air.
It was a massive display of readiness by the 3rd and 176th Wings at the Alaska base.
Airmen worked in shifts leading up to the event, combining a full day’s worth of takeoffs and landings into one onslaught of aircraft.
“The message is that we’re ready. We’ve always been ready,” 3rd Wing Commander Col. Robert Davis told Air Force Magazine in an interview.
- richelieu
Re: USAF .....
Il cielo è affollato ... di aerei dell' USAFE ...
... airforcemag.com ... "USAFE Units Converge over North Sea as International Exercises are Canceled" ...The sky above the North Sea in Europe filled with dozens of USAF aircraft on May 27 as fighters from multiple bases joined together in red vs. blue teams to prove that U.S. Air Forces in Europe crews are ready for a high-end fight, even as the COVID-19 pandemic forces the command to change its schedule.
Since the outbreak began, USAFE has canceled or suspended 14 exercises, leaving a shortage in its crews’ ability to train at a high level outside of their own local airspace.
The May 27 “large force employment” event is the culmination of about a month and a half of planning led by RAF Lakenheath, England, to “sharpen combat readiness” across fourth-generation fighter crews at three USAF bases, said Capt. Nathan Hartoin, the chief of weapons at the 48th Fighter Wing who planned the mission, in an interview with Air Force Magazine.
All told, 38 aircraft came together, including F-15Cs and F-15Es from Lakenheath; KC-135s from RAF Mildenhall, England; F-16s from Spangdahlem Air Base, Germany; F-16s from Aviano Air Base, Italy; a NATO E-3 AWACS; and the 603rd Air Operations Center at Ramstein Air Base, Germany, monitoring the action.
Planners and aircrews, because of travel restrictions and social distancing guidelines, met virtually to plan the training event and debrief.
Maintainers split into shifts and worked to get aircraft ready.
- richelieu
Re: USAF .....
C'è stato, però, un inciampo ...richelieu ha scritto: 4 maggio 2020, 12:02 A giorni l'udienza in Senato per la conferma della nomina del nuovo CSM USAF ...
... defensenews.com ... ... "Historic nomination of first black service chief to move forward after lawmaker lifts secret hold" ...
- richelieu
Re: USAF .....
Confermato all'unanimità !!!richelieu ha scritto: 4 maggio 2020, 12:02 A giorni l'udienza in Senato per la conferma della nomina del nuovo CSM USAF ...
... airforcemag.com ... "Senate Confirms Brown to Lead Air Force in Historic Vote" ...
Anche qui ... defensenews.com ... "Senate confirms new Air Force chief of staff in historic, unanimous vote" ...
- richelieu
Re: USAF .....
Coronavirus ... si sperimenta il calore ...
(*) ... "AFRL brings the “heat” to COVID-19" ...
P.S. ... sta succedendo una cosa strana ... sino a poco fa l'articolo di FlightGlobal era perfettamente leggibile ... ora non lo è più ...
... flightglobal.com ... "Coronavirus could be killed in aircraft interiors using heat, early results show" ...The US Air Force Research Laboratory (AFRL) has shown that common ground heaters could be used to raise the temperature of aircraft interiors to levels sufficient to kill the coronavirus and other biological contaminants.
In two tests conducted in May 2020, the interior of a Boeing C-17 cargo aircraft was sealed using materials common to military installations and was heated to 10°C (50°F) above ambient temperatures over a six-hour period, says the AFRL on 9 June (*).
The heaters used in the experiment are found at all military bases, and are commonly used by maintenance crews to keep warm or to heat equipment.
- richelieu
Re: USAF .....
Air Force & Space Force Almanac 2020 ...
... airforcemag.com ... https://www.airforcemag.com/app/uploads ... issue3.pdf ...
- richelieu
Re: USAF .....
Sperimentato un nuovo sistema di addestramento simulato fra velivoli di diverso tipo ...
Da FlightGlobal ...
Da FlightGlobal ...
(*) ... "Lockheed Martin Delivers F-35 Distributed Mission Training Capability" ...The US Air Force (USAF) has successfully linked simulators for the Lockheed Martin F-35, F-22, F-16 fighters, as well as the Boeing E-3 Sentry airborne warning and control system, in a virtual combat training event.
