Strike Eagle
richelieu
Re: Strike Eagle
Messaggio da richelieu » 16 aprile 2021, 1:10
Un tiro a lunga distanza ... ma non è dato sapere a quale ...
An F-15C Eagle set a record for the longest air-to-air kill, but we won’t know what the record is.
In March, an F-15C fired an AIM-120D Advanced Medium-Range Air-to-Air Missile at a BQM-167 targeting drone in the longest known air-to-air missile shot to date, resulting in a “kill” of the target from the farthest distance recorded, the 53rd Wing said in a release.
However, the wing would not release the length of the shot, or the previous known record.
airforcemag.comF-15C Records Longest Air-to-Air Shot in Test
richelieu
Re: Strike Eagle
Messaggio da richelieu » 25 aprile 2021, 11:36
F-15EX ... ed ora sono due ...
Just five weeks after the first F-15EX Eagle II fighter jet touched down at Eglin Air Force Base - and less than two weeks after that F-15EX was officially unveiled to the public - the second of the new fighter aircraft arrived at the base.
F-15EX "002" was flown to Eglin on Tuesday by Maj. Aaron Eshkenazi, F-15EX operational test pilot with the 85th Test and Evaluation Squadron (85th TES), part of the Eglin-headquartered 53rd Wing.
amp.nwfdailynews.comAnd then there were two: Second F-15EX arrives at Eglin Air Force Base for testing
Anche qui … airforcemag.comSecond F-15EX Eagle II Delivered to Eglin
richelieu
Re: Strike Eagle
Messaggio da richelieu » 29 aprile 2021, 19:29
I due F-15EX appena consegnati sono pronti a partecipare all'esercitazione Northern Edge in Alaska ... :coldcold:
Both of the Air Force’s new F-15EX Eagle II fighters will fly in the Northern Edge exercise in Alaska next week to participate in broader joint all-domain command and control experiments, 11th Air Force Commander Lt. Gen. David A. Krumm said April 28.
The jets will also employ their new electronic warfare suites in the wargame.
“We’re bringing up F-15EX … with its capabilities, including the EPAWSS,” or Eagle Passive Active Warning Survivability System electronic warfare suite, to participate in Northern Edge 2021, Krumm said from Joint Base Elmendorf-Richardson, Alaska, during an AFA “Air and Space Warfighters in Action” streaming event.
airforcemag.comBrand-New F-15EX to Participate in Northern Edge Exercise, JADC2 Experiments
richelieu
Re: Strike Eagle
Messaggio da richelieu » 12 maggio 2021, 19:20
Project Strike Rodeo ... a Eglin hanno caricato 5 AGM-158 su uno Strike Eagle ...
The 85th Test and Evaluation Squadron at Eglin Air Force Base, Florida, loaded five AGM-158 Joint Air-to-Surface Standoff Missiles onto an F-15E, more than doubling the Strike Eagle’s normal JASSM load.
The May 11 test, part of the Project Strike Rodeo at the base, originated from a discussion during a January 2021 conference working group, which focused on a scenario where the standoff missiles would be employed by a bomber escorted by fighters into a contested environment ...
Participants in the group “hypothesized that a formation of fighters” could be used to fire the JASSM salvo, reducing the risk to bombers ...
This would require increasing the capability of fighters to carry the large missiles, since the current maximum payload is two JASSMs.
airforcemag.comEglin Testers Load Five JASSMs onto an F-15E
richelieu
Re: Strike Eagle
Messaggio da richelieu » 22 maggio 2021, 0:09
Esercitazione "Northern Edge" ... come si sono comportati i nuovi F-15EX ...
The F-15EX both shot down some adversaries and was shot down itself during the recent Northern Edge wargame in Alaska, and work is underway to analyze the results of its first appearance in the major force exercise, according to a test pilot who participated.
Statistics such as the mission capable rates of the aircraft have not yet been tabulated, but the jets flew a combined 33 sorties during the exercise from April 28-May 14.
The two first-of-their-kind F-15EXs - being used for concurrent operational and developmental test - played in Northern Edge only two weeks after they were delivered to the Air Force.
The goal was to see if they could play the part now met in the Combat Air Forces by the F-15C plus add some capability to that mission, according to Lt. Col. John O’Rear of the 84th Test and Evaluation Squadron.
Among the test points were how the F-15EXs could integrate with F-15Cs as well as larger forces, including fifth-generation F-22s and F-35s, O’Rear said.