Pilots flew in “a highly contested simulated environment” during final acceptance test of the Distributed Mission Training system at Nellis Air Force Base in Nevada, says Lockheed Martin on 1 July (*).
The Distributed Mission Training system was developed by Lockheed Martin in partnership with the F-35 Joint Program Office and the USAF.
In the future, the training network ought to be able to connect to other aircraft simulators, including those for the Boeing F-15 fighter, says Lockheed Martin.
- richelieu
Re: USAF .....
"Space Force" ... si va a rilento ...
... airforcemag.com ... "Slow Going for Space Force Acquisition Reform" ...
- richelieu
Re: USAF .....
Addestramento congiunto fra F-35 americani e israeliani ...
... airforcemag.com ... "USAF, Israeli F-35s Train Together" ...American and Israeli F-35s trained together in earlier this week, in the second bilateral exercise between the two countries focusing on Joint Strike Fighter operations.
U.S. Air Forces Central Command and the Israeli Air Force conducted “Enduring Lightning II” on Aug. 2 over Southern Israel.
F-35Is with the IAF’s 140th Squadron flew with 421st Expeditionary Fighter Squadron F-35As and a KC-10 from the 908th Expeditionary Air Refueling Squadron.
A Gulfstream G550 “Nachshon” from the IAF’s 122nd Squadron flew command and control for the exercise.
- richelieu
Re: USAF .....
Due bandiere rosse stanno sventolando all'unisono nei cieli d'America ...
... airforcemag.com ... "Red Flags Wrapping Up at Nellis, Eielson" ...The Air Force’s two simultaneous Red Flag training events are set to wrap up this week, with the F-35 participating for the first time in the Alaska version.
Red Flag at Nellis Air Force Base, Nev., and Red Flag-Alaska at Eielson Air Force Base are ending Aug. 14, following about two weeks of intense flying at each location’s training ranges.
Both events began in late July and early August, as organizers worked to counter the spread of COVID-19 while still bringing together flying units from across the Air Force for high-level training.
- richelieu
Re: USAF .....
Ritorno a Diego Garcia ...
... airforcemag.com ... "B-2s Deploy to Diego Garcia" ...The Air Force’s stealth bombers have returned to the Pacific.
Three B-2s arrived Aug. 12 at Naval Support Facility Diego Garcia from Whiteman Air Force Base, Mo., for the first Spirit bomber task force since a deployment to Hawaii in January 2019.
The deployment marks the first time B-2s have deployed to the Pacific since the service’s continuous bomber presence ended in April.
After the 29-hour flight to Diego Garcia, the B-2s joined B-1s already deployed to Andersen Air Force Base, Guam.
- richelieu
Re: USAF .....
Non ci sono solo le "Red Flag ...
... airforcemag.com ... "Combat Hammer Underway at Hill" ...Bomb builders at Hill Air Force Base, Utah, this week are testing weapons for F-35As, B-1s, and MQ-9s as part of an in-depth combat evaluation exercise looking at the effectiveness of the bombs released from multiple aircraft.
The 86th Fighter Weapons Squadron, the military’s sole group tasked with testing the effectiveness of precision weapons, conducts the regular Combat Hammer evaluation at the Utah Test and Training Range.
This year’s event includes F-35s from both Hill and Nellis Air Force Base, Nev., along with B-1s from Ellsworth Air Force Base, S.D., and MQ-9s from Creech Air Force Base, Nev.
“During Combat Hammer, we are tasked to evaluate the reliability, maintainability, suitability, accuracy, and readiness of combat weapons systems against realistic threats and targets,” said Master Sgt. George Bermudez, superintendent of WESP at the 86 FWS ...
- richelieu
Re: USAF .....
Addestramento in Polonia ... con lo sguardo rivolto ad Est ...
... airforcemag.com ... "F-16s, KC-135s Deploy to Poland for Training Rotation" ...
F-16s and KC-135s deployed to two bases in Poland for an aviation rotation, shortly after the U.S. and Poland agreed to increase the amount of forces in the country.
F-16s from the 52nd Fighter Wing at Spangdahlem Air Base, Germany, deployed to Łask Air Base for Aviation Detachment Rotation 20.4, while KC-135s from the Illinois Air National Guard’s 126th Air Refueling Wing will be based at Powidz Air Base.
- richelieu
Re: USAF .....
Il nuovo CSM USAF ...
... airforcemag.com ... "Brown Outlines Leadership Style, Expectations as New Chief of Staff" ...
- richelieu
Re: USAF .....
La stagione degli uragani ...
Anche qui ... nhc.noaa.gov ... "Tropical Storm Laura" ...
... airforcemag.com ... "Gulf Coast Air Bases Prepare for Possible Twin Hurricanes" ...Air Force bases along the Gulf of Mexico are preparing for twin tropical storm systems that are expected to make landfall as hurricanes within the next several days.
Tropical Storm Laura, as well as a tropical depression likely to strengthen into Tropical Storm Marco, could grow into a rare case of two tropical cyclones to barrel through the Gulf of Mexico at the same time, according to the National Weather Service.
They are slated to strike Florida, Mississippi, Alabama, Louisiana, Texas, and Puerto Rico during the week of Aug. 23.
Wind and water could smack communities in the Florida Panhandle that have barely started rebuilding from other recent storms.
Tyndall Air Force Base, Fla., was decimated by Category 5 Hurricane Michael in 2018 and is now staring down new potential threats.
- richelieu
Re: USAF .....
Ultime dall'USAF ...
Uragani ... https://www.airforcemag.com/ahead-of-do ... stays-put/ ...
Rotazioni ... https://www.airforcemag.com/macdill-kc- ... rs-return/ ...
- richelieu
Re: USAF .....
USAF ... un preoccupato CSM Brown lancia l'allarme ...
... airforcemag.com ... Brown: ‘Accelerate Change or Lose’ ...The Air Force has a window of opportunity to change and it must do so quickly, because “our advantage as a nation, as an Air Force, as a joint team, is eroding,” Chief of Staff Gen. Charles Q. Brown Jr. said Aug. 29, noting the service this week will release a paper called, “Accelerate Change or Lose.”
The Air Force has been engaged in conflict—mainly in the Middle East - for the last 30 years, he explained, while “at the same time, our adversaries, … China and Russia, have done things to accelerate and or move to impact our advantage. And so, our advantage is eroding, so that’s why I say accelerate change or lose,” Brown said during a speech at the virtual National Guard Association of the United States conference.
The potential consequences of not adapting are dire, Brown said: “Look at losing a great power competition. Look at losing a high-end fight. Look at losing quality Airmen, losing our credibility. And, unfortunately, I’m also thinking about how we might lose aspects of our national security.”
- richelieu
Re: USAF .....
la direttiva “Accelerate Change or Lose” annunciata dal CSM USAF è stata resa nota ...
... airforcemag.com ... Brown: Change Now or Risk ‘Losing a High-End Fight,’ and ‘Quality Airmen’ ...The Air Force, under the direction of its new top uniformed leader, risks losing its superiority and a future conflict if change does not begin immediately, from how the service buys and evaluates weapons to how it trains and deploys Airmen, Chief of Staff Gen. Charles Q. Brown Jr. writes in his first directive to the service.
In an eight-page “strategic approach” memorandum to the force, titled “Accelerate Change or Lose,” Brown issues stern warnings on the ramifications of not taking threats seriously, and the importance of the Air Force clearly making its case to the country at large, saying failure is a realistic consequence.
- richelieu
Re: USAF .....
In addestramento ... dall'altra parte del mondo ...
... airforcemag.com ... B-1s, B-2s Train Down Under ...Air Force B-1s and B-2s deployed to the Indo-Pacific came together to train with U.S. and Australian joint terminal attack controllers down under, dropping training bombs at three different training ranges throughout August.
The B-1s, deployed to Andersen Air Force Base, Guam, and B-2s deployed to Naval Support Facility Diego Garcia, made multiple passes over the Delamere, Bradshaw, and Mount Bundley training areas where Marine Rotational Force-Darwin and Australian joint terminal attack controlers controlled the strikes, according to a Pacific Air Forces release.