“We flew them with two-ships of F-15C models, two-ships of F-15E models, … two-ships of EXs supporting other fourth-gen [flights], and integrating with the F-22 and F-35,” he said.
airforcemag.comF-15EX Wins Some, Loses Some in Northern Edge
Re: Strike Eagle
Messaggio da JT8D » 26 agosto 2021, 18:55
Rollout per l'F-15QA, destinato alla Qatar Emiri Air Force (QEAF):
https://www.md80.it/2021/08/26/boeing-s ... anced-jet/
richelieu
Re: Strike Eagle
Messaggio da richelieu » 27 ottobre 2021, 23:51
F-15EX ... primi test operativi dalle parti di Las Vegas ... :desert:
The F-15EX Eagle ll is undergoing its first-ever operational test mission paired with F-15Cs and F-15Es at Nellis Air Force Base Oct. 18-25.
“We’ve never done full, large-scale operational tests with the F-15EX, because it’s only been in the U.S. Air Force’s hands for six months,” said Lt. Col. Kenneth Juhl, Air Force Operational Test and Evaluation Center F-15 tester.
“The fact that we’re going this fast in operational test is definitely owing to the chief of staff of the Air Force’s accelerate change or lose mentality.”
There are currently two F-15EXes in existence.
The Air Force accepted delivery of them at Eglin AFB, Florida, in March and April 2021.
af.milF-15EX undergoes first operational test mission at Nellis AFB
richelieu
Re: Strike Eagle
Messaggio da richelieu » 28 ottobre 2021, 17:23
"F-15EX ?" ...
"Meglio lasciar perdere" ... :shocked!:
The U.S. Air Force should abandon its plans to revive fourth-generation fighters under the F-15EX program, and instead focus on building more F-35As and new stealthy fighter jets, according to a new paper from the Mitchell Institute for Aerospace Studies.
Former F-16 pilot Heather Penney, a senior resident fellow at the institute, said in the paper released Monday that the F-15EX Eagle II program is a dead end — one based on outdated technology that wouldn’t suit the Air Force well in a high-end fight nor save money over the F-35 program.
She expects the stealth-less F-15EX will end up playing a limited defensive role in a war, at a time when the Air Force has a limited inventory of fighters.
“Given this reality, funding limitations and modern mission demands, the Air Force should seek the soonest reasonable termination point for the F-15EX,” Penney wrote.
The Air Force should instead shift that money to boosting F-35 production and develop another fighter jet, Penney said — one that is affordable, flexible and has stealth capability.
This would be in addition to the highly classified Next Generation Air Dominance program that would start fielding sometime in the 2030s, to which Penney said the Air Force should commit wholeheartedly.
defensenews.comMitchell Institute: Ditch F-15EX for more F-35s, new stealth fighters
Anche qui … airforcemag.comAlternate Fighter Plan: Cut F-15EX, Extend F-22, Buy New Stealth Jets, More F-35s
Re: Strike Eagle
Messaggio da JT8D » 30 ottobre 2021, 11:51
Riguardo l'F-15EX, GE ha comunicato che ha ricevuto un $1.58 billion firm-fixed-price contract dall'U.S. Air Force per la fornitura di motori F110:
https://www.md80.it/2021/10/30/ge-contr ... tori-f110/
richelieu
Re: Strike Eagle
Messaggio da richelieu » 31 ottobre 2021, 0:34
Quindi, nonostante le raccomandazioni del "Mitchell Institute", il programma va avanti ...
Ulteriori informazioni qui … airforcemag.comGE Secures $1.58 Billion Contract for F-15EX Engines
richelieu
Re: Strike Eagle
Messaggio da richelieu » 7 novembre 2021, 0:18
F-15EX Eagle II ... Rapporto al Congresso ...
On March 11, 2021, the U.S. Air Force took delivery of its first F-15EX Eagle II fighter.
The Eagle II program is intended to deliver 144 aircraft to replace aging F-15Cs, most of which are in the Air National Guard.
The Trump Administration’s FY2020 budget proposal included a request for $1.1 billion to buy 8 F-15EX aircraft, the first procurement toward a planned initial buy of 144.
This proposal represented a change from previous Air Force plans to procure only stealthy “fifth-generation” fighter aircraft.
The subsequent FY2021 defense budget proposal requested about $1.27 billion in procurement funding for 12 Eagle IIs and $133.5 million in advance procurement for future aircraft.
The proposed budget also requested about $159.8 million for F-15EX research and development.
news.usni.orgReport to Congress on F-15EX Eagle II Fighter
richelieu
Re: Strike Eagle
Messaggio da richelieu » 13 novembre 2021, 0:54
Motori General Electric per gli F-15EX ... Pratt & Whitney da deciso di non presentare ricorso ...
Pratt & Whitney has opted not to protest the Air Force’s sole-source contract to GE Aviation to power all the service’s F-15EX fighters, a contract worth $1.58 billion.
GE’s contract, awarded Oct. 29, starts with 29 of its F110-GE-129 engines followed by seven option lots for a total of 329 engines, running ten years, if all the options are exercised.
The Air Force is planning to build between 144 and 200 F-15EXs.
Pratt issued a short statement saying only that it “will not submit a protest regarding the F-15EX propulsion decision,” adding that it is “proud to continue our support of the USAF’s F-15 fleet.”
airforcemag.comPratt & Whitney Won’t Protest GE’s Win of F-15EX Engine Contract
richelieu
Re: Strike Eagle
Messaggio da richelieu » 1 febbraio 2022, 1:02
F-15EX ... primo lancio di un missile AIM-120D ...
The F-15EX successfully fired its first weapon on Jan. 25, launching an AIM-120D missile at a BQM-167 unmanned aerial target over the Gulf of Mexico, the Air Force announced.
Maj. Benjamin Naumann and Maj. Mark Smith, pilots with the 40th Flight Test Squadron, flew the fighter during the test fire, as part of the 53rd Wing’s Combat Archer - an air-to-air weapons system evaluation program.
The F-15EX “detected the drone using onboard sensors, acquired a weapons-quality track, and launched the missile at the target” as part of the test, the Air Force announced in a release (*).
The shot was then determined to be a success.
... airforcemag.com ... F-15EX Fires First Missile Successfully ...
(*) ... af.mil ... Eagle II fires first missile during live-fire event ...
richelieu
Re: Strike Eagle
Messaggio da richelieu » 18 febbraio 2022, 1:10
Un aggiornamento miliardario per gli F-15J della Japan Air Self-Defense Force ...
Japan has confirmed that it will put 68 license-built Mitsubishi F-15J Eagle interceptors through an upgrade that will improve its radar, electronic warfare, weapons carriage capacity and stand-off weapon capabilities.
A document released by the Japanese Ministry of Defense’s Acquisition, Technology and Logistics Agency, or ATLA, in early February also estimated that the total cost of the upgrade and sustainment of its F-15 fleet up to 2045 will cost 646.5 billion Japanese yen or $5.62 billion.
An MoD spokesman confirmed to Defense News that the 68 F-15s that will receive the upgrade will be single-seat F-15Js that have previously gone through the Multi-Stage Improvement Program.
However, the fate of 34 remaining post-MSIP Japan Air Self-Defense Force or JASDF F-15s, which are two-seat F-15DJs, is still up in the air with the MoD still “holding internal discussions,” the spokesman told Defense News.
defensenews.comJapan confirms details of F-15J upgrade program worth $5.6 billion
richelieu
Re: Strike Eagle
Messaggio da richelieu » 28 aprile 2022, 16:22
F-15EX ... si prospettano grossi tagli ...
The Air Force plans to divest nearly 650 aircraft over the coming five years while purchasing fewer than 250, reducing its fleet by exactly 400 tails, a pair of congressmen said during House Armed Services Committee hearings April 27.
Those cuts would include a much-reduced buy for the F-15EX.
The F-15EX is one of the few fighters the Air Force has planned on buying in the immediate future.
Within those overall changes that the Air Force has planned for its fleet, one of the biggest shifts scheduled to take place in the next five years is with the F-15EX Eagle II, the fourth-generation fighter meant to complement the F-35 and NGAD.
Most immediately, the 2023 budget request asks to buy 24 F-15EXs, double the 12 it requested in 2022.
But in the longer term, the Air Force’s J-books reveal that the service plans to reduce the overall buy of the EX from 144 to 80 - a 44 percent decline.
It’s a move Air Force officials hinted at several years ago.