The bombers were refueled by KC-135s deployed to Australia from Kadena Air Base, Japan.
- richelieu
Re: USAF .....
Prove di guerra futura ...
Anche qui ... c4isrnet.com ... Behind the scenes of the US Air Force’s second test of its game-changing battle management system ...
... airforcemag.com ... ‘Smart’ Bullet Downs Cruise Missile in 2nd ABMS Test ...More than 1,600 personnel, 60 companies, over a dozen aircraft, and dozens of radars and sensors came together for a massive Air Force-led event that utilized everything from boots on the ground to satellites in space to test how the service expects to fight a war in the future.
The event culminated when a cruise missile was downed by a “smart” bullet.
The Air Force’s second “Advanced Battle Management System onramp,” long delayed because of COVID-19, took place on Sept. 3, largely within four national training ranges, as well as a part operations center, part fusion cell at Joint Base Andrews, Md.
The new cloud-based, artificial intelligence-fueled command center brought together new and legacy ways of fighting wars into the service’s push for joint all-domain command and control.
- richelieu
Re: USAF .....
D'ora in avanti chiamateli "e" ...
Anche qui ... af.mil/News ... SECAF unveils new “eSeries” classification in nod to Department’s digital future ...
E qui ... defensenews.com ... US Air Force launches new ‘eSeries’ aircraft designation. The internet has questions ...
... airforcemag.com ... Air Force Introduces e-Planes for the Digital Era ...For nearly 80 years, experimental X-planes have been the marker of cutting-edge aerospace technology.
Now, the digital age is ushering in a new kind of aircraft: the e-series.
The Air Force and Space Force will begin adding “e” to the names of aircraft, weapons, and satellites that are designed and tested using digital engineering, Air Force Secretary Barbara M. Barrett said Sept. 14 at the Air Force Association’s virtual Air, Space & Cyber Conference.
“For 73 years, the entire history of the Air Force, X-planes have represented technological innovation,” Barrett said.
“Today, the e-plane and e-sat will join them in making history and ensuring Airmen and space professionals have modern tools to protect our nation.”
- richelieu
Re: USAF .....
Nonostante tutto quello che è capitato ... li stiamo aspettando nel Regno Unito entro il 2021 ...
Inoltre ... airforcemag.com ... USAF to Reactivate 495th Fighter Squadron as F-35 Unit ...
... airforcemag.com ... USAFE Still Targeting F-35s at Lakenheath by 2021, Despite Construction Delays ...The head of U.S. Air Forces in Europe is “convinced” the command will base F-35As at RAF Lakenheath, U.K., on time in late 2021, despite some delays to military construction and a possible slowdown in F-35 deliveries because of COVID-19.
“I am clear eyed that we’ve got a fair amount of work to do from the infrastructure needed to get the facilities ready, and at the same time work through the natural challenges of any bed down that has to do with the appropriate connectivity, security clearances, and those types of activities required to get an airplane in,” USAFE boss Gen. Jeffrey L. Harrigian told reporters during a panel at AFA’s virtual Air, Space & Cyber Conference on Sept. 14.
“But, we’re looking at the end of ’21 as the target remains on track for us to get the airplanes here.”
The original plan was to have the aircraft begin arriving this year, but that slipped to 2021.
Now construction delays have threatened that timeline, with projects about 25 percent over the $480 million budget ...
- richelieu
Re: USAF .....
E, come c'era da aspettarsi, emergono confusione e dubbi ... e l'USAF chiede che il prefisso venga utilizzato soltanto nel periodo che precede la produzione del velivolo ...
... psk.blog.24heures.ch ... USA, une nouvelle désignation qui porte à confusion ! ...Les avions, les satellites et autres armes conçus à l’aide de l’ingénierie numérique seront désignés comme faisant partie de la nouvelle « série électronique » de l’armée de l’air et recevront le préfixe « e », a annoncé lundi la secrétaire de l’armée de l’air, Barbara Barrett.
Sauf, que cette désignation porte à confusion, comme nous allons le voir.