That combination of a bigger buy in this budget and a smaller one overall was intentional, Air Force Secretary Frank Kendall told lawmakers.
airforcemag.comAir Force Leaders Explain 5-Year Divestment Plan and Smaller F-15EX Fleet
Anche qui … thedrive.com/the-war-zoneThe F-15EX Program Is In Trouble
richelieu
Re: Strike Eagle
Messaggio da richelieu » 13 ottobre 2022, 23:17
Rapporto al Congresso sul programma F-15EX Eagle II ...
news.usni.orgReport to Congress on the Air Force F-15EX Eagle II Fighter Program
richelieu
Re: Strike Eagle
Messaggio da richelieu » 1 novembre 2022, 10:08
Gli F-15C/D vengono ritirati dalla base aerea giapponese di Kadena per "raggiunti limiti di età" ... petrebbero essere in futuro sostituiti dagli F-15EX ...
Starting Nov. 1 and continuing over the next two years, the Air Force will bring home the 48 F-15C/D Eagles now stationed at Kadena Air Base, Japan.
A permanent replacement has yet to be determined, but in the meantime, other types of fighters will cycle through deployments to the base, to preserve its battle readiness as the “tip of the spear” in the Indo-Pacific.
Kadena, located on the island of Okinawa, is the Air Force’s closest land-based location to Taiwan, some 450 miles away.
In addition to fighters, Kadena hosts tankers, mobility, special operations, and intelligence, surveillance, and reconnaissance platforms.
The F-15C/D model was introduced in 1979, and most examples average nearly 40 years of age.
airandspaceforces.comKadena-Based F-15C/Ds Start Retiring; F-15EX Likely Replacement
Anche qui … defensenews.comAir Force to begin withdrawing F-15s from Kadena in November
richelieu
Re: Strike Eagle
Messaggio da richelieu » 1 novembre 2022, 20:53
Alcuni parlamentari Repubblicani si oppongono al ritiro degli F-15 da Okinawa ...
Four key Republicans on Capitol Hill are questioning the Air Force’s decision to replace two permanent F-15C Eagle fighter squadrons in Okinawa with rotational forces.
In a new letter to Defense Secretary Lloyd Austin, the lawmakers expressed concern about the plan and asked for a briefing on the decision to remove permanent forces from Kadena Air Base in Okinawa, Japan.
Sen. Marco Rubio, R-Fla., and Rep. Mike Gallagher of Wisconsin - the top Republican on the Armed Services personnel subcommittee - sent the letter on Tuesday.
Sen. Bill Hagerty of Tennessee, the former ambassador to Japan, and Rep. Mike McCaul of Texas, the top Republican on the Foreign Affairs Committee, also signed onto the letter.
defensenews.comRepublicans push back on Okinawa F-15 withdrawal
richelieu
Re: Strike Eagle
Messaggio da richelieu » 4 novembre 2022, 8:56
Nel frattempo ... l'USAF sta considerando altre opzioni ...
F-22s from Elmendorf Air Force Base, Alaska, will initially fill in for F-15Cs as they begin to leave Kadena Air Base, Japan, but the Air Force is eyeing a later and longer deployment of F-16s from Spangdahlem Air Base, Germany, to reinforce the island base, Pentagon officials said.
It would be the second time in as many years that F-16s from Spangdahlem were considered for relocation.
The aircraft were to be consolidated with F-16s at Aviano Air Base, Italy, in 2021, but the Pentagon’s Global Posture Review nixed the plan, along with designs to replace them at Spangdahlem with tankers and special operations forces.
The Air Force won’t discuss deployments and won’t comment officially on its plans to backfill the F-15s at Kadena, or any other base, according to a service spokesperson.
airandspaceforces.comSpangdahlem May Head to Kadena After Alaskan F-22s
richelieu
Re: Strike Eagle
Messaggio da richelieu » 18 giugno 2023, 1:02
L'USAF acquisterà altri sei F-15EX nel 2025 in base al Disegno di Legge della Camera ...
L'USAF otterrebbe altri sei caccia F-15EX Eagle II nell'anno fiscale 2025 in base alla versione proposta dal Comitato per i Servizi Armati della Camera del National Defense Authorization Act per l'anno fiscale 2024.
Se attuata, la proposta potrebbe aumentare gli sforzi dell'USAF per acquistare un maggior numero di nuovi caccia per modernizzare la sua flotta.
I documenti di bilancio del servizio mostrano che si prevede di richiedere 24 caccia Boeing F-15EX nel 2025, la stessa quantità del 2023 e del 2024.
defensenews.comUS Air Force would buy six more F-15EXs in 2025 under draft House bill
Anche qui … airandspaceforces.comHASC Chair Rogers Inserts Funding for More F-15EXs in 2025
richelieu
Re: Strike Eagle
Messaggio da richelieu » 18 agosto 2023, 16:27
Boeing ha effettuato il roll-out del terzo F-15EX dopo 2 anni e mezzo di ritardo nelle consegne ...