Cette annonce a initialement semé la confusion sur les réseaux sociaux, car les utilisateurs ont souligné que l'armée américaine utilise déjà le préfixe « E » pour désigner les avions qui transportent des équipements pour la guerre électronique, l'alerte avancée aéroportée et les missions de commandement et de contrôle aéroportés, ainsi que ceux qui fournissent des communications.
L'armée de l'air a ensuite précisé que l'indicateur eSeries « e » devrait être rendu en minuscules pour le différencier des avions de guerre électronique et d'alerte rapide qui reçoivent le préfixe « E ».
Mais le mal semble être fait.
L’USAF a donc demandé à ce que l'indicateur « e » soit temporaire et que l’abandon soit fait une fois que le programme entre en production.
- richelieu
Re: USAF .....
Il C-17 ... un cargo tuttofare ...
... airforcemag.com ... C-17s Serve as Bombers, Artillery Targeting Systems in AMC Tests ...Air Mobility Command is testing how its workhorse strategic airlifter can not only carry in combat weapons systems, but also directly contribute to a fight by dropping bombs and providing targeting data for artillery.
As part of the high-tech Advanced Battle Management System “onramp” evaluations earlier this month, AMC C-17s tested dropping joint direct attack munitions, making the lumbering mobility jets effectively serve as bombers, AMC boss Gen. Jacqueline D. Van Ovost said Sept. 14 during the Air Force Association’s virtual Air, Space & Cyber Conference.
- richelieu
Re: USAF .....
Esercitazione "Thracian Viper 20" ... un velato (ma non troppo) avvertimento alla Turchia ?
Anche qui ... ac.nato.int ... Bulgaria Hosts Multinational Flying Training Thracian Viper 2020 ...
... airforcemag.com ... Aviano, Ramstein Airmen Head to Bulgaria for Thracian Viper 20 ...Airmen from Aviano Air Base, Italy, and Ramstein Air Base, Germany, will train with their counterparts from Bulgaria, Greece, and Romania as part of exercise Thracian Viper 20, the 31st Fighter Wing said Sept. 18.
The exercise, which is being held Sept. 18-25 at Graf Ignatievo Air Base, Bulgaria, looks to boost participating air forces’ “operational capacity, capability, and interoperability” with its host country, a wing release stated.
“During the exercise, U.S. and Bulgarian air forces will conduct training, enhancing our ability to rapidly deploy to remote locations and take command and control of the region,” U.S. Air Forces in Europe-Air Forces Africa wrote in a release.
- richelieu
Re: USAF .....
Ancora sull'esercitazione "Thracian Viper 20" ... gli F-16 di Aviano alla ribalta ...
... airforcemag.com ... Triple Nickel Hones Skills at Thracian Viper 20 ...For Aviano Air Base’s 555th Fighter Squadron, Thracian Viper 20 is about more than just training.
The multilateral exercise, to which the squadron sent Airmen and six F-16s, boosts “operational capacity and capability,” as well as interoperability with Bulgaria, Maj. Rohan Naldrett-Jays, the squadron’s chief of standardizations and evaluation, told Air Force Magazine.
But, it also helps the Italy-based squadron fine-tune its ability to deploy aircraft and manpower anywhere in the European theater with agility - a critical part of Chief of Staff Gen. Charles Q. Brown Jr.’s “accelerate change, or lose” directive for the Total Force.
- richelieu
Re: USAF .....
"Exercise Wolff Pack" ... aerocisterne KC-135 dell' USAF in appoggio alle forze aeree degli alleati europei ...
... airforcemag.com ... Tankers Practice Speedy Deployment in European Refueling Exercise ...KC-135 Stratotankers from the 100th Air Refueling Wing at RAF Mildenhall, U.K., practiced supporting other aircraft in “Exercise Wolff Pack,” a multinational event over Europe that ended Oct. 1.
The three-day effort vetted the wing’s ability to deploy its aircraft to multiple places across Europe “in order to protect and defend partners, allies, and U.S. interests at a moment’s notice” and sharpen the agile combat employment (ACE) construct, wing spokesperson Capt. Shelley A. Spreier told Air Force Magazine in a Sept. 30 email.