Boeing ha ha effettuato il roll-out del primo F-15EX Eagle II a St. Louis, velivolo che sarà consegnato entro la fine dell'anno a uno squadrone operativo dell'USAF, come ha dichiarato l'azienda sui social media.
L'aereo, dipinto con vernice di fondo gialla e verde, è stato mostrato mentre attraversava una strada che divide la fabbrica della Boeing dall'aeroporto.
Il roll-out ha posto fine a un intervallo di quasi 2 anni e mezzo dalla consegna all'USAF dei primi due F-15EX effettuata nei mesi di Marzo e Aprile del 2021.
I primi due Eagle II sono stati consegnati allo squadrone di prova dell'USAF e sfoggiano una configurazione leggermente diversa rispetto a quella delle consegne successive.
aviationweek.comBoeing Rolls Out Third F-15EX After 2 1/2-Year Delivery Gap
richelieu
Re: Strike Eagle
Messaggio da richelieu » 5 novembre 2023, 16:20
Boeing ha fatto volare il terzo F-15EX Eagle II, il primo costruito nella configurazione operativa definitiva ...
Dopo più di due anni dal volo iniziale del primo esemplare, Boeing ha fatto volare per la prima volta il terzo F-15EX Eagle II, che è anche il primo ad essere prodotto nella configurazione operativa definitiva.
L'aereo ha volato dipinto solo con la vernice di fondo e un piccolo numero di serie (20-0003) sulle due derive, e riceverà i colori e le insegne finali prima della consegna all'USAF.
theaviationist.comBoeing Flies Third F-15EX Eagle II, The First Built In Final Operational Configuration
richelieu
Re: Strike Eagle
Messaggio da richelieu » 27 novembre 2023, 20:56
L'F-15EX dell'USAF risveglia l'interesse per il caccia della Boeing ...
La Boeing farà presto volare il terzo F-15EX Eagle II di sviluppo per l'USAF, dopo averne effettuato il roll-out in Agosto.
Quell’evento si è verificato più di due anni dopo che i primi due F-15EX erano stati consegnati all’USAF all’inizio del 2021 per iniziare i test.
ainonline.comUSAF F-15EX Ignites Renewed Interest in the Boeing Fighter
richelieu
Re: Strike Eagle
Messaggio da richelieu » 5 gennaio 2024, 1:11
Due nuovi caccia F-15EX (n. 3 e n.4) sono arrivati a Eglin per i test
Il terzo e il quarto esemplare del Boeing F-15EX Eagle II sono arrivati alla Eglin Air Force Base, in Florida, per i test, ha dichiarato l'USAF il 30 Dicembre scorso.
Per mantenere la scaletta del programma, altri sei devono essere consegnati prima del mese di Luglio.
Secondo quanto comunicato dall'USAF i nuovi velivoli, denominati "EX3" ed "EX4", sono arrivati a Eglin il 20 Dicembre, ha detto l'Air Force.
"EX1", "EX2" ed "EX4" appartengono al 53rd Wing, mentre "EX3" appartiene al 96th Test Wing.
airandspaceforces.comNew F-15EX Fighters - Nos. 3 and 4 - Arrive at Eglin for Testing
richelieu
Re: Strike Eagle
Messaggio da richelieu » 6 febbraio 2024, 17:48
Il caccia F-15EX della Boeing potrebbe volare per l'Arabia Saudita
Il colosso aerospaziale Boeing ha avuto un inizio difficile nel 2024.
Tuttavia, i funzionari dell’Azienda stanno cercando di presentare l'F-15EX Eagle II ai potenziali acquirenti in Medio Oriente.
La variante aggiornata dell’F-15 è stata esposta al World Defense Show (WDS) a Riyadh, in Arabia Saudita – e il Regno è tra le parti interessate.
Flight Global ha riferito per la prima volta che la Royal Saudi Air Force potrebbe cercare di aggiornare la sua attuale flotta di F-15SA, mentre potrebbe, al tempo stesso, cercare di acquisire più di 54 nuovi Eagle II.