ACE is the Air Force’s effort to move troops and planes around the globe quickly and with less reliance on brick-and-mortar installations, to be more responsive and resilient if bases are threatened.
- richelieu
Re: USAF .....
Tutti negativi ... tranne "The Donald" ...
... airforcemag.com ... Top USAF, DOD Officials Test Negative for COVID-19 After White House Event ...
... news.usni.org ... Marine Commandant Berger Tested Negative for COVID-19 After White House Event ...
- richelieu
Re: USAF .....
Pure i Joint Chiefs ... ed altri ...
... news.usni.org ... 7 Joint Chiefs, 2 Senior Leaders in Quarantine After Meetings with COVID-19-Positive USCG Flag ...
Seven members of the Joint Chiefs of Staff, including chairman Gen. Mark Milley and vicechair Gen. John Hyten, plus two other senior U.S. military commanders are in quarantine after coming in contact with a Coast Guard flag officer who tested positive for COIVD-19, USNI News has learned.
The military leaders all had meetings last week in the Pentagon with Vice Commandant of the Coast Guard Adm. Charles Ray. Ray tested positive for the virus on Monday after symptoms over the weekend, a senior defense department official told USNI News.
- richelieu
Re: USAF .....
Edwards AFB ... dopo 11 anni l'Air Force organizza un Airshow molto "sui generis" ...
... airforcemag.com ... Edwards AFB Goes ‘Hybrid’ for First Air Show in Over a Decade ...Edwards Air Force Base, Calif., had scheduled its first on-base air show in 11 years to take place in October 2020.
Then the coronavirus pandemic intervened.
COVID-19 has forced Airmen across the country to get creative in hosting air shows, as everything from concerts to medical appointments moves online to avoid gathering crowds.
The 412th Test Wing at Edwards is no different.
In response to this year’s unique challenges, Edwards this week is hosting the Aerospace Valley Hybrid Air Show, wing spokesman and air show executive director Ed Buclatin said in an email.
- richelieu
Re: USAF .....
La nuova frontiera dell'addestramento ... alle soglie della fantascienza ...
Anche qui … scott.af.mil … AFRL neurotechnology partnership aims to accelerate learning …
Tutto questo mi ricorda qualcosa ...
… flightglobal.com … US Air Force aims to train pilots faster using brain electrode …Some will feel like a slight tingling sensation.
Others will feel nothing at all.
The electrode placed inside the ear canal isn’t designed to shock.
Rather, the US Air Force Research Laboratory (ARFL) believes the earbud-like device, when placed next to the brain’s vagas nerve, will have more of an intellectually stimulating effect.
It ought to create moments of super learning, controllable periods of focus that allow pilots to soak up their flight training faster than humanly possible.
In August, the AFRL’s 711th Human Performance Wing launched its Individualized Neural Learning System (iNeuraLS) project, an effort to speed up pilot training through brain stimulation.
The US Air Force (USAF) has been dogged for years by a pilot shortage and hopes the technology can help it quickly refill its ranks.
- richelieu
Re: USAF .....
Lt. Col. Jared “Vic” Santos ... 1000 ore di volo su F-35A ...
(*) … 388fw.acc.af.mil … First USAF pilot hits 1,000 flying hours in F-35A …
… airforcemag.com … Hill Airman Makes USAF History in the F-35A …Lt. Col. Jared “Vic” Santos, 388th Fighter Wing special projects manager, recently became the first USAF Airman to accrue 1,000 flying hours in the F-35A Lightning II fighter jet, the wing announced.
Santos hit the milestone during an approximately two-hour, “four-on-six tactical intercept” training sortie Oct. 22 over the Utah Test and Training Range, according to a release.
Wing Commander Col. Steven Behmer heralded the moment as a victory for Santos, his wing, and the service at large.
“A relatively short time ago, the Air Force was standing this program up,” Behmer said in the release (*).
“Now we’ve got our first 1,000-hour-pilot. Pilots like Vic are able to pass that experience on to younger pilots in the F-35 community. They are really going to get the best out of this jet, which is already very capable, and continuing to improve.”