L’attuale flotta potrebbe essere dotata di nuovi radar e di attrezzature aggiornate per la guerra elettronica.
nationalinterest.orgBoeing's F-15EX Fighter Could Fly for Saudi Arabia
richelieu
Re: Strike Eagle
Messaggio da richelieu » 21 febbraio 2024, 16:02
Boeing vanta, per l’F-15EX, una velocità massima vicina a Mach 3ma, in condizioni operative e con la presenza di carichi esterni, tale velocità non è praticamente raggiungibile
Un Boeing F-15EX può raggiungere quasi Mach 3 in volo controllato in una configurazione “pulita”, ovvero senza piloni esterni, munizioni o sensori, ha dichiarato, il 21 Febbraio, il Program Manager della Boeing al Singapore Airshow.
"Sì, è veloce", ha detto Rob Novotny della Boeing, ex pilota collaudatore di F-15 dell'USAF.
In particolare, Novotny ha specificato che la velocità da non superare, da parte del caccia bimotore, è di circa Mach 2,9, o circa 2.225 miglia orarie al livello del mare.
Ciò pone la velocità massima dell’Eagle II circa 80 mph al disotto di Mach 3, una velocità che solo pochi aerei alimentati da turbine a gas sono stati in grado di raggiungere.
aviationweek.comBoeing Boasts Near Mach 3 Top Speed For F-15EX
richelieu
Re: Strike Eagle
Messaggio da richelieu » 28 febbraio 2024, 1:03
Boeing si rimangia la rivendicazione che l'F-15 possa raggiungere quasi Mach 3
L'F-15 è ancora abbastanza veloce, ma non vicino a Mach 3, ha detto il responsabile del programma della compagnia il 23 Febbraio, correggendo una precedente affermazione.
"Mach 2.497 è ciò che possiamo ottenere dall'Eagle e questo è vicino a [Mach] 2.5, ma non è vicino a Mach 3", ha detto Rob Novotny su LinkedIn.
aviationweek.comBoeing Withdraws Near-Mach 3 Claim For F-15
Nota Questo articolo è pubblicato su Aerospace Daily & Defense Report, parte di Aviation Week Intelligence Network (AWIN), ed è leggibile fino al 4 Marzo 2024.
richelieu
Re: Strike Eagle
Messaggio da richelieu » 10 marzo 2024, 11:17
L'F-111 era più veloce di quanto si potesse credere
Una storia che abbiamo recentemente pubblicato sulla vera velocità massima dell'F-15EX Eagle II ha attirato molta attenzione.
La cosa più interessante è che un veterano dell'USAF si è messo in contatto con "The War Zone" per fornire un'idea della velocità ancora più impressionante che avrebbe potuto essere raggiunta da uno dei predecessori dell'aereo … l'F-111 Aardvark.
Ritornando per un momento all'F-15EX, abbiamo riferito di come il produttore Boeing ci avesse detto che il velivolo, il nuovo caccia dell'USAF, era stato in grado di raggiungere una velocità massima di Mach 2.497.
Ciò è avvenuto a titolo di chiarimento dopo che un articolo in un'altra pubblicazione aveva erroneamente descritto l'F-15EX come in grado di raggiungere una velocità di "quasi Mach 3".
twz.comThe F-111 Was Faster Than You Think
richelieu
Re: Strike Eagle
Messaggio da richelieu » 19 marzo 2024, 0:30
Alcuni piloti istruttori dell'Oregon Air National Guard si stanno addestrando sull'F-15EX
Per due settimane, nel mese di Marzo, cinque piloti istruttori di F-15C del 123° Fighter Squadron dell'Oregon ANG si stanno addestrando sull'F-15EX con istruttori dell'85° Test and Evaluation Squadron presso la Eglin AFB, Florida.
dvidshub.netPortland, Ore. Pilot conducts First Flight in EX for 142nd Wing
richelieu
Re: Strike Eagle
Messaggio da richelieu » 18 aprile 2024, 17:08
La difesa di Israele da parte dell’F-15E Strike Eagle rafforza la tesi a favore dell’F-15EX
Tra una serie di primati a seguito dell'attacco di rappresaglia dell'Iran contro Israele, incluso quello che potrebbe essere il più grande sbarramento di missili balistici di tutti i tempi e il maggior numero di scontri con missili antiaerei in una singola operazione, spiccano le prestazioni incredibili degli F-15E Strike Eagle dell'USAF.
twz.comF-15E Strike Eagle’s Defense Of Israel Bolsters The Case For F-15EX
:usa
richelieu
Re: Strike Eagle
Messaggio da richelieu » 15 maggio 2024, 15:53
Signore e Signoriqui non si taglia
airandspaceforces.comHouse Defense Bill Would Slow F-15E Retirements, Add Future F-15EXs
